Results 1 to 10 of 10
  1. Hi,
    I would like build a batch file that do this:
    it have to recognize if my .avi source (attached) is mjpeg (MJPG) or uncompressed (YUY2) with the ffprobe and
    If is mjpeg --> goto procedure1
    if is UNCOMPRESSED --> goto procedure2
    in another bath ndjamed help me using something like this:
    SetLocal DisableDelayedExpansion
    	rem Find TimeCode Info
    	Set AUCount=0;
    	for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\virtualdubmod\FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_entries stream^=codec_type^,width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version "%~1" 2^>^&1') DO (
    		 if "%%~g"=="TAG:company_name" set "T_Company_Name=%%~h"
    		 if "%%~g"=="TAG:product_name" set "T_Product_Name=%%~h"
    		 if "%%~g"=="TAG:product_version" set "T_Product_Version=%%~h"
    		 if "%%~g"=="TAG:timecode" set "TIMECODE=%%~h"
    		 if "%%~g"=="width" set "V_Width=%%~h"
    		 if "%%~g"=="height" set "V_Height=%%~h"
    		 if "%%~g"=="sample_aspect_ratio" set "V_PAR=%%~h"
    		 if "%%~g"=="codec_type" if "%%~h"=="audio" set /a AUCount+=1
    	if "%V_Width%"=="" (
    		echo  ERROR: Video Width NOT FOUND!
    		pause
    		goto :eof
    	if "%V_Height%"=="" (
    		echo  ERROR: Video Height NOT FOUND!
    		pause
    		goto :eof
    	if "%V_PAR%"=="" (
    		echo  ERROR: Video PAR NOT FOUND!
    		pause
    		goto :eof
    	rem Set "V_Q=UD"
    	rem if %V_Width% LEQ 1920 if %V_Height% LEQ 1120 \\
    	Set "V_Q=HD"
    	rem if %V_Width% LEQ 1280 if %V_Height% LEQ 752 Set "V_Q=MD"
    	if %V_Width% LEQ 1024 if %V_Height% LEQ 608 Set "V_Q=SD"
    	echo  Using %V_Q% Mode
    	echo  PAR = %V_PAR%
    	if "%TimeCode%"=="" echo Warning! no TimeCode Found!
    	if NOT "%TimeCode%"=="" echo Timecode= %TIMECODE%
    if "%V_Q%"=="SD" (CALL :MAKEVCF_SD "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1")
    if "%V_Q%"=="HD" (CALL :MAKEVCF_HD "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1")
    but now, in this batch, I would analize the "vtag"
    How I have to change it to recognize the "vtag" YUY2 or MJPG?
    thanks
  2. an in this another attachment is the .avi in mjpeg
  3. u.avi = uncompressed.avi
    m.avi = mjpeg .avi
    Sep 2012
    Australia
    I'm sure I gave you this before:
    FFProbe -hide_banner -loglevel fatal -pretty -show_streams "%~1" 1>"%~dpn1.txt"
  5. thanks ndjamena, your batch does work perfectly. With yours I'm able to transcode from .mxf into .avi files
    Now I have to do a batch that do from .avi into .mxf (but in hd mode ffmbc won't work :=()
    So I have to recognize if my source is a .avi mjpeg or yuy2, but possibly I don't wont to generate a .txt file. Simply the batch have to analize the .avi and if it is yuy2 have to go into procedure1 (..) and if is mjpeg have to go into procedure2
    u.avi is yuy2
    m.avi is mjpg
    have the batch distinguish it in base the fourcc code? ffprobe have to extract the fourcc
    The new batch should: watch if the input .avi file is internally mjpg or yuy2: if the .avi is not yuy2 or mjpg ---> goto EOF : "error unrecognized input format"
    This is my definitive MXF2AVI.bat (from mxf to avi)
    @rem unless otherwise specified for debugging reasons turn echo off
    @if "%EMode%"=="" Set EMode=ON
    @ECHO %EMode%
    @ECHO off
