  1. Hi, I'm applying a same set of instructions to dozen of identical files in structure. The instructions are:
    "--default-track" "1:no"
    "--forced-track" "1:no"
    "--default-track" "2:yes"
    "--track-order" "0:0,0:2,0:1"
    How do I do that?
    Cann't tell it's possible don't tell anything.
    Make a batch/bat file with the mkvmerge command and put in same folder as your mkvs. Make a new folder newfiles in same folder.
    test.bat
    for %%a in ("*.mkv") do "c:\mkvtoolnix\mkvmerge.exe" -o "newfiles\%%a" --default-track 1:no --forced-track 1:no --default-track 2:yes --track-order 0:0,0:2,0:1 "%%a"
    pause
    Then double click/run the test.bat. You can test with just one mkv first.
  3. Great, thanks! Any idea how translate "for %%a in ("*.mkv") do" to a Terminal (OSX)? On a second thought I'can use a virtual XP machine for that.
    Nope. No idea.
  5. Thanks, Baldricks awesome tip works fantastic. I've been with computers since 1995 but I didn't know DOS can read files from a directory filtered by extension to repeat the command line with each file and provide the filename as string for input / output parameter.
    Besides MKVMerge does let you create an option file but does not tell you how to use it or apply it to multiple files.
    Also I tried 'Add command line options' feature but MkvMerge 'could not find' the loaded video track probably because the track rearrangement is not a 'global' nor 'hack' option listed in 'Available options' dropbox.
