Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 12 of 12
  1. Member Johnbil's Avatar
    Sep 2010
    Staten Island, NY
    I'm looking to replace my old Handbrake program. I'm looking for a good, simple program that works with XVid and has filters such as deinterlace, denoise, decomb and detelecine in its GUI.
    Any recommendations would be welcome.
    Thanks...John
    OD: Windows 7
    Maybe staxrip.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Oh, you actually meant a "converter"
    Handbrake still works fine for me so I have not really tried anything else.
  4. Member Johnbil's Avatar
    Sep 2010
    Staten Island, NY
    Thanks, Baldrick. I tried Staxrip, but I guess I'll stick to Handbrake. I only had one issue with it. It's with setting Xvid's profile. Handbrake won't address issues with older versions. I'm going to ask my question with a new thread.
  5. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    Not really different than Handbrake, but you might look into VidCoder. It's a GUI for Handbrake that makes the program a bit easier to use.
  6. Member Johnbil's Avatar
    Sep 2010
    Staten Island, NY
    Vidcoder looks great, but it doesn't work with Xvid.
    Mar 2011
    Nova Scotia, Canada
    Newer handbrake versions don't either.
    I like avidemux for encodes to xvid myself. I think it has all those filters but I may be wrong.
    May 2014
    Down the road, last house on the right
    FYI Handbrake should be coming out with a new version fairly soon.
    I wish I knew exactly when though.
  9. Banned
    Freedonia
    In the 2nd sentence of the original post in this thread, the original poster stated that he wants to use Xvid. Handbrake stopped supporting Xvid years ago, so a new version won't do him any good. He's stuck with the last version they put out that supports Xvid encoding.
    Anyway, it's not the easiest program to use (the OP will likely need to find a guide), but Xvid4PSP can be used to encode with Xvid. I've done so. It might meet his needs.
    May 2014
    Yeah I personally have used avidemux for Xvid encodes (which isn't often ). Never tried
    Xvid4PSP. But I guess I will now.
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Originally Posted by zomac View Post
    You may check free dvd ripper speedy, it has a nice interface and easy to use.
    Are you speedy spammer?? Never heard about it.
