Results 1 to 18 of 18
  1. devdev devdev's Avatar
    Sep 2003
    does anyone know if tmpgenc mastering works 5 can invert a film?
  2. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    AFAIK, Negative and Positive relate to film, not video.
    Oct 2005
    666th portal
    don't know about tmpgenc but vegas pro has in invert filter
  4. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I thought invert was for building masks. Yeah it does do a Negative effect.
  5. Mod Neophyte redwudz's Avatar
    USA
    devdev, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Thanks,
    Moderator redwudz
  6. I don't know about tmpgenc mastering works 5 but most video and image editors have an invert filter. VirtualDub has one. AviSynth has one. If you're trying to convert color negatives to positives a simple invert usually won't work well. You usually need to do a lot more processing to get the colors and levels right.
  7. DECEASED
    Jun 2009
    Heaven
    And if you have the DScaler filters, then ffdshow can use them too
  8. Some media players have invert filters too. MPCHC for example.
  9. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    You might find that tool easier if you look for a color corrector that can rotate the hue 180 degrees.
  10. Originally Posted by budwzr View Post
    ? Rotating the hue 180 degrees isn't the same as an invert. Consider a greyscale image. Rotating the hue will make no difference. Inverting will.
  11. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I looked at the help for the Sony Invert tool, and that's what it does. Switches the color to its complement. And reverses the brightness.
    Is that what makes it a negative? Reversing the brightness?
  12. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    pretty much. if you ever worked in a darkroom you might remember black parts of negatives create white images.
  13. devdev devdev's Avatar
    Sep 2003
    are we saying that it would perhaps make sense to employ the sony vegas invert tool?
    I have premiere 6.5 that that has an invert tool - I wonder if it will have the same effect
  14. Originally Posted by devdev View Post
    Probably. I don't use the program so I don't know for sure.
    Probably. Most editors have an invert function.
    But as I mentioned earlier, if you have (for example) scans of 35mm film a simple invert will not be enough. You'll need to further refine the gamma and colors based on the properties of that particular film stock.
  15. TVMW5 will not do it. Vegas will (invert). Premiere will (channel/invert.)
  16. Maybe the OP didn't mean what you guys think. I'm thinking he meant rotate. Like he took cell phone photo upside down and want to 'invert' it to right side up.
    Extraordinary claims require extraordinary evidence -Carl Sagan
  17. Originally Posted by TreeTops View Post
    The title of the thread would suggest otherwise.
  18. Yes, you are probably correct. Reading his post #13 kinda implies he is trying to "invert" like you suggested.
