OSU chemists have found that cellulose the most abundant organic polymer on Earth and a key component of trees can be heated in a furnace in the presence of ammonia, and turned into the building blocks for supercapacitors.
These supercapacitors are extraordinary, high-power energy devices with a wide range of industrial applications, in everything from electronics to automobiles and aviation.
They have found a way to cheaply make nanoporous carbon membranes that are extraordinarily thin a single gram of them can have a surface area of nearly 2,000 square meters. Thats part of what makes them useful in supercapacitors.
Source: http://oregonstate.edu/ua/ncs/archives/2014/apr/trees-go-high-tech-process-turns-cellu...torage-devices
Extraordinary claims require extraordinary evidence -Carl Sagan
What's the life span of these things?
If its bioorganic do they have a lifespan?
Sent from my Nexus 7 using TapatalkDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Since they are made from carbon it should have a long life, but who knows for sure. Other ingredients in those capacitors may have a effect on longevity.
Remember diamonds are carbon and diamonds are forever.
