I am trying to rip episodes off a dvd and convert to vcd. I can not figure out how to do it. There are eight episodes on the dvd and eight vob files. But, each vob file is not a episode. My question is is it possible to rip each separate episode from the dvd. If so how? I have tried Smart Ripper, Vstrip, and Decess. Thanks for your help.
I dont know if you can rip each ep.
What you can do is rip your VOB's. Use DVD2AVI to make file for TMPG.
Then when you goto encode it use the source range option to have it encode just each ep at a time. Then save it and run a batch encode.
-Hope this helps
You should try to rip the chapters from the disc. Firstly check in your DVD player to see which chapters refer to each episode and then just rip those specific chapters into seperate folders on your hard drive.
you can rip the episodes useing smartripper .. under the section where it says Title -> Program Chain -> Angle look for the epsiode's rough run time ie: 28mins then just click in each file in there thats around 28mins long some may be 24mins some 26 they vary and just rip each one ..
in smartripper select the option to split .vob by chapter & rip the entire disc
Yeah, forgot to say to split the .vob files into chapter as you rip a DVD. It's what I do all the time, although it does mean maybe 25 .vob files to encode rather than 4, but it allows for more flexibility.
Well, thanks for all the help but I am still having a bit of trouble. I downloaded Smart Ripper from this site because I misplaced my original copy and it does not work. I tried one of the suggestions and looked for each chapter but there were 11 listed and only 8 episodes. I click and start and I get a program error. I am running Windows 2000 and updated my aspe layer. I
Multiple Drives to Rip DVDs
By Levis in forum DVD RippingReplies: 0Last Post: 24th Aug 2011, 16:51 -
Best way to rip and encode TV episodes to DVD?
By MackSwagga in forum DVD RippingReplies: 8Last Post: 28th Mar 2011, 20:16 -
How to 'Ripit' to XVID with multiple Episodes
By DarkPhoenix77 in forum MacReplies: 4Last Post: 19th Sep 2009, 22:35 -
Multiple episodes in one vts
By c9806961 in forum DVD RippingReplies: 12Last Post: 15th Aug 2009, 02:35 -
Re: Multiple TV episodes, only decoding the first one
By Franknstein in forum ffmpegX general discussionReplies: 2Last Post: 10th Apr 2008, 23:46
