Hello everyone.
First, sorry for my bad english !
I want to download video from this url : bongngo.vn (this is a website in Vietnam). I use ffmpeg with command :
When I run, it seems fine, however about 2,3 minutes later, its stopped:Code:ffmpeg -y -i "http://117.103.204.131:1936/bongngovod2c/mp4:./464e590318a54e5da7a3d4123fbba175/53907980/Encoded/Movie/2014/5/30/24177_the-perks-of-being-a-wallflower-2012-1080p-bluray-dts-x264-d_480.mp4/playlist.m3u8?wowzasessionid=1149761109" -bsf:a aac_adtstoasc -c copy output.mp4
It appears "Failed to open segment of playlist 0". I dont know why.Code:E:\TriStore\Winforms\MovieScrapper\MovieScrapper\bin\Debug>ffmpeg -y -i "http:// 117.103.204.131:1936/bongngovod2c/mp4:./464e590318a54e5da7a3d4123fbba175/5390798 0/Encoded/Movie/2014/5/30/24177_the-perks-of-being-a-wallflower-2012-1080p-blura y-dts-x264-d_480.mp4/playlist.m3u8?wowzasessionid=1149761109" -bsf:a aac_adtstoa sc -c copy output.mp4 ffmpeg version N-63623-g2e532aa Copyright (c) 2000-2014 the FFmpeg developers built on May 30 2014 22:01:51 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp e --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable- libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libope njpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsox r --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab - -enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable- libxavs --enable-libxvid --enable-decklink --enable-zlib libavutil 52. 87.100 / 52. 87.100 libavcodec 55. 65.100 / 55. 65.100 libavformat 55. 42.100 / 55. 42.100 libavdevice 55. 13.101 / 55. 13.101 libavfilter 4. 5.100 / 4. 5.100 libswscale 2. 6.100 / 2. 6.100 libswresample 0. 19.100 / 0. 19.100 libpostproc 52. 3.100 / 52. 3.100 Input #0, hls,applehttp, from 'http://117.103.204.131:1936/bongngovod2c/mp4:./46 4e590318a54e5da7a3d4123fbba175/53907980/Encoded/Movie/2014/5/30/24177_the-perks- of-being-a-wallflower-2012-1080p-bluray-dts-x264-d_480.mp4/playlist.m3u8?wowzase ssionid=1149761109': Duration: 01:42:41.00, start: 0.000000, bitrate: 0 kb/s Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 854x480 [ SAR 1280:1281 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 13 0 kb/s Output #0, mp4, to 'output.mp4': Metadata: encoder : Lavf55.42.100 Stream #0:0: Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 854x480 [SAR 128 0:1281 DAR 16:9], q=2-31, 23.98 fps, 90k tbn, 90k tbc Stream #0:1: Audio: aac ([64][0][0][0] / 0x0040), 48000 Hz, stereo, 130 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help frame= 