Has anyone tried this? If so, care to share you experiences?
Can I author 4.7GB worth of MPEG-1 files (VCD spec) onto on DVD-R?
Will it play on settop DVD players? DVD-ROM (on computer?)
you can convert your vcd into mpeg and join all the vcd disk, but vcd is half the resolution of dvd so the quality would not be as good, ulead dvd studio allows you to save video as dvd video which has a good resolution 720x576, if u join all the files on vcd it would fit as one file on a dvdr as mpeg, but no set top player would play it
homer2067
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 10:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 01:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
