Closed Thread
    May 2014
    Hello this is my first time trying to create a DVD using AVStoDVD, but I keep getting this error. If I select yes, the audio is out of sync by several seconds, and if I select no there is no audio at all. I'm just wondering what the issue is and how to fix it?
    Here is the message:
    WARNING! Errors found during Title 1 Audio Track 1 encoding. Audio Channels are incorrect (6 vs 2)
    Do you want to start Backup Audio encoding routine (FFmpeg Safe Mode)? Default 'Yes'
    Here is the log:
    <5/29/2014 6:43:26 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 1
    DVD Size: 6728/8100 MB (83%)
    DVD Output Setup: ISO UDF Image
    DVD Label: Frozen
    DVD Menu: No Menu
    Output Folder: E:\Videos
    Delete Temp Assets Files: Yes
    Delete Temp Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    MultiThread: 1
    AVS Video Source Filter: A2DSource
    AVS Audio Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
    Frame Adjust Strategy: 1
    PAL SpeedUp: 0
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 6500
    Video Profile Level 2: 4500
    Video BitRate Max: 9000
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Audio Language (Primary): EN - English
    DVD Audio Language (Secondary): EN - English
    DVD Subs Language (Primary): EN - English
    DVD Subs Language (Secondary): EN - English
    DVD Subs Font: Tahoma 16pt (255,255,255)
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: D: ASUS DRW-24B1ST c 1.05
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Unload ActiveMovie library: 0
    Adjust ffdshow at runtime: 1
    Save General Settings: 1
    TITLE 1 SOURCE FILES
    Video: E:\Torrents\Frozen (2013) [1080p]\Frozen.2013.1080p.BluRay.x264.YIFY.mp4
    Info: AVC - 2193 kbps - 1920x856 - DAR 2.243 - 23.976 fps (CFR) - Progressive - 1:42:13 hours - 147045 frames
    Audio 1: E:\Torrents\Frozen (2013) [1080p]\Frozen.2013.1080p.BluRay.x264.YIFY.mp4
    Info: AAC LC - 93 kbps - VBR - 2 ch - 48000 Hz - 1:42:13 hours (0 ms delay) - EN
    [MediaInfoLib - v0.7.61]
    AVISYNTH SCRIPT
    Import("E:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("E:\Torrents\Frozen (2013) [1080p]\Frozen.2013.1080p.BluRay.x264.YIFY.mp4", CacheFolder="F:\TEMP", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("E:\Torrents\Frozen (2013) [1080p]\Frozen.2013.1080p.BluRay.x264.YIFY.mp4", CacheFolder="F:\TEMP")
    Video = Video.ConvertToYV12()
    Video = Video.AddBorders(0,110,0,112)
    Video = Video.Spline16Resize(720,480)
    #Using DGPulldown/HCenc to upsize FPS
    AudioDub(Video, Audio)
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: FFmpeg CBR 1-pass
    Target Video FileSize: 6439.6 MB
    Encoding Parameters: -i "F:\TEMP\Frozen_0_Frozen_1.avs" -threads 4 -aspect 16:9 -c:v mpeg2video -b:v 8808k -minrate 8808k -maxrate 8808k -bufsize 2000k -dc 10 -y "E:\Videos\Frozen_0_Frozen.m2v"
    <5/29/2014 7:11:31 PM>
    END VIDEO ENCODING OPERATIONS
    Video Source Filter: A2DSource (DirectShowSource)
    Created File: E:\Videos\Frozen_0_Frozen.m2v (6439.7 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 8808 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:42:06 hours - 146900 frames
    START PULLDOWN OPERATIONS
    DGPulldown Parameters: "E:\Videos\Frozen_0_Frozen.m2v" -srcfps 23.976 -destfps 29.97 -inplace -tff
    <5/29/2014 7:13:03 PM>
    END PULLDOWN OPERATIONS
    DGPulldown executed on File: E:\Videos\Frozen_0_Frozen.m2v (6439.7 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 8808 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:42:13 hours - 147046 frames
    START AUDIO ENCODING OPERATIONS (Track 1)
    Wavi+Aften Parameters: "F:\TEMP\Frozen_0_Frozen_1.avs" - | "E:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "E:\Videos\Frozen_0_Frozen_1.ac3"
    <5/29/2014 7:13:39 PM>
    Backup Audio encoding routine (FFmpeg Safe Mode) is starting ...
    START FFMPEG (SAFE MODE) AUDIO ENCODING OPERATIONS (Track 1) - Trial 1/2
    FFmpeg Parameters: -threads 4 -i "E:\Torrents\Frozen (2013) [1080p]\Frozen.2013.1080p.BluRay.x264.YIFY.mp4" -map 0:1 -y -vn -acodec ac3 -ar 48000 -ab 192k "E:\Videos\Frozen_0_Frozen_1.ac3"
    <5/29/2014 7:14:06 PM>
    END AUDIO ENCODING OPERATIONS (Track 1)
    Audio Source Filter: A2DSource (DirectShowSource)
    Created File: E:\Videos\Frozen_0_Frozen_1.ac3 (140.4 MB)
    OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:42:13 hours (0 ms delay)
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "F:\TEMP\Frozen_0_BatchMux.ini"
    BatchMux ini file:
    -d "E:\Videos\Frozen_0\VIDEO_TS"
    -mxp "F:\TEMP\Frozen_0_MuxMan.mxp"
    -l "F:\TEMP\Frozen_0_MuxMan.log"
    -muxman "E:\Program Files\AVStoDVD\MuxMan"
    -prio ABOVENORMAL
    -palette "F:\TEMP\Frozen_0_Palette.txt"
    -v "E:\Videos\Frozen_0_Frozen.m2v"
    -vidmode LB
    -a1 "E:\Videos\Frozen_0_Frozen_1.ac3"
    -a1lang en
    -cellfr "E:\Videos\Frozen_0_Frozen_Chapters.txt"
    -progfr "E:\Videos\Frozen_0_Frozen_Chapters.txt"
    -chapfr "E:\Videos\Frozen_0_Frozen_Chapters.txt"
    <5/29/2014 7:16:28 PM>
    END DVD AUTHORING OPERATIONS
    Created Folder: E:\Videos\Frozen_0 (6700 MB)
    CHECK DVD SIZE
    DVD Folder (actual) Size: 6700 MB
    vs Estimated Size: 6728 MB -> 0.4% undersize
    vs Assets Size: 6580 MB -> Warning!
    <5/29/2014 7:16:29 PM>
    START ISO IMAGE BUILDING OPERATIONS
    ImgBurn (ISO) Parameters: /mode isobuild /buildmode imagefile /src "E:\Videos\Frozen_0\VIDEO_TS" /dest "E:\Videos\Frozen_0.iso" /volumelabel "Frozen" /overwrite yes /noimagedetails /start /close
    <5/29/2014 7:17:31 PM>
    Process aborted during ISO Image building operations.
    <5/29/2014 7:17:34 PM>
    Log file created by AVStoDVD Release 2.7.3
    Just buy Frozen on dvd instead of downloading warez. See our rules https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
