I don't know the technicalities of how DVD ripping software actually works, but what I have is a VIDEO_TS folder with all the necessary VOB, BUP and INI files but when I try to "play" it it goes right to the main feature and wont let me access the menu or navigation. I tried using ImgBurn to create an ISO - hoping somehow that would fix it, to no avail.
It's been years ago, but I remember once just using "copy" to copy the files from a decrypted, burned DVD to my HD and learning that this didn't work. There seems to be something about using the proper ripping software to make sure the resulting folder maintains all the proper navigation info.
I've been told by a reliable source that as long as I do in fact have all the original files that they can be "remuxed", but this person did not know exactly how to do that so I thought I'd ask here.
Thanks,
mugz
Results 1 to 14 of 14
"Remux" (re-multiplex) is the wrong term here.
Muxing has nothing to do with your error.Want my help? Ask here! (not via PM!)
I'm not sure that you can because I think you actually do NOT "in fact have all the original files". If you did truly have them all, you probably wouldn't be seeing what you are seeing.
If the menu stuff actually exists but something weird happened to make it go to the movie automatically, it might be possible to fix it with PgcEdit. I said MIGHT. I don't personally know what exactly you'd have to do, but that might be tool for the job. -
Ok, I've discovered that if I simply double-click on VIDEO_TS.IFO MPC-HC opens the DVD normally, the menu's come up, they work fine - I can select trailers, extras, chapters - the whole works, it works perfectly! But when I use imgburn to create an ISO - and burn it to a DVD -or- I tried Ashampoo to burn a disk using the folder itself as my souce - again I get a DVD that wont display the menu and just plays the main feature - if I press "menu" it just goes back to the beginning of the feature.
So, it does appear everything is there and working properly - i just have to double click the VIDEO_TS.IFO.. :/ Seems like there should be some simple fix for thls... -
There probably is ... if you know a little about PGCEdit. Run the Trace and change where it goes to where it should go.
How did you decrypt the DVD in the first place? Doing the whole DVD using DVDFab HD Decrypter (or using File Mode in DVD Decrypter if it doesn't have advanced copy protection) should get it to the hard drive correctly.
By the way, it's just an extra and unnecessary step to create an ISO for burning. ImgBurn will happily burn the VIDEO_TS folder. -
Thanks, I'll see if I can figure it out.
I didn't do it, my son made the backup a few years ago and now the DVD is lost.How did you decrypt the DVD in the first place? Doing the whole DVD using DVDFab HD Decrypter (or using File Mode in DVD Decrypter if it doesn't have advanced copy protection) should get it to the hard drive correctly.
I have no idea what he used or how he did it.
Ya, I was just trying different tools, on occasion I've found programs like this have "built in" methods of correcting errors.By the way, it's just an extra and unnecessary step to create an ISO for burning. ImgBurn will happily burn the VIDEO_TS folder. -
If you no longer have the original dvd disc then it's illegal to have a backup copy if the dis was copyrighted.
Um, I didn't say I didn't have it, I said it was lost, (probably in a box in the storage shed). It's a rare anime, otherwise I would just pay a $1 at redbox or download it from netflix... But... isn't that the point of making a backup? In case your DVD is lost or damaged?
Pardon me if I doubt your legal expertise on the subject. -
The point in making a backup is to store the original away so if the backup gets lost or damaged and why would you store a rare dvd in a storage shed?Downloading from netflix is illegal as well.
Sorry for the double-post but I just wanted to say "thanks!" to manomano - I learned enough to get the menu button working. When I play it now the main feature starts but I can press the menu button now and it takes me to the main menu where all the buttons work and I can access all the extras now form my TV remote.
I actually don't do much dvd ripping or burning but it's nice to have a forum like this to come to when I find myself in a fix. -
If you want to jump to the menu instead of the movie when the DVD is inserted, use PGC -> Jump to PGC Upon DVD Insert. Follow the instructions. Usually, it's very easy to do.
r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
- BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV
