  1. Audiophile Frozen Fractals's Avatar
    Jun 2014
    Arendelle
    I am having issues where HandBrake (v0.99 on Windows 8.1 64-bit) is only encoding a part of a file. What I mean is that, let's say...for example, I have a 2 hours 44 minutes 33 seconds movie (metadata shown below) that I want to encode using the settings listed below. However, instead of encoding the whole file (all frames) like I tell it to, it is only encoding about half of it (1 hour 7 minutes 44 seconds to be exact). (NOTE: This happened twice - this along with another movie - in the past 24 hours and I am using only one of the occurrences as an example.) Why is it doing this and how can I fix it?
    HandBrake Results:
    HandBrake Settings:
    - All chapters
    - Mkv output
    - Strict anamorphic
    - Automatic cropping
    - Default detelecine, Default decomb, off deinterlace, off denoise, off deblock, unchecked grayscale
    - H.264 codec
    - Same as source FPS
    - Variable framerate
    - Very slow preset
    - Film tune
    - High profile
    - 4.1 level
    - 18 CRF
    - No audio, no subtitles, no chapters
    Original File Metadata:
    General
    Unique ID                                : 331177862422873921685895677283931576227 (0xF926894570EB2D33456512715354D7A3)
    Complete name                            : E:\The Dark Knight Rises (1080p HD).mkv
    Format                                   : Matroska
    Format version                           : Version 2
    File size                                : 32.7 GiB
    Duration                                 : 2h 44mn
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 28.4 Mbps
    Movie name                               : The Dark Knight Rises
    Encoded date                             : UTC 2014-05-11 19:19:38
    Writing application                      : MakeMKV v1.8.10 linux(x64-release)
    Writing library                          : libmakemkv v1.8.10 (1.3.0/1.4.1) x86_64-linux-gnu
    Video
    Format profile                           : High@L4.1
    Format settings, ReFrames                : 2 frames
    Format settings, GOP                     : M=1, N=10
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 2h 44mn
    Bit rate mode                            : Variable
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Audio
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Format profile                           : MA / Core
    Mode                                     : 16
    Format settings, Endianness              : Big
    Codec ID                                 : A_DTS
    Duration                                 : 2h 44mn
    Bit rate                                 : Unknown / 1 509 Kbps
    Channel(s)                               : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 24 bits
    Compression mode                         : Lossless / Lossy
    Title                                    : Surround 5.1
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
  2. Audiophile Frozen Fractals's Avatar
    Jun 2014
    Arendelle
    Originally Posted by roma_turok View Post
    Try with VidCoder
    VidCoder is based on HandBrake
    I will try that, but I am curious as to what is causing the issue at hand. Is it HandBrake, my setup, the files, or a combination of the above?
  3. Did you use HandBrake 64bit version?
    upload log file of encoding by going to Tools -> Option -> Advanced -> View Log Directory
    in directory you can find logs of previous encodes, usual with name of video file
    what happens when if you set preset to Normal without changing anything?
  4. Audiophile Frozen Fractals's Avatar
    Jun 2014
    Arendelle
    Ok I think I have found out what is causing it. Whenever I am processing an encode and load the CPU with an additional task (i.e. a game, etc.) it "crashes". I have been able to repeat it thrice on demand. No solution to why it causes it to crash other than the presumption that it most likely "overloads" the CPU. Nevertheless, I'll just run my encodes overnight from now on as to not disturb the process.
    canada
    Rip your disc again and re-encode.Might be a problem with the ripping.
