i have a 64 meg graffix card and was wondering if there would be any advantage to putting my dxr3 card in as well or even if it would work thanks
tenor,
the dxr3 will do the mpg2 decoding and you can use it as a tv-out card as well. I'm using mine with a creative drive 12x and an ATI card with tv out. There are some 'nifty' appz that allow the removal of macrovision and regions. There's also an app to feed out divx files using the card.
As long as there are drivers for the o/s you are using from either creative {or the Hollywood Plus drivers will work too, same card}, i dont see why it wouldn't work.
ztr
