1. you can drag and drop one of more folders and/or files onto the .bat file and the script will process them, when it's run out of arguments to process it will ask for user input ie another file or folder.Originally Posted by http://ss64.com/nt/choice.html
2. is easily correctable but at the moment it makes the new AVI in the same directory as the file it's processing.
3. I just changed that in the new version. Now it creates a unique randomised name for the working file, then when it's done renames any old avi versions is finds before renaming the current working file and moves the .MXF into a folder called "Done". Or at least I hope it does.
4. I tried to add error correction but apparently VDM returns 0 even when something goes wrong. I could test for zero file size if you like (I do that in my own scripts) it's really not that hard.
5. Hopefully, it only looks in subdirectories if it doesn't find anything to process in the directory it's in and only if you've specifically pointed it at a directory. I need that for TV Shows that have season folders. It's easily removed.
I think I may have only just downloaded it, I'm not sure.Code:ffprobe version N-63013-g4cdea92 Copyright (c) 2007-2014 the FFmpeg developers built on May 6 2014 22:02:02 with gcc 4.8.2 (GCC)
Results 61 to 90 of 98
ah ok, so I think I have to change something to well test it. Because for the function that is useful to me, the script cannot work in the same dir of input file:
I use a sony pdw-f800 camera in FAM (file access mode), when I connect it on the pc, windows recognize the xdcam disc as drive (e.g. f:) and source .mxf are in (e.g.) f:\clips
but this drive is readonly, cannot write anythings
wishing, I can copy all the files in f:\clips into (e.g.) d:\mycats and process mycats but copying process would be employ also 1 hours (with the 50GB xdcam disc) ... it's more easy use f:\clips as source for opening .mxf files and point o:\ as target folder so I don't have to copy uselessy .mxf files into hard disk
So, for this reason maybe is uselessy (at least from what I have to do) do a "done" folder for processed .mxf
Initially, in fact, my script was (consider o:\ = v:\automazioneclip\output):
Code:set "d=" set "done=" set /p "d=Type source path (or press enter for current folder): " if not defined d set "d=%cd%" if not exist "%d%" echo Enter valid path - try again & goto :loop :loop cd /d "%d%" for /f "delims=" %%a in ('dir *.mxf /b /od /a-d') do ( if defined done goto :EOF if not exist "v:\automazioneclip\output\%%~na.*" ( echo %d%\%%~na.mxf|clip >nul bla bla bla c:\virtualdubsetup\vdub.exe anything .... ..... .... ) goto loop set done=1 )Last edited by marcorocchini; 13th May 2014 at 07:25.
also I thought another things: to make more safety and easy the script, avoiding to generate all entire .vcf
simply it have to use a pre-writed .vcf called script4HD.vcf and script4SD.vcf but the script have to change only the line
VirtualDub.video.AddComment(0x0000000C,"","01:34:2 1:15");
or simply it have to found the space reserved to 01:34:21:15 in script4HD.vcf (or script4SD.vcf) and change with the %timecode%
or delete entire line VirtualDub.video.AddComment(0x0000000C,"","01:34:2 1:15"); and replace with the new containing %timecode%Last edited by marcorocchini; 13th May 2014 at 07:30.
or more simply (I think)
script4SD.vcf/cript4HD.vcf does not have VirtualDub.video.AddComment(0x0000000C,"","01:34:2 1:15");
the script add a line to the script4HD.vcf and generate script4HDwithTC.vcf to take @ virtualdubmod only if the procced file have timecode -
Batch doesn't work like that. I can either write over the file or append to it, I can't alter bits in the middle. The name of the .VCF actually makes absolutely no difference whatsoever.
That should work, but I haven't tested it.Code:@rem unless otherwise specified for debugging reasons turn echo off @if "%EMode%"=="" Set EMode=OFF @ECHO %EMode% rem delayed expansion is a bad idea when processing file names SetLocal DisableDelayedExpansion Set "EXTLIST=*.mxf" Set "DoPop=0" Set "ARGLVL=0" Set "FileName-DQ=" Set VDM_LOC="C:\Program Files (x86)\VirtualDubMod\VirtualDubMod.exe" :MakeFolders Set "DestFolder=O:\Output" if EXIST "%DestFolder%" goto :MakeWork type NUL mkdir "%DestFolder%" if "%ERRORLEVEL%"=="0" goto :MakeWork echo Error!!! Cannot Make Destination Folder: echo "%DestFolder%" pause goto :eof :MakeWork Set "WorkFolder=%DestFolder%\Work" if EXIST "%WorkFolder%" goto :ARGS type NUL mkdir "%WorkFolder%" if "%ERRORLEVEL%"=="0" goto :ARGS echo Error!!! Cannot Make Work Folder: echo "%WorkFolder%" pause goto :eof rem process the arguments one by one. :ARGS rem if there are no further arguments then exit the batch. if [%1]==[] ( if "%ARGLVL%"=="0" ( CALL :GetTargetName EndLocal pause ) goto :eof ) rem wildcard processing Set "FileName=%~1" if "%FileName%"=="" ( SHIFT goto :ARGS ) rem if the argument doesn't exist in the file system in any form skip it. if NOT EXIST %1 ( SHIFT goto :ARGS ) if NOT [%1]==[] if NOT "%FileName:^*=%%FileName:^?