75 fps= 42 q=-1.0 size= 52kB time=00:00:03.11 bitrate= 137.8kbits/ frame= 115 fps= 43 q=-1.0 size= 167kB time=00:00:04.75 bitrate= 287.2kbits/ frame= 124 fps= 39 q=-1.0 size= 232kB time=00:00:05.14 bitrate= 370.0kbits/ frame= 130 fps= 35 q=-1.0 size= 295kB time=00:00:05.41 bitrate= 445.9kbits/ frame= 141 fps= 33 q=-1.0 size= 419kB time=00:00:05.86 bitrate= 584.5kbits/ frame= 150 fps= 31 q=-1.0 size= 528kB time=00:00:06.22 bitrate= 694.2kbits/ frame= 150 fps= 26 q=-1.0 size= 539kB time=00:00:06.25 bitrate= 706.2kbits/ frame= 154 fps= 24 q=-1.0 size= 606kB time=00:00:06.44 bitrate= 770.2kbits/ frame= 158 fps= 22 q=-1.0 size= 671kB time=00:00:06.56 bitrate= 836.7kbits/ frame= 167 fps= 22 q=-1.0 size= 820kB time=00:00:06.95 bitrate= 966.5kbits/ frame= 188 fps= 22 q=-1.0 size= 1362kB time=00:00:07.84 bitrate=1421.5kbits/ frame= 190 fps= 21 q=-1.0 size= 1412kB time=00:00:07.89 bitrate=1465.3kbits/ frame= 193 fps= 20 q=-1.0 size= 1527kB time=00:00:08.02 bitrate=1559.4kbits/ frame= 204 fps= 20 q=-1.0 size= 1722kB time=00:00:08.51 bitrate=1657.0kbits/ frame= 224 fps= 19 q=-1.0 size= 1836kB time=00:00:09.32 bitrate=1613.6kbits/ frame= 248 fps= 20 q=-1.0 size= 1987kB time=00:00:10.34 bitrate=1573.0kbits/ frame= 260 fps= 20 q=-1.0 size= 2045kB time=00:00:10.85 bitrate=1543.2kbits/ frame= 342 fps= 25 q=-1.0 size= 2328kB time=00:00:14.25 bitrate=1338.2kbits/ frame= 397 fps= 23 q=-1.0 size= 2409kB time=00:00:16.55 bitrate=1192.2kbits/ frame= 527 fps= 29 q=-1.0 size= 2591kB time=00:00:21.97 bitrate= 965.8kbits/ frame= 602 fps= 32 q=-1.0 size= 2652kB time=00:00:25.10 bitrate= 865.1kbits/ frame= 647 fps= 34 q=-1.0 size= 2689kB time=00:00:26.96 bitrate= 817.0kbits/ frame= 752 fps= 37 q=-1.0 size= 2774kB time=00:00:31.35 bitrate= 724.8kbits/ frame= 827 fps= 35 q=-1.0 size= 2840kB time=00:00:34.47 bitrate= 674.9kbits/ frame= 902 fps= 37 q=-1.0 size= 2922kB time=00:00:37.61 bitrate= 636.4kbits/ frame= 951 fps= 38 q=-1.0 size= 3376kB time=00:00:39.65 bitrate= 697.4kbits/ frame= 957 fps= 37 q=-1.0 size= 3983kB time=00:00:39.91 bitrate= 817.4kbits/ frame= 963 fps= 37 q=-1.0 size= 4598kB time=00:00:40.17 bitrate= 937.7kbits/ frame= 968 fps= 36 q=-1.0 size= 4818kB time=00:00:40.36 bitrate= 977.9kbits/ frame= 1013 fps= 37 q=-1.0 size= 5413kB time=00:00:42.21 bitrate=1050.3kbits/ frame= 1045 fps= 37 q=-1.0 size= 5651kB time=00:00:43.58 bitrate=1062.1kbits/ frame= 1047 fps= 37 q=-1.0 size= 5665kB time=00:00:43.66 bitrate=1062.7kbits/ frame= 1073 fps= 36 q=-1.0 size= 5883kB time=00:00:44.75 bitrate=1076.7kbits/ frame= 1111 fps= 