How do I change the frame rate from NTSC to PAL?
THanks
In TMPGEnc there is an option for 3:2 pulldown or inverse telecine. I forget which one is which. But that should do it.
Most likely you would need to do some post processing with a video editor, and then use the same settings. I recommend VirtualDub.
@swanside, I think it is necessary to give us some more details.
@both, I recommend to read the guides.
http://www.vcdhelp.com
http://www.doom9.org
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
