  1. For kindness, ndjamena can you help my cat that need you? ^^
    I would like to change my (your) modified script.
    At the moment this modified script do this: distinguish if the input file (or drag and dropped) is internally mjpeg or uncompressed yuy2.
    If it is mjpeg ---> goto procedure for mjpeg
    If it is yuy2---> goto procedure for uncompressed
    result is a file .mxf
    Source is a .avi file and a .wav file:
    this line is for uncompressed
    ffmbc -loglevel fatal -y -i "%CD%\%~n1.avi" -i "%CD%\%~n1.wav" -target imx50 -aspect 16:9 %WorkFolder%\%~n1.mxf
    and this is for mjpeg:
    ffmpeg.exe -y -i "%CD%\%~n1.avi" -pix_fmt yuvj422p -an -f rawvideo - | v:\automazioneclip\core\ffmbc.exe -loglevel fatal -y -f rawvideo -pix_fmt yuv422p -s 720x576 -r 25 -i - -tff -i "%CD%\%~n1.wav" -target imx50 -aspect 16:9 %WorkFolder%\%~n1.mxf
    booth use as audio source the same filname of the .avi. For example: if I drag and drop C:\cats\C0001.avi, the command line use c:\cats\C0001.wav as audio source.
    Now I would like change it so it do this:
    1) if audio source does not exist (if the the same filename with extension .wav is not found in the same dir of the .avi) the batch assume that audio is v:\empty.wav
    2) I would like integrate a timecode in the .mxf so would be nice if the batch ask to the user... "please specify timecode, press Enter", within 3 second. If in 3 second the user don't press ENTER the batch start the procedure without timecode.
    But if the user press enter and put a timecode (e.g.) 01:22:40:55
    the command line become
    ffmbc -loglevel fatal -y -i "%CD%\%~n1.avi" -i "%CD%\%~n1.wav" -target imx50 -timecode 01:22:40:55 -aspect 16:9 %WorkFolder%\%~n1.mxf
    THANKS!!!!!
  2. This is the batch:
    @rem unless otherwise specified for debugging reasons turn echo off
    @if "%EMode%"=="" Set EMode=ON
    @ECHO %EMode%
    @ECHO off
    SetLocal DisableDelayedExpansion
    Set "EXTLIST=*.avi"
    Set "DoPop=0"
    Set "ARGLVL=0"
    Set "FileName-DQ="
    Set VDM_LOC="v:\automazioneclip\VirtualDubMOD\virtualdubmod.exe"
    if not exist v:\automazioneclip\output\progetto1 mkdir v:\automazioneclip\output\progetto1
    set "DestFolder=v:\automazioneclip\output\broadcast"
    Set "WorkFolder=%DestFolder%"
    if not exist %DestFolder% mkdir %DestFolder%
    rem process the arguments one by one
    :ARGS
    	rem if there are no further arguments then exit the batch.
    	if [%1]==[] (
    		if "%ARGLVL%"=="0" (
    			CALL :GetTargetName
    			EndLocal
    			pause
    		goto :eof
    	rem wildcard processing
    	Set "FileName=%~1"
    	if "%FileName%"=="" (
    		SHIFT
    		goto :ARGS
    	rem if the argument doesn't exist in the file system in any form skip it.
    	if NOT EXIST %1 (
    		SHIFT
    		goto :ARGS
    	if NOT [%1]==[] if NOT "%FileName:^*=%%FileName:^?=%"=="%FileName%%FileName%" (
    		for %%w in (%1) DO (
    			Set /a ARGLVL+=1
    			CALL :ARGS "%%~fw"
    			Set /a ARGLVL-=1
    		SHIFT
    		goto :ARGS
    	Set "FileName="
    	rem Set search/recursion variables
    	Set "Pattern=%EXTLIST%"
    	Set "STARTLVL=0"
    	Set "FOUNDLVL=1024"
    	rem if the argument is the current directory then process everything in it.
    	if "%~f1"=="%CD%" (
    		rem echo Processing Directory "%CD%"
    		CALL :START %1
    		SHIFT
    		goto :ARGS
    	rem Test if the argument is a directory, if it is move to it then process everything in it, if not then move to the file's parent directory and process the file.  Then return to starting directory.
    	Type NUL
    	pushd "%~f1" 2> nul
    	if NOT "%errorlevel%"=="0" (
    		if NOT "%CD%\"=="%~dp1" (
    			pushd "%~dp1"
    			Set "DoPop=1"
    		Set Pattern="%~nx1"
    	) else (
    		rem echo Processing Directory "%~f1"
    		Set "DoPop=1"
    	CALL :START %1
    	if "%DoPop%"=="1" (
    		popd
    		Set "DoPop=0"
    	SHIFT
    goto :ARGS
    :START <CURRENT_ARG>
    	rem Count is superseded by FOUNDLVL but may still be useful for renaming purposes
    	Set "Count=0"
    	rem Process all files in the current directory fitting the arguments search pattern.
    	for /f "delims=" %%y in ('dir %Pattern% /b /od /a-d') do (
    		if /I NOT "%%~y"=="File Not Found" CALL :Process_File "%%~fy"
    	rem if it didn't find anything search all directories instead
    goto :eof
    	if "%Count%"=="0" if %STARTLVL% LSS %FOUNDLVL% (
    		for /d %%b in (*) do (
    			pushd "%%~fb"
    			rem echo Processing Directory "%%~fb"
    			Set /a STARTLVL+=1
    			CALL :START "%%~fb"
    			Set /a STARTLVL-=1
    			popd
    goto :eof
    :Process_File <AVI_FILENAME>
    	Set /a Count+=1
    	Set "FOUNDLVL=%STARTLVL%"
    	echo Processing "%CD%\%~nx1"
    	if /I NOT "%~x1"==".avi" (
    		echo "%~nx1"
    		echo  is not a .avi file
    		pause
    		goto :eof
    	if EXIST "%DestFolder%\%~n1.avi" (
    		echo  File già esistente nella directory di destinazione %DestFolder%
    		goto :eof
    	if EXIST "%WorkFolder%\%~n1.mp4" (
    		echo  Working File Already Exists...
