i've looked around and haven't been able to find out how to capture still frames from video, specifically mpeg, but divx or avi would be fine as well. i just want to capture lots of single frames to use later. someone on the board suggested snagit, so i downloaded it, and it doesn't work. i have eo video, virtualdub, and tmpeg. is there a way with any of these to capture still frames to a file format like jpeg, gif, or bmp?
Open the mpeg in virtual dub. You can then either set a start and end point (if you want stills of sequential frames) and do a file...save image sequence, or you can do a video...copy frame to clipboard and then paste it in to Paint Shop Pro or wherever you choose.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
You can also play the video in Power DVD using its file mode playback. It has a button on the toolbar to do frame capture. It works for me!
How to extract I-Frame from Mpeg-4?
By ahrouhi in forum ProgrammingReplies: 7Last Post: 23rd Jan 2011, 18:56 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
cutting MPEG frame by frame
By headless chicken in forum EditingReplies: 3Last Post: 9th Nov 2009, 19:45 -
Still Frame and Field Capture?
By swingmaster in forum Newbie / General discussionsReplies: 1Last Post: 10th Mar 2009, 09:28 -
All Frame's Capture to show In one big Pic . ??
By lostnucleus in forum Newbie / General discussionsReplies: 11Last Post: 28th Feb 2008, 04:24
