  1. Can I put more than one mpeg movie on a SVCD using Nero? Can I just drag multiple movies into the burn window and burn it, will I be able to play each mpeg? I looked around here and couldn't find anything on this topic.
    Thanks for the help. :)
  2. Yes you can only if the files will all fit on one CD.
  3. Yes, Thank you. I tried it out and it worked great. To go to the next mpeg I just press the "next" button on my remote and it starts to play on my JVC XVS65. Now I've got to learn how to do the interactive menus. :) Are there any help files on that subject here??
  4. There is a tremendeous amount of info here, nicely categorized and presented, please have a look at the menu on the left side here and you will be amazed over what you won't have to ask about [wink]
    http://www.vcdhelp.com/burnmpg.htm
    Section:How to make VCD or SVCD with Menus, Chapters and Entrypoints
    HTH
    "The future is no longer what it used to be"
  5. Hey Thanks a bunch. I'm learning lots here. :)