37 q=-1.0 size= 6117kB time=00:00:46.33 bitrate=1081.5kbits/ frame= 1183 fps= 38 q=-1.0 size= 6502kB time=00:00:49.32 bitrate=1079.9kbits/ frame= 1270 fps= 40 q=-1.0 size= 6875kB time=00:00:52.96 bitrate=1063.3kbits/ frame= 1284 fps= 40 q=-1.0 size= 6934kB time=00:00:53.54 bitrate=1060.8kbits/ frame= 1333 fps= 40 q=-1.0 size= 7153kB time=00:00:55.59 bitrate=1054.0kbits/ frame= 1376 fps= 40 q=-1.0 size= 7327kB time=00:00:57.38 bitrate=1045.9kbits/ frame= 1408 fps= 40 q=-1.0 size= 7444kB time=00:00:58.70 bitrate=1038.7kbits/ frame= 1452 fps= 41 q=-1.0 size= 7740kB time=00:01:00.56 bitrate=1047.0kbits/ frame= 1483 fps= 41 q=-1.0 size= 7999kB time=00:01:01.84 bitrate=1059.5kbits/ frame= 1558 fps= 42 q=-1.0 size= 8538kB time=00:01:04.98 bitrate=1076.3kbits/ frame= 1633 fps= 43 q=-1.0 size= 9018kB time=00:01:08.11 bitrate=1084.5kbits/ frame= 1676 fps= 44 q=-1.0 size= 9274kB time=00:01:09.88 bitrate=1087.1kbits/ frame= 1708 fps= 43 q=-1.0 size= 9436kB time=00:01:11.23 bitrate=1085.2kbits/ frame= 1782 fps= 44 q=-1.0 size= 9787kB time=00:01:14.32 bitrate=1078.7kbits/ frame= 1863 fps= 45 q=-1.0 size= 10121kB time=00:01:17.69 bitrate=1067.1kbits/ frame= 1877 fps= 45 q=-1.0 size= 10196kB time=00:01:18.27 bitrate=1067.1kbits/ frame= 1912 fps= 45 q=-1.0 size= 10342kB time=00:01:19.72 bitrate=1062.7kbits/ frame= 1937 fps= 45 q=-1.0 size= 10451kB time=00:01:20.78 bitrate=1059.7kbits/ frame= 1971 fps= 45 q=-1.0 size= 10594kB time=00:01:22.19 bitrate=1055.9kbits/ frame= 2014 fps= 45 q=-1.0 size= 10791kB time=00:01:24.01 bitrate=1052.2kbits/ frame= 2056 fps= 46 q=-1.0 size= 10967kB time=00:01:25.75 bitrate=1047.6kbits/ frame= 2116 fps= 46 q=-1.0 size= 11197kB time=00:01:28.21 bitrate=1039.8kbits/ frame= 2131 fps= 45 q=-1.0 size= 11288kB time=00:01:28.87 bitrate=1040.5kbits/ frame= 2142 fps= 45 q=-1.0 size= 11347kB time=00:01:29.32 bitrate=1040.7kbits/ frame= 2165 fps= 45 q=-1.0 size= 11469kB time=00:01:30.28 bitrate=1040.7kbits/ frame= 2190 fps= 45 q=-1.0 size= 11589kB time=00:01:31.32 bitrate=1039.5kbits/ frame= 2214 fps= 44 q=-1.0 size= 11704kB time=00:01:32.35 bitrate=1038.2kbits/ frame= 2256 fps= 45 q=-1.0 size= 11815kB time=00:01:34.05 bitrate=1029.0kbits/ frame= 2278 fps= 44 q=-1.0 size= 11862kB time=00:01:34.99 bitrate=1023.0kbits/ frame= 2342 fps= 45 q=-1.0 size= 11974kB time=00:01:37.70 bitrate=1003.9kbits/ frame= 2353 fps= 45 q=-1.0 size= 11989kB time=00:01:38.13 bitrate=1000.8kbits/ frame= 2389 fps= 45 q=-1.0 size= 12036kB time=00:01:39.64 bitrate= 989.5kbits/ frame= 2463 fps= 46 q=-1.0 size= 12145kB