    xcopy /y V:\automazioneclip\system\morgan\m3jpegHD.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\morgan\m3jpHD.ini c:\windows
    xcopy /y v:\automazioneclip\system\morgan\MMIJG32.dll c:\windows\system32
    xcopy /y V:\automazioneclip\system\morgan\m3jpegSD.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\morgan\m3jpSD.INI c:\windows
    xcopy /y v:\automazioneclip\system\morgan\MMIJG30.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\wavdest.ocx c:\windows\system32
    xcopy /y v:\automazioneclip\system\SamplesDropper.ocx c:\windows\system32
    xcopy /y v:\automazioneclip\system\SP_audio.ocx c:\windows\system32
    xcopy /y v:\automazioneclip\system\dv_grabber.ocx c:\windows\system32
    xcopy /y v:\automazioneclip\system\SP_video.ocx c:\windows\system32
    regsvr32 /s c:\windows\system32\wavdest.ocx
    regsvr32 /s c:\windows\system32\SamplesDropper.ocx
    regsvr32 /s c:\windows\system32\SP_audio.ocx
    regsvr32 /s c:\windows\system32\dv_grabber.ocx
    regsvr32 /s c:\windows\system32\SP_video.ocx
    regedit /s v:\automazioneclip\system\morgan\morganreg.reg
    del v:\automazioneclip\output\temp.avi
    del v:\automazioneclip\output\temp.wav
    cls
    Set "EXTLIST=*.mxf"
    Set "DoPop=0"
    Set "ARGLVL=0"
    Set "FileName-DQ="
    Set VDM_LOC="v:\automazioneclip\VirtualDubMOD\virtualdubmod.exe"
    if not exist v:\automazioneclip\output\progetto1 mkdir v:\automazioneclip\output\progetto1
    set "DestFolder=v:\automazioneclip\output\progetto1"
    Set "WorkFolder=%DestFolder%"
    if not exist %DestFolder% mkdir %DestFolder%
    rem process the arguments one by one
    :ARGS
    	rem if there are no further arguments then exit the batch.
    	if [%1]==[] (
    		if "%ARGLVL%"=="0" (
    			CALL :GetTargetName
    			EndLocal
    			pause
    		goto :eof
    	rem wildcard processing
    	Set "FileName=%~1"
    	if "%FileName%"=="" (
    		SHIFT
    		goto :ARGS
    	rem if the argument doesn't exist in the file system in any form skip it.
    	if NOT EXIST %1 (
    		SHIFT
    		goto :ARGS
    	if NOT [%1]==[] if NOT "%FileName:^*=%%FileName:^?=%"=="%FileName%%FileName%" (
    		for %%w in (%1) DO (
    			Set /a ARGLVL+=1
    			CALL :ARGS "%%~fw"
    			Set /a ARGLVL-=1
    		SHIFT
    		goto :ARGS
    	Set "FileName="
    	rem Set search/recursion variables
    	Set "Pattern=%EXTLIST%"
    	Set "STARTLVL=0"
    	Set "FOUNDLVL=1024"
    	rem if the argument is the current directory then process everything in it.
    	if "%~f1"=="%CD%" (
    		rem echo Processing Directory "%CD%"
    		CALL :START %1
    		SHIFT
    		goto :ARGS
    	rem Test if the argument is a directory, if it is move to it then process everything in it, if not then move to the file's parent directory and process the file.  Then return to starting directory.
    	Type NUL
    	pushd "%~f1" 2> nul
    	if NOT "%errorlevel%"=="0" (
    		if NOT "%CD%\"=="%~dp1" (
    			pushd "%~dp1"
    			Set "DoPop=1"
    		Set Pattern="%~nx1"
    	) else (
    		rem echo Processing Directory "%~f1"
    		Set "DoPop=1"
    	CALL :START %1
    	if "%DoPop%"=="1" (
    		popd
    		Set "DoPop=0"
    	SHIFT
    goto :ARGS
    :START <CURRENT_ARG>
    	rem Count is superseded by FOUNDLVL but may still be useful for renaming purposes
    	Set "Count=0"
    	rem Process all files in the current directory fitting the arguments search pattern.
    	for /f "delims=" %%y in ('dir %Pattern% /b /od /a-d') do (
    		if /I NOT "%%~y"=="File Not Found" CALL :Process_File "%%~fy"
    	rem if it didn't find anything search all directories instead
    goto :eof
    	if "%Count%"=="0" if %STARTLVL% LSS %FOUNDLVL% (
    		for /d %%b in (*) do (
    			pushd "%%~fb"
    			rem echo Processing Directory "%%~fb"
    			Set /a STARTLVL+=1
    			CALL :START "%%~fb"
    			Set /a STARTLVL-=1
    			popd
    goto :eof
    :Process_File <MXF_FILENAME>
    	Set /a Count+=1
    	Set "FOUNDLVL=%STARTLVL%"
    	echo Processing "%CD%\%~nx1"
    	if /I NOT "%~x1"==".mxf" (
    		echo "%~nx1"
    		echo  Is not an mxf file.
    		pause
    		goto :eof
    	if EXIST "%DestFolder%\%~n1.avi" (
    		echo  File già esistente nella directory di destinazione %DestFolder%
    		goto :eof
    	if EXIST "%WorkFolder%\%~n1.avi" (
    		echo  Working File Already Exists...
    		goto :eof
    		pause
    	Set AUCount=0;
    		pause
    		goto :eof
    		pause
    		goto :eof
    	if "%V_PAR%"=="" (
    		pause
    		goto :eof
    	rem Set "V_Q=UD"
    	Set "V_Q=HD"
    	echo  PAR = %V_PAR%
    rem CALL :MAKEVCF "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1"
    	echo  FATTO
    	echo.
    	echo ---------------------------------------------
    	echo.
    	EndLocal
    goto :eof
    :MAKEVCF_HD <VCF_FILENAME> <AVS_FILENAME> <AVI_FILENAME> <MXF_FILENAME>
            v:\automazioneclip\virtualdubmod\ffmpeg.exe -loglevel fatal -y -i "%CD%\%~n1.mxf" -filter_complex "[0:1] [0:2] amerge,volume=3" -c:a pcm_s16le %WorkFolder%\%~n1.wav
            v:\automazioneclip\virtualdubmod\ffmpeg.exe -loglevel fatal -y -i "%CD%\%~n1.mxf" -filter_complex "[0:3] [0:4] amerge,volume=3" -c:a pcm_s16le %WorkFolder%\%~n1ch3ch4.wav
    	rem ***Make The .vcf Script File***
    	echo VirtualDub.RemoveInputStreams^(^)^;>%1
    	echo VirtualDub.video.DeleteComments^(1^)^;>>%1
    	if NOT "%TimeCode%"=="" echo VirtualDub.video.AddComment^(0x0000000C,"","%TIMECODE%"^)^;>>%1
    	echo VirtualDub.video.AdjustChapters^(1^)^;>>%1
    	echo VirtualDub.video.SetDepth^(16,16^)^;>>%1
    	echo VirtualDub.video.SetMode^(1^)^;>>%1
    	echo VirtualDub.video.SetFrameRate^(0,1^)^;>>%1
    	echo VirtualDub.video.SetIVTC^(0,0,-1,0^)^;>>%1
    	echo VirtualDub.video.SetCompression^(0x31626d64,0,10000 ,0^)^;>>%1
    	echo VirtualDub.video.filters.Clear^(^)^;>>%1
    	rem ***Make The .avs AVISynth Script***
    	echo DirectShowSource^(%4^)>%2
    	rem ***Call VirtualDub[Mod]
    	if NOT EXIST %VDM_LOC% (
    		echo  Um, where the hell is VirtualDubMod?
    		pause
    	%VDM_LOC% /s%1 /p%2,%3 /r /x
    	if NOT "%ERRORLEVEL%"=="0" (
    		echo  WARNING!!!  VirtualDubMod Error Detected!!!
