Hello guys,
N00b needs help please.
I,ve tried several free editors but i cant figure out the best settings with least quality loss.
Last editor I've tried was VSDC Free Video Editor. But my file is 17,1 mbps and the editor only goes up to 10.000 kbps.
I just want to merge several video's i've shot to one playable HD file with some nice transitions and date text stamps.
For real I'm a noob in conversion settings and for all I know VSDC has all I want. But what settings should I use?
And if it doesn't, what (affordable) editor does the trick more than fine?
I use a HD samsung recorder. The outputfile is as following:
Algemeen
Volledige naam : N:\1 - VIDEO\Diverse Video\HDV_1112.MP4
Formaat : MPEG-4
Formaatprofiel : JVT
Codec-ID : avc1
Bestandsgrootte : 97,1 MiB
Duur : 47s 616ms
Totale bitrate : 17,1 Mbps
@sec : UNG
Video
Formaat : AVC
Formaat/Info : Advanced Video Codec
Formaatprofiel : Main@L4.0
Formaatinstellingen, CABAC : Ja
Formaatinstellingen, ReFrames : 4 frames
Format_Settings_GOP : M=3, N=15
Codec-ID : avc1
Codec-ID/Info : Advanced Video Coding
Duur : 47s 320ms
Bitrate-modus : Variabel
Bitrate : 17,1 Mbps
Breedte : 1 920 pixels
Hoogte : 1 080 pixels
Beeldverhouding : 3,161
Originele beeldverhouding : 16:9
Frameratemodus : Constant
Framerate : 25,000 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scansoort : Interlaced
Scanvolgorde : Bovenste Veld Eerst
Bits/(Pixel*Frame) : 0.329
Stroomgrootte : 96,2 MiB (99%)
Titel : SAMSUNG AVC
Taal : Engels
Audio
Formaat : AAC
Formaat/Info : Advanced Audio Codec
Formaatprofiel : LC
Codec-ID : 40
Duur : 47s 616ms
Bitrate-modus : Constant
Bitrate : 128 Kbps
Kanaal(en) : 2 kanalen
Kanaalposities : Front: L R
Samplerate : 48,0 KHz
Stroomgrootte : 744 KiB (1%)
Titel : SAMSUNG AAC
Taal : Engels
Hope somebody can help me out..
You can't get any good result with crappy editors.
Maybe time to find something better like moviestudio pro. You can get it from $40. -
If you're trying to make a DVD, there's a 10Mbs limit. If you're trying to edit and output at the same bitrate, you really want smart rendering which your files probably won't lend themselves to. If you just want a higher bitrate you can go uncompressed. What's so special about 17.1?
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
