Hello. I want a program that can convert YV12 into RGB.
I don't want to change anything else whatsoever on my video, just the color format. Simple, isn't it?
How can I do it? (also, the program must work with .mkv)
Results 1 to 13 of 13
Your question doesn't really make any sense. What is it you are trying to do? You have uncompressed Y12 video and you want to make it uncompressed RGB?
Nevermind, I was trying to do something here but it actually won't work the way I intended.
But... take a look at this:
^I have this video but it's way too big: 4.55GB. It'd take forever for me to upload to youtube with my slow internet speed.
So I want to convert it to .mkv so it will reduce the file's size. What's a good way to do that? -
You can use mkvtoonix to rewrap to mkv with no conversion whatsoever.
If you want to reduce the file's size (not what you originally asked) try handbrake. -
Encode your video with Lagarith or UtVideo codec
AND
Select the RGB(A) mode of these codecs
Then just use mkvtoolnix to mux into mkv. -
There's no reason to convert YV12 lagarith to RGB lagarith. Doing so will only make the file bigger and lose a little quality. Any program that can read RGB lagarith can read YV12 lagarith. They guy just wants a smaller video for upload to youtube. I verified that Handbrake can read the original YV12 Lagarith file. So it's a simple matter to open it in Handbrake, select and configure a video codec, and save it in an MP4 or MKV file.
Ok. So, seems like Handbrake is what I should use, right?
Can someone post a screenshot here with the correct configurations I should select on Handbrake? I want something that will reduce file size but will also keep the quality nearly as good as the original. But it must reduce it to a reasonable size. And by that, I mean something I can upload to youtube with an internet this fast:
http://www.speedtest.net/my-result/3592468912 -
Try the Regular -> High Profile preset, h.264, Constant Frame Rate, Constant Quality, RF=18 to 21.
FYI, Ookla Speedtest is not reliable: http://testmy.net/ipb/topic/28902-why-do-my-results-differ-from-speedtestnet-ookla-speed-tests/
Secondly, YouTube resamples the audio to 44.1kHz, so you'd better record the sound of your games at 44.1kHz as well.
FWIW: when I had a YouTube channel for my M.U.G.E.N videos, I used either Xvid or WMV3, with
constant quantizer = 3, maximum GOP length = 300 frames, no B-frames. And for Xvid especifically,
quantization type = MPEG-2. Audio remained uncompressed. Also, keep in mind that HTTP file transfers
can use compression, and as a consequence, sometimes the uploads happen faster than you expected ^_^
