Results 1 to 19 of 19
  1. Advance Advance Cat audio codec:
    in my NLE I need to set an audio codec for mp4 encoding directly from internal, I have download an half aac codec but I don't think I have the right codec: I can not configure it
    Virtualdub cam view it in the "audio-->compressor"
    but seems to me seeing only 8kbs in the list
    According to my standard mp4 ffmpeg encoding: I need a VFW audio codec that can do the same quality of the
    -c:a libvo_aacenc -b 256k
    comandline of ffmpeg
    So I wonder: where I can find an aaC good codec, or an equivalent that is "viewved" as codec fully configurable also in my NLE as Virtualdub? thanks
  2. AACACM is actually not an encoder, decoder only. Try it in vdub , it won't encode AAC
  3. ok but can I find an alternative vfw audio codec? I need to set a decent audio codec vfw because the mp4 encoding from timeline, directly to the NLE allow me avoiding the uncompressed-export --> virtuadlub ---> final encoding procedure
    I'm not very expert but I remember there are some audio codec vfw installable in windows, do you know one or two? thanks
  4. DECEASED
    Jun 2009
    Heaven
    There is no such thing as "VfW audio", you meant *ACM codec*
    Regarding AAC, no, I'm not aware of any AAC encoder which could be used *directly* by VirtualDub.
    FWIW, "MPEG-1 Audio" (that is, mp1, mp2 and mp3) is officially supported by the MP4 container.
  5. Lame MP3 ACM.
    There is no ACM AAC codec that allows for ENcoding yet
  6. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    What NLE is that?
  7. Originally Posted by budwzr View Post
    What NLE is that?
    mmm, it has just been released and is still in a "debug" mode, it's SPEED RAZOR FOR CATS 3.0 HD Super Proofessional nle!
  8. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Hahaha. Doesn't Nero have a free AAC encoder?
  9. no but is it DirecShow or VFW?
  10. NeroAAC is neither Directshow or VFW, it's a CLI encoder that accepts stdin, or pcm wav
  11. Originally Posted by poisondeathray View Post
    Lame MP3 ACM.
    I have try the one of the link but seems to me don't find .inf file to install as .VFW codec:
    on the web I have foundhttp://www.rarewares.org/mp3-lame-dshow-acm.php codec but strange my dinosaurus cannot see it the VFW codec (also even in virtualdub he is present).
    The DS filter: it work but only @ 44.100 instead of 48KHZ ...:^^
  12. DECEASED
    Jun 2009
    Heaven
    In VirtualDub, menu "Audio", item "Full processing mode", then "Compression".
  13. In virtualdub I can see the "Lame MP3 codeec"
    but strangely I cannot see it on my NLE: I need to use the VFW codec under my NLE because I need to export in MP4 entire timeline directly from Speed Razor.
    I'm looking for anhother audio codec.
  14. How about AC3 ?
    AC3ACM
  15. DECEASED
    Jun 2009
    Heaven
    How about an up-to-date NLE?
    Seriously, the catman can have a Windows 8 machine, BUT cannot have a better video editor, WTF
  16. Originally Posted by poisondeathray View Post
    How about AC3 ?
    AC3ACM
    mmm yes this seems work :=)
    Advanced Cat3AudioCatMe Codec
  17. Originally Posted by El Heggunte View Post
    Me I have update Speed Razor, I have "do" a new playback module:
    the DVSink.rzf that can read in realtime both mjpeg and uncompressed YUY2 avi ^^
  18. Originally Posted by El Heggunte View Post
    I'm not a catman
    I'm a cat
  19. DECEASED
    Jun 2009
    Heaven
    ^ Wrong, marcorocchini is just a troll u_u