time=00:01:42.71 bitrate= 968.6kbits/ frame= 2566 fps= 45 q=-1.0 size= 12271kB time=00:01:47.00 bitrate= 939.4kbits/ frame= 2640 fps= 45 q=-1.0 size= 12355kB time=00:01:50.10 bitrate= 919.2kbits/ frame= 2682 fps= 45 q=-1.0 size= 12389kB time=00:01:51.85 bitrate= 907.4kbits/ frame= 2740 fps= 46 q=-1.0 size= 12453kB time=00:01:54.30 bitrate= 892.5kbits/ frame= 2806 fps= 46 q=-1.0 size= 12554kB time=00:01:57.03 bitrate= 878.7kbits/ frame= 2818 fps= 46 q=-1.0 size= 12579kB time=00:01:57.52 bitrate= 876.8kbits/ frame= 2848 fps= 46 q=-1.0 size= 12636kB time=00:01:58.80 bitrate= 871.3kbits/ frame= 2892 fps= 46 q=-1.0 size= 12710kB time=00:02:00.61 bitrate= 863.2kbits/ frame= 2910 fps= 46 q=-1.0 size= 12767kB time=00:02:01.42 bitrate= 861.3kbits/ frame= 2938 fps= 46 q=-1.0 size= 12827kB time=00:02:02.51 bitrate= 857.7kbits/ frame= 2966 fps= 46 q=-1.0 size= 12900kB time=00:02:03.69 bitrate= 854.4kbits/ frame= 2990 fps= 46 q=-1.0 size= 12962kB time=00:02:04.71 bitrate= 851.4kbits/ frame= 3057 fps= 46 q=-1.0 size= 13138kB time=00:02:07.50 bitrate= 844.1kbits/ frame= 3115 fps= 46 q=-1.0 size= 13319kB time=00:02:09.91 bitrate= 839.8kbits/ frame= 3146 fps= 46 q=-1.0 size= 13442kB time=00:02:11.19 bitrate= 839.3kbits/ frame= 3175 fps= 46 q=-1.0 size= 13540kB time=00:02:12.39 bitrate= 837.8kbits/ frame= 3190 fps= 46 q=-1.0 size= 13591kB time=00:02:13.03 bitrate= 836.9kbits/ frame= 3236 fps= 46 q=-1.0 size= 13758kB time=00:02:14.95 bitrate= 835.1kbits/ frame= 3306 fps= 46 q=-1.0 size= 14003kB time=00:02:17.89 bitrate= 831.9kbits/ frame= 3331 fps= 47 q=-1.0 size= 14092kB time=00:02:18.92 bitrate= 831.0kbits/ frame= 3385 fps= 47 q=-1.0 size= 14299kB time=00:02:21.18 bitrate= 829.7kbits/ frame= 3391 fps= 47 q=-1.0 size= 14317kB time=00:02:21.43 bitrate= 829.2kbits/ frame= 3431 fps= 47 q=-1.0 size= 14494kB time=00:02:23.10 bitrate= 829.7kbits/ frame= 3481 fps= 47 q=-1.0 size= 14695kB time=00:02:25.17 bitrate= 829.2kbits/ frame= 3524 fps= 47 q=-1.0 size= 14870kB time=00:02:26.96 bitrate= 828.8kbits/ frame= 3556 fps= 47 q=-1.0 size= 14968kB time=00:02:28.30 bitrate= 826.8kbits/ frame= 3603 fps= 46 q=-1.0 size= 15166kB time=00:02:30.27 bitrate= 826.7kbits/ frame= 3615 fps= 45 q=-1.0 size= 15250kB time=00:02:30.78 bitrate= 828.5kbits/ frame= 3624 fps= 45 q=-1.0 size= 15304kB time=00:02:31.18 bitrate= 829.2kbits/ frame= 3635 fps= 45 q=-1.0 size= 15363kB time=00:02:31.61 bitrate= 830.1kbits/ frame= 3639 fps= 45 q=-1.0 size= 15390kB time=00:02:31.76 bitrate= 830.7kbits/ frame= 3675 fps= 43 q=-1.0 size= 15575kB time=00:02:33.25 