  1. Hello!
    I tried to export the music files from the new MMO PC game called Wildstar. Seems they use BNK extension to store the music files. I successfully extracted the Music.bnk file from th archive with their own tool (Wildstar Studio) and then extracted the files from the .bnk container with "bnkextr.exe" but I received RIFF files in an unknown format. Tried to convert them with various converters with no success. No tools knows this format yet. The last tool I tried called "ww2ogg" gave me an error message at least: "parse error: RIFF truncated"
    I uploaded a sample of the audio files to here:
    http://mediafire.com/download/n4n2lcxlfcaf72s/.002.wav
    From MediaInfo:
    General
    Complete name : D:\GAMES\UJ\2\.002.wav
    Format : Wave
    File size : 2.72 MiB
    Duration : 1mn 24s
    Overall bit rate : 271 Kbps
    Audio
    Format : In Development
    Codec ID : FFFF
    Duration : 1mn 24s
    Bit rate : 271 Kbps
    Channel count : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 2.72 MiB (100%)
    Please take a look and see if you could identify the format / recommend a converter. Thank you in advance!
    Tried open with any audio editor? Like goldwave or/and audacity.
  3. Banned
    Freedonia
    There are a few articles on the internet about BNK audio. I can't read them while I'm at work due to restrictions (we can't go to any gaming websites), but just putting something like this:
    BNK audio
    in a Google search gave me a few articles that seemed promising about working with the audio from the brief summaries I could read. Please don't be too lazy to do a simple internet search.
  4. DECEASED
    Jun 2009
    Heaven
    Try decoding the BNK files with ffmpeg. BTW: not all audio codecs are well-supported in the WAV container.
  5. It is a WAV file, but ffmpeg can't decode it. That's why the publisher uses that particular codec. To make it harder for you to rip off their audio files.
  6. The BNK file itself is not an audio file, it is a container used by many game developer companies to store their data:
    I believe this is it or something similar:
    http://wiki.xentax.com/index.php?title=Wwise_SoundBank_%28*.bnk%29
    With bnkextr.exe I managed to extract this soundbank (.bnk) file already and I received a couple of wav files. The download link on my first post contains one of those WAV files to let you able to inspect the format because I couldn't find any editor / converter program that actually knows this wave format.
  7. DECEASED
    Jun 2009
    Heaven
    FYI --- WAV is a (RIFF-based) container as well.
    Besides, http://wiki.multimedia.cx/index.php?title=TwoCC says:
    0xFFFF In Development / Unregistered
    If I were you, and as a last resort, I would send an e-mail to Kostya:
    http://codecs.multimedia.cx/