    		pause
    	for %%v in (%3) do (
    		if %%~zv LSS 128 (
    			echo  ERROR!!!  Extra Small File Size Detected!!!
    			pause
            v:\automazioneclip\virtualdub\cfourcc.exe -i %3 -u MJPG -d MJPG
    	rem Clean-up
    	DEL %1
    	DEL %2
    goto :eof
    :MAKEVCF_SD <VCF_FILENAME> <AVS_FILENAME> <AVI_FILENAME> <MXF_FILENAME>
            v:\automazioneclip\virtualdubmod\ffmpeg.exe -loglevel fatal -y -i "%CD%\%~n1.mxf" -map_channel 0.1.0 -map_channel 0.1.1 -af "volume=volume=9dB:precision=fixed" %WorkFolder%\%~n1.wav
            v:\automazioneclip\virtualdubmod\ffmpeg.exe -loglevel fatal -y -i "%CD%\%~n1.mxf" -map_channel 0.1.2 -map_channel 0.1.3 -af "volume=volume=9dB:precision=fixed" %WorkFolder%\%~n1ch3ch4.wav
    	echo VirtualDub.video.SetCompression^(0x6a6d7674,0,10000 ,0^)^;>>%1
    	echo VirtualDub.video.SetCompData^(28,"TUpQRxgAAAAAAAAAAgAAAAgAAAACAAAAAQAAAA=="^)^;>>%1
    	echo Crop^(0,32,0,0^)>>%2
    		pause
    		pause
    		if %%~zv LSS 128 (
    			pause
    	rem Clean-up
    	DEL %1
    	DEL %2
    goto :eof
    :GetTargetName
    	Set "FileName="
    	Set /p FileName=InputFileName.mxf o InputFolder - INVIO per convertire tutto (EXIT esce):
    	rem Add or remove double-quotes if necessary
    	if NOT DEFINED FileName (
    		Set "FileName-DQ="
    		goto :DQSkip
    	Set "FileName-DQ=%FileName:"=%"
    	if NOT DEFINED FileName-DQ (
    		Set "FileName="
    		Set "FileName-DQ="
    		goto :DQSkip
    	if EXIST "%FileName-DQ%" (
    		if "%FileName-DQ%"=="%FileName-DQ: =%" (
    			Set "FileName=%FileName-DQ%"
    		) else (
    			Set FileName="%FileName-DQ%"
    :DQSkip
    	if /I "%FileName-DQ%"=="" Set FileName="%CD%"
    	if /I "%FileName-DQ%"=="CD" Set FileName="%CD%"
    	if /I "%FileName-DQ%"=="EXIT" goto :eof
    	if /I "%FileName-DQ%"=="NOEXIT" goto :GetTargetName
    	if DEFINED FileName (
    		Set /a ARGLVL+=1
    		CALL :ARGS %FileName%
    		Set /a ARGLVL-=1
    goto :GetTargetName
    Sep 2012
    Australia
    That command will list all the values FFProbe will put out for a particular file. All you have to do is add whatever value you're interested in to the FFProbe command line in the original script, assign it to a variable then use an if statement on the variable. It's not rocket science.
  7. mmmm now I spoke with my cat, thank you
  8. for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\virtualdubmod\FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_entries stream^=codec_type^,codec_tag_string^,width^,height^,sample_aspect_ratiotream_disposition^=:format_tags^=timecode^,company _name^,product_name^,product_version "%~1" 2^>^&1') DO (
    if "%%~g"=="TAGroduct_name" set "T_Product_Name=%%~h"
    if "%%~g"=="TAGroduct_version" set "T_Product_Version=%%~h"
    if "%%~g"=="codec_tag_string" set "codec_tag_string=%%~h"
  9. mmm my catcClick image for larger version
  10. grr if "%codec_tag_string%"=="YUY2" (CALL : BLACK CATS)
    if "%codec_tag_string%"=="MJPG" (CALL : WHITE BACK CATS)