    		goto :eof
    		pause
    	rem Find TimeCode Info
    	Set AUCount=0;
    	for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\virtualdubmod\FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_entries stream^=codec_type^,codec_tag_string^,width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version "%~1" 2^>^&1') DO (
    		 if "%%~g"=="TAG:company_name" set "T_Company_Name=%%~h"
    		 if "%%~g"=="TAG:product_name" set "T_Product_Name=%%~h"
    		 if "%%~g"=="TAG:product_version" set "T_Product_Version=%%~h"
    		 if "%%~g"=="TAG:timecode" set "TIMECODE=%%~h"
    		 if "%%~g"=="width" set "V_Width=%%~h"
    		 if "%%~g"=="height" set "V_Height=%%~h"
    		 if "%%~g"=="sample_aspect_ratio" set "V_PAR=%%~h"
                     if "%%~g"=="codec_tag_string" set "codec_tag_string=%%~h"
    		 if "%%~g"=="codec_type" if "%%~h"=="audio" set /a AUCount+=1
    	if "%V_Width%"=="" (
    		echo  ERROR: Video Width NOT FOUND!
    		pause
    		goto :eof
    	if "%codec_tag_string%"=="" (
    		echo  ERROR: no codec tag FOUND!
    		pause
    		goto :eof
    	if "%V_Height%"=="" (
    		echo  ERROR: Video Height NOT FOUND!
    		pause
    		goto :eof
    	if "%V_PAR%"=="" (
    		echo  ERROR: Video PAR NOT FOUND!
    		pause
    		goto :eof
    	rem Set "V_Q=UD"
    	rem if %V_Width% LEQ 1920 if %V_Height% LEQ 1120 \\
    	Set "V_Q=HD"
    	rem if %V_Width% LEQ 1280 if %V_Height% LEQ 752 Set "V_Q=MD"
    	if %V_Width% LEQ 1024 if %V_Height% LEQ 608 Set "V_Q=SD"
    	echo  Using %V_Q% Mode
    	echo  PAR = %V_PAR%
    	if "%TimeCode%"=="" echo Warning! no TimeCode Found!
    	if NOT "%TimeCode%"=="" echo Timecode= %TIMECODE%
    if "%codec_tag_string%"=="YUY2" (CALL :MAKEVCF_YUY2 "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1")
    if "%codec_tag_string%"=="MJPG" (CALL :MAKEVCF_MJPG "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1")
    rem CALL :MAKEVCF "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1"
    	echo  FATTO
    	echo.
    	echo ---------------------------------------------
    	echo.
    	EndLocal
    goto :eof
    :MAKEVCF_YUY2 <VCF_FILENAME> <AVS_FILENAME> <AVI_FILENAME> <avi_FILENAME>
            v:\automazioneclip\core\ffmbc -loglevel fatal -y -i "%CD%\%~n1.avi" -i "%CD%\%~n1.wav" -target imx50 -aspect 16:9 %WorkFolder%\%~n1.mxf
    goto :eof
    :MAKEVCF_MJPG <VCF_FILENAME> <AVS_FILENAME> <AVI_FILENAME> <avi_FILENAME>
            v:\automazioneclip\core\ffmpeg.exe -y -i "%CD%\%~n1.avi" -pix_fmt yuvj422p -an -f rawvideo - |  v:\automazioneclip\core\ffmbc.exe -loglevel fatal -y -f rawvideo -pix_fmt yuv422p -s 720x576 -r 25 -i - -tff -i "%CD%\%~n1.wav" -target imx50 -aspect 16:9 %WorkFolder%\%~n1.mxf
    goto :eof
    :GetTargetName
    	Set "FileName="
    	Set /p FileName=InputFileName.mxf o InputFolder - INVIO per convertire tutto (EXIT esce):
    	rem Add or remove double-quotes if necessary
    	if NOT DEFINED FileName (
    		Set "FileName-DQ="
    		goto :DQSkip
    	Set "FileName-DQ=%FileName:"=%"
    	if NOT DEFINED FileName-DQ (
    		Set "FileName="
    		Set "FileName-DQ="
    		goto :DQSkip
    	if EXIST "%FileName-DQ%" (
    		if "%FileName-DQ%"=="%FileName-DQ: =%" (
    			Set "FileName=%FileName-DQ%"
    		) else (
    			Set FileName="%FileName-DQ%"
    :DQSkip
    	if /I "%FileName-DQ%"=="" Set FileName="%CD%"
    	if /I "%FileName-DQ%"=="CD" Set FileName="%CD%"
    	if /I "%FileName-DQ%"=="EXIT" goto :eof
    	if /I "%FileName-DQ%"=="NOEXIT" goto :GetTargetName
    	if DEFINED FileName (
    		Set /a ARGLVL+=1
    		CALL :ARGS %FileName%
    		Set /a ARGLVL-=1
    goto :GetTargetName
    Please stop with the CAT thread titles. Please describe the problem in the thread title instead.
    Sep 2012
    Australia
    if exist "%~dpn1.wav" (
    set "Audio=%~dpn1.wav"
    ) else (
    set "Audio....
    Can't be bothered finishing. You're not using XP now, so use choice with it's timeout option.
  5. Originally Posted by ndjamena View Post
    ) else (
    set "Audio....
    mm thanks: now I'm in a windows 8.1 s.o. ^^
