Is it possible to take a Blu Ray and create a DVD5 or 9 but also have it include the menus?
There seems to be a bunch of software out there that can shink a Blu ray to a DVD but I'm not sure
it can do it with menus?
I tried DVD Fab Blu Ray cloner, I selected everything and I till end up with a DVD without menus.
So it is possible? if so please recommend which software.
If you mean can you shrink it to fit on a DVD5 or DVD9 sized disc but still in a BD / AVCHD format then...yes
I still have my 1st test of this done when I 1st got my BD drive. I can't recall for sure but I think I used BD Rebuilder or Ripbot264There's not much to do but then I can't do much anyway. -
Or if you mean convert the Blu-ray to DVD-Video format(VIDEO_TS folder with vob files) for standard dvd players. Then nope, no menus.
BD menus are totally different than DVD.
Not at all the same language to build them.Want my help? Ask here! (not via PM!)
It could be possible, but the menus would have to be decoded (to BMP, etc) then re-encoded/converted to DVD menu format. AFAIK, no software currently does this.
Scott -
This is what I mean, I guess there's no way.Or if you mean convert the Blu-ray to DVD-Video format(VIDEO_TS folder with vob files) for standard dvd players. Then nope, no menus.
Thanks for the replies
