  1. Hi all,
    I'm looking to make a reference/demo disc of small clips from various movies for Blu-ray. And I also want to make custom menus with my own art/buttons/etc.
    I now how to extract m2ts files, the question is, how to I then build a disc with them? I don;t want to re-encode or any quality loss. I figure there has to be a way to map them like that.
    I'm using a Mac, but I have access to a PC if that's the only way.
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Look in the software section of videohelp for blu-ray authoring s/w:
    https://www.videohelp.com/tools/sections/authoring-bd-hd-dvd
    Apr 2006
    Brazil
    At that section you will find https://www.videohelp.com/tools/multiAVCHD.
    It is freeware and one of the bests!
  4. Originally Posted by fjmr View Post
    Maybe I'm just stupid, but I don't see any way to build menus to select the various clips.
    Feb 2014
    QUÉBEC
    Just select ''add Title List'' in the Author tab, and uncheck ''play all (sequential playback)''
    Apr 2006
    Brazil
    At top of Multiavchd soft screen you have Media, Author, Menu. You should click on menu and set accord you want!
    https://www.videohelp.com/toolsimages/multiavchd_1174.jpg
