How do I create mpgs, mpegs, avis, asfs,etc into a vcd format? So I can
burn and play into VCDs. What programs do I need? I've read all the
other instructions but it's too long and complicated. Can anyone break
down the process and post. I'm preparing for my summer 8)
Please Help!!
The programs you use and the steps to take depend alot on what your source video is. Go back in the "How To" column and click on the particular subject your wanting to learn. Don't try to read and then remember all that stuff. Print it out so you can have it to look at while you're doing your converting. Download the programs it says you need, get them installed on your computer the way it says to, in the same folder. Look at your print-out and go step by step. I just started this stuff too and so far my VCDs have come out pretty good. I use Kwags templates and modify them if I need to for each VCD I make.
Originally Posted by Stev1ous
1, download move
2, load into "Virtual Dub"
3, select Video > Scan video stream for errors
4, select Video > streaming, select audio > streaming
5, SAVE AS, save out movie2.avi
6, Load new movie2.avi into "TMPGEnc"
7, click the load button and load a VCD template (PAL/NTSC)
8, select output file and location
9, click START
10, check size of mpeg, if to large for one CD, load TMPGENC and select FILE > MPEG TOOLS
11, Select Merge&Cut
12, ADD > select your movie2.mpg
13, click edit > use { } for start and end
14, use drop down arrow and select "MPEG 1 Video CD"
15, type output file and location (part1.mpg)
16, click RUN
17, click edit and use { } again for second half
18, type output file and location (part2.mpg)
19, Click RUN
20 load burner software (use VCD)
21 drop part1 into it, burn cd
22 drop part2 into it, burn cd
23, make cup of coffee
24, place VCD in DVD and press play
25 watch movie
26, think your yourself, dam that was easy -
Actually the 'How To's are quite explicit and not that complicated(geez I can do it!).
All you need is here and most of it is free including Virtualdub,TMPGE and VCDEasy. -
Ulead DVD Movie Factory has a 30-day trial and costs only $45 after that. It's a super easy program and does a lot of automatic conversions for you (some argue you get better quality with other programs, but this program still does good work).
Download it from: www.ulead.com
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 02:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 02:52 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 10:38
