I just started to use videostudio 6 by ulead and every time i capture something even if its 10 seconds the output size comes out 60mb for 10 seconds alone. I lowered the resolution to the smallest possible and its still kinda big and looks horrible unless i bring it up to 352x480. can someone help me out
chronic3010,
You can capture in many different digital video formats depending on what you will be doing with the captured video.
If you're capturing in uncompressed AVI, yes, your captured file size is going to be HUGE and this format is not appropriated for long captures. A 10 second clip with a frame size of 352 x 480 uncompressed AVI, on my machine is 103 mb's. However, capturing directly to MPEG-1, 352 x 240 frame size, @ 2300 kbps, the 10 second clip is 3.3 mb's.
Your post doesn't address what you're going to be doing with the captured video. There are to many options for me to speculate.
Good luck, and if you re-post with a little more detail I can give better specific information as I use VideoStudio 6.0 all the time.
Gary
Ashampoo Burning Studio 9 problems
By Mike_EH in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2010, 20:21 -
DVD STUDIO PRO 4 problems
By macuser1960 in forum MacReplies: 9Last Post: 14th Mar 2009, 05:44 -
Vegas Movie Studio 9 ~~~~ Audio problems
By FaB4FaN in forum EditingReplies: 13Last Post: 4th Mar 2009, 18:19 -
Pinnacle studio 11 capture problems...
By bla4free in forum Capturing and VCRReplies: 0Last Post: 6th Feb 2008, 11:09 -
Pinnacle studio 8 capture problems
By bimfi in forum Capturing and VCRReplies: 1Last Post: 23rd Nov 2007, 16:27
