Results 1 to 30 of 40
  1. Banned
    Dec 2004
    What is currently the best codec for 4k video??
  2. DECEASED
    Jun 2009
    Heaven
    Assuming you have a HUGE display or monitor and a DAMN-FAST multicore machine, then HEVC is (or will be) the way to go.
    Otherwise, AVC still is "the king".
  3. Banned
    Dec 2004
    I am asking about mp4 mpeg avi which is best for 4k which??
  4. Member Cornucopia's Avatar
    "Best"? Means many things to different people. If you mean "highest quality for lowest bitrate, regardless of complexity", the CURRENT best codec is h.264/AVC. A few years from now it would likely be h.265/HEVC, but not yet for everyday consumer use.
    Btw, do you have a 4k monitor with which to view & evaluate?
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    mp4, mpeg and avi are video containers.
    h264/avc and h265/hevc are video codecs.
  6. Originally Posted by DJboutit View Post
    Which is best cake in cardboard box or cake in a glass cake dish? Containers have no bearing on the quality. The codecs and settings used determine the quality. Assuming you mean "picture quality" when you say "best".
  7. Banned
    Dec 2004
    I have a 32" 720p flat screen tv as my monitor
  8. Originally Posted by DJboutit View Post
    And you think you'll benefit from 4K source material?
  9. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Then your question is meaningless.
  10. Banned
    Dec 2004
    Well it is better for 4k than a 19" to 24" monitor this thread was has nothing to do with my monitor it is just a general question
  11. Member racer-x's Avatar
    Mar 2003
    Your question has already been answered. The current best codec is AVC or VP9. mp4 and mpg are containers and have nothing to do with codecs aside from containing them.
  12. Some folks swear by redcode or blackmagic raw. But you don't actually mean BEST, do you?
  13. Originally Posted by DJboutit View Post
    Not necessarily. I have a 22" 1080p TV. That will show more detail than your 32" 720p TV. I also have a 27" 2560x1440 computer monitor. That will show even more detail. Whether you can see that extra detail depends on the viewing distance.
  14. I'm a Super Moderator johns0's Avatar
    canada
    Mpeg1.
  15. Member racer-x's Avatar
    Mar 2003
    Mpeg1.
    4k Mpeg1 video clip:
  16. I'm a Super Moderator johns0's Avatar
    canada
    Originally Posted by racer-x View Post
    Mpeg1.
    The video is mpeg2,not mpeg1.
  17. Member racer-x's Avatar
    Mar 2003
    I used ffmpeg with:
    -vcodec mpeg1video
  18. I'm a Super Moderator johns0's Avatar
    canada
    It shows as mpeg2 with tsmuxer and mediainfo.
  19. Member racer-x's Avatar
    Mar 2003
    It probably defaulted to Mpeg2 because of the resolution. It gave a bunch of buffer underflow errors while encoding.
  20. DECEASED
    Jun 2009
    Heaven
    Below are two UHD MPEG-1 still pictures Sample #2 used an "ALL-8" intra matrix.
    They were generated with the olde TMPGenc Plus, of course
    I tried mpeg2enc as well, however it has some stupid limitation on the max VBV buffer size (1024kB for MPEG-1)
    Besides, VirtualDub cannot open the samples, and says "No video stream!"
  21. I'm a Super Moderator johns0's Avatar
    canada
    That's a common issue when just outputting video only,the track info isn't present so most apps will report no track found,ffmeg command line fixes that issue.
  22. DECEASED
    Jun 2009
    Heaven
    Geez, I do need more , how in the world did I forget Motion JPEG 2000
  23. Member racer-x's Avatar
    Mar 2003
    Prores uses motionjpeg 2000, and what does that have to do with mpeg-1.....
  24. DECEASED
    Jun 2009
    Heaven
    And since when MPEG-1 is suitable for UHD?
  25. Member racer-x's Avatar
    Mar 2003
    Oops, I forgot about the original question....
  26. Member Cornucopia's Avatar
    @racer-x, prores does NOT use mjpeg nor mjpeg2000 (at least not standard version), it's Apple proprietary.
    As I said earlier, depends on one's definition of "best". If best is meant in terms of "quality regardless of bitrate or complexity", then uncompressed, lossless compressed, or raw formats would top the list.
    This, however, sounds like a hypothetical posed by someone with little invested in the answer, or even a full understanding of the variables involved, so that's enough effort for me for now.
  27. Member racer-x's Avatar
    Mar 2003
    The prores version I use is from ffmpeg and that one uses mjpeg 2000 according to Virtual dub anyway...
  28. Member racer-x's Avatar
    Mar 2003
    Mpeg1.
    I just demuxed the Scorpion.mpg and ran it through DGindex. It reported the stream was indeed Mpeg-1
    Stream Type: Elementary
    Profile: [MPEG1]
    Frame Size: 3840x2160
    Display Size: [not specified]
    Aspect Ratio: 1:1
    Frame Rate: 24.000000 fps
    Video Type: NTSC
    Frame Type: Progressive
    Coding Type: P
    Colorimetry: BT.470-2 B,G*
    Frame Structure: Frame
    Field Order: Bottom
    Coded Number: 174
    Playback Number: 174
    Frame Repeats: 0
    Field Repeats: 0
    VOB ID:
    Cell ID:
    Bitrate: 16.200 Mbps
    Bitrate (Avg): 12.458 Mbps
    Bitrate (Max): 16.200 Mbps
    Timestamp:
    Elapsed: 0:00:15
    Remain: FINISH
    FPS: 10.80
    Info:
  29. Member racer-x's Avatar
    Mar 2003
    Vegas reports ffmpeg Prores as Apple Codec. Here's what Virtualdub says about ffmpeg Prores. I'm probably wrong here.
  30. DECEASED
    Jun 2009
    Heaven
    Yes, there is a bug, but I can't determine where it is exactly
    As far as I knEw, ProRes is not MJP2.