bitrate= 832.5kbits/ frame= 3718 fps= 43 q=-1.0 size= 15748kB time=00:02:35.07 bitrate= 831.9kbits/ frame= 3730 fps= 43 q=-1.0 size= 15809kB time=00:02:35.56 bitrate= 832.5kbits/ frame= 3750 fps= 41 q=-1.0 size= 15904kB time=00:02:36.39 bitrate= 833.1kbits/ frame= 3788 fps= 42 q=-1.0 size= 16066kB time=00:02:37.97 bitrate= 833.1kbits/ frame= 3847 fps= 42 q=-1.0 size= 16293kB time=00:02:40.49 bitrate= 831.7kbits/ frame= 3863 fps= 40 q=-1.0 size= 16354kB time=00:02:41.10 bitrate= 831.6kbits/ frame= 3920 fps= 41 q=-1.0 size= 16589kB time=00:02:43.45 bitrate= 831.4kbits/ frame= 3938 fps= 38 q=-1.0 size= 16668kB time=00:02:44.24 bitrate= 831.4kbits/ frame= 3964 fps= 38 q=-1.0 size= 16790kB time=00:02:45.33 bitrate= 831.9kbits/ frame= 3978 fps= 38 q=-1.0 size= 16847kB time=00:02:45.93 bitrate= 831.7kbits/ frame= 3988 fps= 38 q=-1.0 size= 16892kB time=00:02:46.31 bitrate= 832.0kbits/ frame= 3997 fps= 38 q=-1.0 size= 17040kB time=00:02:46.69 bitrate= 837.4kbits/ frame= 4012 fps= 38 q=-1.0 size= 17220kB time=00:02:47.33 bitrate= 843.0kbits/ frame= 4023 fps= 38 q=-1.0 size= 17343kB time=00:02:47.78 bitrate= 846.8kbits/ frame= 4062 fps= 37 q=-1.0 size= 17754kB time=00:02:49.40 bitrate= 858.5kbits/ frame= 4077 fps= 37 q=-1.0 size= 17936kB time=00:02:50.04 bitrate= 864.1kbits/ frame= 4117 fps= 37 q=-1.0 size= 18298kB time=00:02:51.71 bitrate= 872.9kbits/ frame= 4132 fps= 37 q=-1.0 size= 18435kB time=00:02:52.35 bitrate= 876.2kbits/ frame= 4136 fps= 37 q=-1.0 size= 18470kB time=00:02:52.50 bitrate= 877.1kbits/ frame= 4148 fps= 37 q=-1.0 size= 18588kB time=00:02:53.01 bitrate= 880.1kbits/ frame= 4156 fps= 37 q=-1.0 size= 18653kB time=00:02:53.33 bitrate= 881.6kbits/ frame= 4165 fps= 37 q=-1.0 size= 18717kB time=00:02:53.73 bitrate= 882.5kbits/ frame= 4179 fps= 37 q=-1.0 size= 18812kB time=00:02:54.29 bitrate= 884.2kbits/ frame= 4200 fps= 37 q=-1.0 size= 18943kB time=00:02:55.18 bitrate= 885.8kbits/ frame= 4210 fps= 36 q=-1.0 size= 19011kB time=00:02:55.57 bitrate= 887.0kbits/ frame= 4228 fps= 36 q=-1.0 size= 19132kB time=00:02:56.31 bitrate= 888.9kbits/ frame= 4237 fps= 36 q=-1.0 size= 19196kB time=00:02:56.72 bitrate= 889.8kbits/ frame= 4251 fps= 36 q=-1.0 size= 19256kB time=00:02:57.30 bitrate= 889.7kbits/ frame= 4269 fps= 36 q=-1.0 size= 19375kB time=00:02:58.06 bitrate= 891.3kbits/ frame= 4277 fps= 36 q=-1.0 size= 19436kB time=00:02:58.41 bitrate= 892.4kbits/ frame= 4286 fps= 35 q=-1.0 size= 19503kB time=00:02:58.77 bitrate= 893.7kbits/ frame= 4295 fps= 35 q=-1.0 size= 19564kB time=00:02:59.15 bitrate= 894.6kbits/ frame= 4305 fps= 35 q=-1.0 size= 19623kB time=00:02:59.54 bitrate= 895.3kbits/ frame= 4307 fps= 34 q=-1.0 size= 19634kB time=00:02:59.62 bitrate= 895.4kbits/ frame= 4348 fps= 34 q=-1.0 size= 19813kB time=00:03:01.35 bitrate= 895.0kbits/ frame= 4373 fps= 34 q=-1.0 size= 19931kB time=00:03:02.39 bitrate= 895.2kbits/ frame= 4434 fps= 35 q=-1.0 size= 20171kB time=00:03:04.91 bitrate= 893.6kbits/ frame= 4455 fps= 35 q=-1.0 size= 20292kB time=00:03:05.81 bitrate= 894.6kbits/ frame= 4494 fps= 35 q=-1.0 size= 20534kB time=00:03:07.43 bitrate= 897.4kbits/ frame= 4557 fps= 35 q=-1.0 size= 20915kB time=00:03:10.05 bitrate= 901.5kbits/ frame= 4581 fps= 35 q=-1.0 size= 21027kB time=00:03:11.10 bitrate= 901.3kbits/ frame= 4594 fps= 35 q=-1.0 size= 21094kB time=00:03:11.57 bitrate= 902.0kbits/ frame= 4628 fps= 35 q=-1.0 size= 21285kB time=00:03:13.02 bitrate= 903.3kbits/ frame= 4688 fps= 34 q=-1.0 size= 21471kB time=00:03:15.51 bitrate= 899.6kbits/ frame= 4720 fps= 34 q=-1.0 size= 21589kB time=00:03:16.86 bitrate= 898.4kbits/ frame= 4752 fps= 34 q=-1.0 size= 21707kB time=00:03:18.20 bitrate= 897.2kbits/ frame= 4763 fps= 34 q=-1.0 size= 21751kB time=00:03:18.65 bitrate= 896.9kbits/ frame= 4774 fps= 34 q=-1.0 size= 21807kB time=00:03:19.10 bitrate= 897.2kbits/ frame= 4792 fps= 34 q=-1.0 size= 21870kB time=00:03:19.87 bitrate= 896.4kbits/ frame= 4809 fps= 34 q=-1.0 size= 21928kB time=00:03:20.55 bitrate= 895.7kbits/ frame= 4826 fps= 33 q=-1.0 size= 21991kB time=00:03:21.25 bitrate= 895.1kbits/ frame= 4838 fps= 33 q=-1.0 size= 22037kB time=00:03:21.77 bitrate= 894.7kbits/ frame= 4867 fps= 33 q=-1.0 size= 22154kB time=00:03:22.96 bitrate= 894.2kbits/ frame= 4890 fps= 33 q=-1.0 size= 22235kB time=00:03:23.94 bitrate= 893.1kbits/ frame= 4908 fps= 33 q=-1.0 size= 22297kB time=00:03:24.71 bitrate= 892.3kbits/ [hls,applehttp @ 036209e0] Failed to open segment of playlist 0 http://117.103.204.131:1936/bongngovod2c/mp4:./464e590318a54e5da7a3d4123fbba175/ 53907980/Encoded/Movie/2014/5/30/24177_the-perks-of-being-a-wallflower-2012-1080 p-bluray-dts-x264-d_480.mp4/playlist.m3u8?wowzasessionid=1149761109: Input/outpu t error frame= 4913 fps= 32 q=-1.0 size= 22314kB time=00:03:24.88 bitrate= 892.2kbits/ frame= 4913 fps= 32 q=-1.0 Lsize= 22502kB time=00:03:24.88 bitrate= 899.7kbits /s video:19114kB audio:3202kB subtitle:0kB other streams:0kB global headers:0kB mux ing overhead: 0.833847% E:\TriStore\Winforms\MovieScrapper\MovieScrapper\bin\Debug>pause Press any key to continue . . .
Hope your help, thank you !
Results 1 to 1 of 1
