hi
i have a problem playing newer mkv files
they play fine in media player classic
but in zoomplayer 5 and ms media player every few moments the screen turns a green,red,purple and blue color
you can still see the video scene but its one color
after a few seconds the color fades and you have a normal color again but this happens several time during play back
i also have a media player connected to the tv and there the video file freezes at the first frame and only the audio does work
i tried mkvtoolnix with a few settings changes but no luck changing it
did someone have a the same problem and manange to fix it
or does someone know the solution
i would appreciate some help i dont see to get anywhere![]()
Closed Thread
Please post a MediaInfo report about one of those "new" MKVs.
Perhaps you have some "10-bit" encodes, and the decoders of the other players cannot deal with that
this is the mediainfo of the file:
General
Unique ID : 197251201444249296962756815031508649825 (0x946533153C62CA678C786EF59187C761)
Complete name : D:\bittorrent store\rapidshare\gownload temp\movies\eros\downltemp\[FFF] Koi to Senkyo to Chocolate [BD][720p-AAC]\[FFF] Koi to Senkyo to Chocolate - 01 [BD][720p-AAC][A0773747].mkv
Format : Matroska
Format version : Version 2
File size : 525 MiB
Duration : 24mn 19s
Overall bit rate : 3 016 Kbps
Encoded date : UTC 2014-04-19 07:44:16
Writing application : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 9 2011 11:55:43
Writing library : libebml v1.2.2 + libmatroska v1.3.0
Attachment : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Video
Format : AVC
Format profile : High 10@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 24mn 19s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Title : 10bit H.264 - 720p
Writing library : x264 core 129 r2245+729M 1a52e03
Encoding settings : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=1.10 / psy_rd=0.80:0.05 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=250 / rc=crf / mbtree=1 / crf=14.0 / qcomp=0.85 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=3:0.90
Language : Japanese
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 24mn 19s
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Title : 2.0 AAC
Language : Japanese
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : Pomf
Language : English
Menu
00:00:00.000 : en:Prologue
00:02:10.005 : en:Opening
00:03:39.845 : en:Episode
00:22:10.746 : en:Ending
00:23:41.795 : en:Preview
please reread our rules about warez:
https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
