  1. Hello, I've been trying to join two mkv files into one mkv, but the resulted file plays only the first part correctly and the second part is only audio and pixels.
    I tried with both mkvtoolnix and avidemux but I get the same result. The two mkv files are encoded from 2 flv files with the same audio, aspect ratio and fps (only different video bitrate). The two mkv also have the same audio, aspect ratio and fps and I have tried both maintaining the initial video bitrates (from flv) and also encode them with exactly the same video bitrate. But they don't want to merge
    I tried also joining the 2 FLVs into one flv (before encoding them into mkv) with avidemux but when I try to save the appended files avidemux says it supports only flv1 and vp6.
    I tried also to use virtual dub but when I try to load the flv it says there is no video stream (?)
    So, I ran out of ideas and thought to ask here.
    I have windows 7 x64, latest versions of mkvtoolnix, avidemux, virtual dub and ffdshow and I used handbrake to turn the flv into mkv
  2. DECEASED
    Jun 2009
    Heaven
    MediaInfo is not Google, therefore it's your friend
    Please tell us what it says about those FOUR files (2 FLVs and 2 MKVs).
  3. General
    Complete name : Part1.flv
    Format : Flash Video
    File size : 85.3 MiB
    Duration : 14mn 23s
    Overall bit rate : 828 Kbps
    httphostheader : r7---sn-cg07luez.c.youtube.com
    Video
    Format : AVC
    Format profile : Main@L3.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Format settings, GOP : M=1, N=50
    Codec ID : 7
    Duration : 14mn 23s
    Bit rate : 691 Kbps
    Width : 600 pixels
    Height : 480 pixels
    Display aspect ratio : 5:4
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.096
    Stream size : 71.2 MiB (83%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 10
    Duration : 14mn 23s
    Bit rate : 129 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 13.3 MiB (16%)
    General
    Complete name : Part2.flv
    File size : 71.7 MiB
    Duration : 15mn 27s
    Overall bit rate : 649 Kbps
    httphostheader : r5---sn-cg07luez.c.youtube.com
    Video
    Format : AVC
    Codec ID : 7
    Duration : 15mn 27s
    Bit rate : 512 Kbps
    Width : 600 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.071
    Stream size : 56.6 MiB (79%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 10
    Duration : 15mn 27s
    Bit rate : 129 Kbps
    Stream size : 14.2 MiB (20%)
    General
    Unique ID : 176455759026245649956609969871923384970 (0x84C0249CC01F51A518558EC8C5BF128A)
    Complete name : Part1.mkv
    Format : Matroska
    Format version : Version 2
    File size : 66.0 MiB
    Duration : 14mn 18s
    Overall bit rate : 644 Kbps
    Writing application : HandBrake 0.9.9
    Writing library : libmkv 0.6.5
    Video
    Format : AVC
    Format profile : High@L3.0
    Format settings, ReFrames : 5 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 14mn 18s
    Bit rate : 512 Kbps
    Width : 584 pixels
    Height : 348 pixels
    Display aspect ratio : 1.678
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.101
    Stream size : 51.5 MiB (78%)
    Writing library : x264 core 130 r2273 b3065e6
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=512 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 14mn 18s
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Bit depth : 16 bits
    Stream size : 13.1 MiB (20%)
    Default : Yes
    Forced : No
    General
    Unique ID : 298668510556091661532119428742467475688 (0xE0B1767992985017E13DB53244AED8E8)
    Complete name : Part2.mkv
    Format : Matroska
    File size : 71.2 MiB
    Duration : 15mn 27s
    Video
    Format : AVC
    Duration : 15mn 27s
    Bit rate : 512 Kbps
    Width : 584 pixels
    Height : 348 pixels
    Color space : YUV
    Bit depth : 8 bits
    Stream size : 55.7 MiB (78%)
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : AC-3
    Codec ID : A_AC3
    Duration : 15mn 27s
    Bit rate : 128 Kbps
    Bit depth : 16 bits
    Default : Yes
    Forced : No
  4. DECEASED
    Jun 2009
    Heaven
    Hmmm, apparently there's nothing wrong with those MKVs
    Anyway: What players have you tried? Does the problem happen in all of them?
    And if MKVtoolnix gave you an error message, what did it say?
  5. I tried vlc, pot player, mpc and they all play only the first part while the second part is only audio and pixels.
    mkvtoolnix didn't give an error message. It completed the process but the resulted file had the above problem. Exactly the same happened with avidemux when merging the mkv files.
    The error messages (in avidemux and virtual dub) were only when I tried to join the flv files.
    Is there any other reliable software that will join the flv files without changing their quality? Then maybe I can try and encode the joined flv into mkv.
    Note: I just tried to save the joined flv into another form (mkv) with avidemux and it let me. But as I am not very familiar with the software, can anyone please tell me if the quality drops in this case? Here is the resulted technical specs:
    Format : Matroska
    File size : 156 MiB
    Duration : 29mn 51s
    Overall bit rate : 729 Kbps
    Writing application : Lavf54.63.104
    Writing library : Lavf54.63.104
    Video
    Format : AVC
    Duration : 29mn 51s
    Width : 600 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 29mn 51s
    Language : unknown
    Default : Yes
    Forced : No
  6. Apparently avidemux keeps the same quality for the joined flv even if it's saved as mkv (as long as audio and video outpout is set to "copy"). So I managed to join the files.
    I just want to ask something more. I want to crop and re-encode the file into mkv but keep the quality as close to the initial quality, but the 2 initial files have different video bitrates (691 and 512). If I do a double pass with 691 kbps, I will probably end up with a larger file and 512 will drop the quality. Is there a workaround so I don't loose in quality but I don't end up with a larger file?
  7. There is no workaround. A re-encode will mean a loss in quality no matter what. If you want the same file size you'll need a bitrate of 605 kbps for the video part leaving the audio bitrate unaltered.
  8. OK, thank you (everyone) very much for your help.
