Hi, I would like to make a quiz DVD with DVD Lab 2.5, but I have never used DVD Lab before.
My mother will have her birthday on Sunday and I would like to make a quiz for her with 30 questions.
I have created the quiz with the assistant in the menu. I have used the instructions from here http://mediachance.com/dvdlab/tutorial/quiz1.pdf but I don't know if I have worked correctly.
If I burn the quiz DVD (30 questions + start monitor + end monitor) in an *.img file, and I start it (I click on the *.vob file) the questions run very quickly through the picture.
I start the img - then comes the first, 2nd.... up to the 30th question and the DVD stops.
- I start the DVD
- Then: Start monitor with the instructions for my mum
- Then CLICK to start the quiz
- question 1 with two buttons "Right" or "Wrong" - if she is "right", then I click on "Right" and the second question will come
- after answering the 30th question there should come an overview with the amount of the right answers (e. g. 10)
What do I have to do to let this work?
I can send you my presentation.
Greetings
Knut
Try burning it to a dvd and playing it on a set-top box. Clicking on vob in an image file is not how DVDs work. What software player are you using?
