Results 1 to 16 of 16
  1. I'm a Super Moderator johns0's Avatar
    canada
    I ditched it finally and am using html5 for youtube viewing,also switched to palemoon from firefox.
  2. I never heard of a ABODE flash player.
    Extraordinary claims require extraordinary evidence -Carl Sagan
  3. I'm a Super Moderator johns0's Avatar
    canada
    Corrected title,you do know what i meant.
  4. Originally Posted by johns0 View Post
    Aren't they basically/practically the same under the hood?
    What's the benefit of using Palemoon over Firefox?
    (e.g. Palemoon even accepts every (Firefox) add-on I throw at it, which is more than SeaMonkey does).
  5. DECEASED
    Jun 2009
    Heaven
    The user interface of Pale Moon is better.
    Firefox becomes gayer and gayer each day, whereas Pale Moon at least attempts to remain straight.
    As for Seamonkey, it is THE REAL MOZILLA (interface from Netscape Communicator 4.xx).
  6. DECEASED
    Jun 2009
    Heaven
    Ooops, as for the original question, ......
    I still prefer Flash Player to HTML5 video.
    As for Pale Moon, yes, it's better than the current Firefox, granted,
    but the problem is, none of them are good-enough to non-n00bs like myself
  7. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I still use it. Haven't had any reason to look for an alternative.
    Google is your Friend
  8. I'm a Super Moderator johns0's Avatar
    canada
    The thing i don't like about adobe software is it is bloatware and always wants to do auto updates like holding your hand.
  9. Member p_l's Avatar
    Montreal, Canada
    I also just installed Pale Moon, and so far me likey. Settings transfer tool worked like a charm. Only real discrepancy I see is the search box sets up and defaults to DuckDuckGo, which is not a bad thing.
  10. I'm a Super Moderator johns0's Avatar
    canada
    It's easy enough to set the search bar to what ever provider you want.
  11. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Every once in a while YouTube and other vids start giving me a hard time.....once per year or so. Then I go and update Firefox, then I go and update Adobe. It always takes me forever where to go (in my computer) to update Adobe Flash Player.....I bother with it so little. That's how "Un-Hip" I am I guess. I was never the one to to appear to be Super-Hip to others by denouncing EVERYTHING....Microsoft, Adobe, etc etc etc.
    If the worst problem you have today is that others know you (still) use Microsoft or Adobe Flash Player or....whatever .....you're gonna have a DAMN good day.
  12. Member p_l's Avatar
    Montreal, Canada
    Yes, but this is a great opportunity to give DuckDuckGo a try.
  13. I'm a Super Moderator johns0's Avatar
    canada
    Duckduckgo sucks.
  14. Member p_l's Avatar
    Montreal, Canada
    Because...
  15. I'm a Super Moderator johns0's Avatar
    canada
    By the way it shows the links.Looks crappy.
  16. Many HTML5 supported browsers (Chrome, Firefox, SeaMonkey, IceWeasel, Opera, PaleMoon, and many many...) will play h264, vp9 & WebM (YouTube) videos by default. Where as IE9+ & Safari may require additional plugins.
    No need for Adobe Flash Player anymore. No need for keep updating every time.
    While searching for HTML5 supported browsers, I have came across a few HTML5 stand alone players. But browsers are capable of playing directly.
