hi,
playing my mpg-file on windows-media-player is displaying an
upside-down & mirrowed movie.
What' the reason for?
audiocodec = Morgan Stream Switcher
videocodec = Bicubic Video Resizer
fps = unknown
how can I create a svcd with TMPGEnc to view the movie in the right way?
thanx for help,
walter
Have you installed the Nimo codec pak? If so it include DivXG400 and there will be a Tv in the system tray when you play the file. Click on it to open it. In the propeties select the Force vertical flip to correct the orientation.
Originally Posted by cmarcum
If you access your nimo program folder to setup Divx G400 you should find the function that I am talking about.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 11:11 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36
