When i try to join two avi files this error pops up"Cannot append segment:The video streams have different sampling rates [29.97027 vs 29.97028]".Can this problem get fix?If yes how?
I'd like to know this as well, though my rates are given as 23966.00000 and 23960.00000.
If you are talking about appending AVI segments in Virtual Dub, it's mighty picky about the frame rates being identical (it seems to want them exactly identical). I have rarely had luck getting 2 AVIs to join that were not originally connected.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
You could try changing the frame rate on both clips to the same value in vdub, then try joining them again, but no guarantees.
Whoops... mine was audio. How would i convert one of the files to have an audio rate of the other one? Can I do that through VirtualDub?
And, if it helps, the audio is in MP3.
Premiere Pro 'Error Compiling Movie - Unknown error'
By koberulz in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2012, 16:43 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 10:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
