Okay, I downloaded a movie file off the net, and I can only see the video.. There is no audio.. When looking at the file properties, it shows the following audio info: Average Date: 24.00 Kb/s
Sampling Rate: 48.00 kHz
Channel: 2 (stereo)
So it appears the video file DOES have audio, it just won't play for some reason.. Is there a codec or something that I need??
Any help would be greatly appreciated.
Thanks!
Well, from right clicking on the file and clicking on properties, here's the info listed there:
Audio
Channel: 2 (stereo)
Also, listed under a different tab, it shows, "Audio format - Unknown format"
Video
Frame width 640 pixels
Frame height 352 pixels
Play length 4505.630 secs
Frame count 23.976 f/s
Date rate 154.377 kb/s
Video sample 24 bit
Video compression DIVXMPG4 V3 -
Originally Posted by mcamp
I'm just guessing here, but you might need the ogg-vorbis codec. Dunno where to get it from the top of my head, but if not here try google -
Well the codec for video is Divx Mpeg 4 V3, its probably not using a standard audio codec, or its a MP3 or AC3Originally Posted by mcamp
Well Load it into vdub 1.49, do a check for bad frames and save out another copy using video and audio streaming, if there is something wrong you should get some indication by now.
If the second save still don't work, then you may have a codec missing from your system that has been used in this file.
Start by installing "Nimo Codec pack" , this contains a lot of audio and video codec's and fixes most problems like this -
Any idea where I can get the Nimo Codec pack??? I did some searches, and all lead to downed sites..
You searched the wrong place then, you should have checked out the tools section on this site
http://users.chartertn.net/bpearson/
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12
