Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Jun 2014
    Fermanagh, N.Ireland
    this the simplest project ever, and i have years and years experience in encore,
    one timeline to auto play.
    mpeg file was rendered from vegas 10 pro..
    rendered with dvd architect export settings.
    that is the only difference from what i normally do.
    (i will be using vegas for allot more projects so i need to get dvd's burning quicly and effiecently , to get into a quick workflow.
    in addition i have just installed cs6,
    i have also tried to encode in dvd architect 5.2 ,
    exactly the same problem,
    dvd plays on a pc , with dvd software player installed, no problem,
    its just the standalone dvd players that wont play the disc.
    i have tried everything at this stage,
    could someone please help,
    dec
    Have you changed dvdr/w media?
    And what you do you mean by burned dvd stops? DOes it play but stops after a while on your standalone player? Or does not work at all?
    Jun 2014
    baldrick,
    i havent changed media,
    DOES NOT WORK AT ALL,
    disc rotates,
    waits for approx 1-2 minutes and then stop appears on the screen,
    Are you burning with dvd architect also?
    Does your old burned dvdr media work on your standalone?
    Jun 2014
    i have tryed architect and cs6 encore, just realised i am using rewritables, i will try non rewritables and revert back to u, thanks in advance for the help,
    i do believe i seen a thread somewhere in the past and the changed the action or overide parametres to get encore stopping this problem,
    i now cant find it, again..
    will look at a few things including putting the video file through cs6 premiere, to see if it makes a difference,
    just pressed for dealine at the moment with this project,
    chat soon, dec
    any other ideas welcome
