You are. The Theatre chips seems to be implicated in the false Macrovision detection problem as well as the AGC issue in more recent ATI products. The TV Wonder 600 USB simply does not have the same problems.
Nice try, but that article highlights a much older and very different device from a different ATI product line, and the capture software detects CGMS-A, in my experience. You are in a deep hole already. Stop digging.
Results 31 to 47 of 47
I don't think that is a fair assessment. The 750 USB supposedly has a Theatre 750 chip (Diamond says this in its product description). I know for certain that it includes a far more advanced TV tuner than the TV Wonder 600 USB. It isn't physically impossible. I have seen a PCI-e mini card version of the TV Wonder 750, and the circuit board for that would certainly fit inside the 750 USB's enclosure.
Originally Posted by SHSI hate VHS. I always did.
The 750 USB does have a better TV tuner than the 600 USB. However, its analog capture was very bad, and nothing compared to the ATI 600 USB.
Given that there are better dedicated TV tuner devices available than the 750, and given that anyone using the 600 (at least in this Forum) really doesn't care about its tuner, is my reason to say that the 750 was rather useless and sucked. It was nothing like the 600.I hate VHS. I always did. -
@PuzZLeR I'm sure that you have captured a larger number of VHS tapes than I have. I take it you have not noticed any unusual problems with false Macrovision detection using the TV Wonder 600 USB, since you don't seem to need a full-frame TBC or a Grex to use it.
[Edit]My comments about the TV Wonder 750 USB were to spell out that the hardware used is very different from that used in the TV Wonder 600 USB, so there is no good reason think of them as similar devices.Last edited by usually_quiet; 15th Jul 2014 at 22:28.
This would make sense wouldn't it??! I mean even if there was a half-assed TBC on the usblive-2 I would probably be happy. Happague support guy emailed me back and asked if I tried the arcsoft showbiz capture software. I lol'ed, I'm tired of installing crapware (I have a bit of prejudice admittedly, I dunno, maybe it's a nice piece of software??) but I will try it out.
He also said about the 'vcr input' option being greyed out that it's because the driver doesn't support it. And most worryingly, he said he doesn't know why video is flickering. -
I suspect there is no TBC in the USB-Live 2. It is relatively inexpensive, and the need for analog tape capture has greatly diminished over the past 10 years.
Showbiz by itself won't let you use the TBC in the USB-Live 2, assuming there is one. I have a capture device that has a TBC, the Hauppauge Colossus, which costs a bit more than 3 times as much as the USB-Live 2, and hardware encodes its captures to H.264. The TBC can only be enabled by using a registry hack. As far as I can tell, there is no such hack for the USB-Live 2. -
Never any induced by the 600.
When I do notice a false positive, this happens also with other capture devices and the problem is the tape, VCR, TBC or whatnot, and nothing to do with the ATI 600. Even though having the ES15 is rather beneficial, for a large majority of the tapes I capture, I'm quite confident without a full-frame or Grex in the chain.
Worth noting, I have never seen any AGC issues either with the 600.
I say this after about 5 years of using the 600 with many tapes and many hours of analog TV recordings. (I'm still using/abusing the first unit even though I have two backups.)
The 600 is quite solid.
Originally Posted by usually_quiet
I have been looking for some link I remember seeing years ago on the 750's architecture. I can't find it now unfortunately, so working from memory here, but the chipset under the hood of the 750, even the 650, was quite a different story from the 600.Last edited by PuzZLeR; 16th Jul 2014 at 11:56.
I don't think you would. There are many "TBC"s around, and many of them rather weak, such as internal ones in some VCRs, and other products claiming one, or something similar (ex: "video stabilizer" in the discontinued ADVC 300). Many can be very misleading, and the term "TBC" has been often loosely used. So, having a substandard TBC IMO means you may as well not have one. They don't do much unless it's an established real one. Don't bother with any "claims" from companies on this. Many of them have no clue or will twist things.
Originally Posted by Event3horizon
Packaged software that comes with many capture devices is usually inferior, buggy, and has limited features. Don't bother with it. Of course the company will recommend it, but that's not because it's good.
Even if the software is good, such as VirtualDub is, it still won't solve your problem.
True, the driver maybe doesn't support the "VCR Input" function, whatever it is supposed to be doing, but the fact that he has no clue of the erratic video - typical of analog tape to digital - from one who is supposed to be "Support" for a product supposedly dedicated to analog capture, is pathetic.
He probably is a peon, or script reader, or got in because he knows someone in the company. Or maybe he's just winging it, or even hiding something. Who knows.
Then again, I have never gotten any good advice on capture devices from any company I've contacted about them for over a decade now. (Pinnacle/Dazzle also come to mind here too.)I hate VHS. I always did. -
Well I'm getting nowhere with the Happauge support (it's a joke) and I've tried an old samsung miniDV cam that has analog input and to my surprise it DOES correct the video, sadly though.. there is no way to use it as a pass-through. I must capture it on miniDV tapes. Sucks.
The panasonic es10-15 are going for at least 90-100 dollars on ebay and a bit past my budget at the moment. This is where I start hating analog tape technology. -
We should dedicate a thread here, and post it publicly to what we hear from "Support" teams from all sorts of video products. Many of these folks are comedians.
What may work is we give them full disclosure, and a disclaimer from the start, that their "advice" will be publicly posted. I'd love to see how they would react to this.
But, yeah, it does appear the price is rising on these units (as I was expecting, from another thread). But this, in some ways, is a good sign. The forces of supply and demand are raising the price because it's something people want from much advice on the 'Net about these units, and the fact that other TBCs, or similar, are in bad production, flaky, discontinued, over-priced, or just plain useless or bad.
Originally Posted by Event3horizon).
Yes my friend, this is indeed only the "start", and gets more and more involving. You're in for quite a ride!
I hate VHS. I always did.I hate VHS. I always did. -
Well there has been an interesting twist to my story. I've finally found the solution, and the solution was to ditch the usblive-2 (returning it) and continue to use my Pinnacle 500 USB. Someone in this thread gave me an idea of reviving the usage of XP for analog to digital capture and this proved key.
I found an amazing capture program, called 'CaptureFlux', that works on detecting the Pinnacle 500 device properly. Not only that, but I can select the s-video source (this is where some capture programs failed) and I can use it as an audio source (yet another thing other programs failed on)
So I'm able to use captureflux in windows xp with the pinnacle 500 usb and use it to capture interlaced material and into a .DV file. THE BEST PART is, the pinnacle 500 HAS to have some sort of line corrector because all my flicker and tear problems have gone away. And I was almost going to throw this thing away because it was horrible with Win 7!
Problems solved. I can't believe happauge can't put some corrector in their device like the 500-usb has. Shame. -
The Pinnacle 500 doesn't have a line TBC. The problems on the Hauppauge are intentional. They err on the side of their Macrovision masters now. Any hint of a time base error and they intentionally screw up the picture. Not like the old days when the PVR 250 and PVR 350 ignored macrovision.
See http://www.mediacollege.com/video/editing/macrovision/
Homemade tapes can have noise in the VBI that confuses the automatic gain control in some capture devices just like Macrovision. Some capture devices are known to filter out all or part of the VBI. My guess is that the Pinnacle device does that, depending on whether VCR input is on or off. The VBI doesn't contain any picture information. The only part of the VBI that people might be interested in capturing are analog closed captions, but most file formats and video capture formats don't provide a way to store them.
[Edit]...or another guess is that checking the VCR input box turns off the capture device's automatic gain control.Last edited by usually_quiet; 28th Jul 2014 at 21:54.
