Help would be appreciated .... every start-up Autoload.exe appears on the screen and it really is annoying, is there a way to stop it from happening ???
Cheers from downunder.
Yes, go to Bleepingcomputer.com and learn about how to remove rootkit viruses (esp. via known-clean bootable rescue discs/usb flash).
Scott -
Hi Scott,
Thank you for your response however this application is not for me.Cheers from downunder. -
His advice is good,it's not an app to use,just read how to remove bad programs and bugs,if you can't do that then hire a computer geek to do it for you.
Try with System explorer in Autoruns category
find Autoload.exe and delete it
Disable Auto Insert Notification (AKA AutoPlay): http://www.aleratec.org/s.nl/ctype.KB/it.I/id.6992/KB.3433/.f?category=215