=%"=="%FileName%%FileName%" ( for %%w in (%1) DO ( Set /a ARGLVL+=1 CALL :ARGS "%%~fw" Set /a ARGLVL-=1 ) SHIFT goto :ARGS ) Set "FileName=" rem Set search/recursion variables Set "Pattern=%EXTLIST%" Set "STARTLVL=0" Set "FOUNDLVL=1024" rem if the argument is the current directory then process everything in it. if "%~f1"=="%CD%" ( echo Processing Directory; "%CD%" CALL :START %1 SHIFT goto :ARGS ) rem Test if the argument is a directory, if it is move to it then process everything in it, if not then move to the file's parent directory and process the file. Then return to starting directory. Type NUL pushd "%~f1" 2> nul if NOT "%errorlevel%"=="0" ( if NOT "%CD%\"=="%~dp1" ( pushd "%~dp1" Set "DoPop=1" ) Set Pattern="%~nx1" ) else ( echo Processing Directory; "%~f1" Set "DoPop=1" ) CALL :START %1 if "%DoPop%"=="1" ( popd Set "DoPop=0" ) SHIFT goto :ARGS :START <CURRENT_ARG> rem Count is superseded by FOUNDLVL but may still be useful for renaming purposes Set "Count=0" rem Process all files in the current directory fitting the arguments search pattern. for /f "delims=" %%y in ('dir %Pattern% /b /od /a-d') do ( if /I NOT "%%~y"=="File Not Found" CALL :Process_File "%%~fy" ) rem if it didn't find anything search all directories instead goto :eof if "%Count%"=="0" if %STARTLVL% LSS %FOUNDLVL% ( for /d %%b in (*) do ( pushd "%%~fb" echo Processing Directory; "%%~fb" Set /a STARTLVL+=1 CALL :START "%%~fb" Set /a STARTLVL-=1 popd ) ) goto :eof :Process_File <MXF_FILENAME> Set /a Count+=1 Set "FOUNDLVL=%STARTLVL%" echo Processing File; "%~nx1" if /I NOT "%~x1"==".mxf" ( echo "%~nx1" echo Is not an mxf file. pause goto :eof ) if EXIST "%DestFolder%\%~n1.avi" ( echo Output Already Exists... goto :eof ) if EXIST "%WorkFolder%\%~n1.avi" ( echo Working File Already Exists... goto :eof pause ) SetLocal DisableDelayedExpansion rem Find TimeCode Info Set AUCount=0; for /f "tokens=1,2 delims=^=" %%g in ('FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_entries stream^=codec_type^,width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version "%~1" 2^>^&1') DO ( if "%%~g"=="TAG:company_name" set "T_Company_Name=%%~h" if "%%~g"=="TAG:product_name" set "T_Product_Name=%%~h" if "%%~g"=="TAG:product_version" set "T_Product_Version=%%~h" if "%%~g"=="TAG:timecode" set "TIMECODE=%%~h" if "%%~g"=="width" set "V_Width=%%~h" if "%%~g"=="height" set "V_Height=%%~h" if "%%~g"=="sample_aspect_ratio" set "V_PAR=%%~h" if "%%~g"=="codec_type" if "%%~h"=="audio" set /a AUCount+=1 ) if "%V_Width%"=="" ( echo ERROR: Video Width NOT FOUND! pause goto :eof ) if "%V_Height%"=="" ( echo ERROR: Video Height NOT FOUND! pause goto :eof ) if "%V_PAR%"=="" ( echo ERROR: Video PAR NOT FOUND! pause goto :eof ) rem Set "V_Q=UD" rem if %V_Width% LEQ 1920 if %V_Height% LEQ 1120 \\ Set "V_Q=HD" rem if %V_Width% LEQ 1280 if %V_Height% LEQ 752 Set "V_Q=MD" if %V_Width% LEQ 1024 if %V_Height% LEQ 608 Set "V_Q=SD" echo Using %V_Q% Mode. echo PAR = %V_PAR% if "%TimeCode%"=="" echo Warning! no TimeCode Found! if NOT "%TimeCode%"=="" echo Timecode= %TIMECODE% if NOT "%TimeCode:~2,1%"=="" echo %TimeCode:~0,-1%^%TimeCode:~-1,1%>"%~dpn1.txt" rem if NOT "%TimeCode%"=="" echo %TimeCode% 1>"%~dpn1.txt" CALL :MAKEVCF "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1" echo Done! echo. echo --------------------------------------------- echo. EndLocal goto :eof :MAKEVCF <VCF_FILENAME> <AVS_FILENAME> <AVI_FILENAME> <MXF_FILENAME> rem ***Make The .vcf Script File*** echo %T_Company_Name% %T_Product_Name% %T_Product_Version% echo %AUCount% Audio Streams Detected. echo VirtualDub.RemoveInputStreams^(^)^;>%1 echo VirtualDub.video.DeleteComments^(1^)^;>>%1 if NOT "%TimeCode%"=="" echo VirtualDub.video.AddComment^(0x0000000C,"","%TIMECODE%"^)^;>>%1 echo VirtualDub.video.AdjustChapters^(1^)^;>>%1 echo VirtualDub.video.SetDepth^(24,24^)^;>>%1 echo VirtualDub.video.SetMode^(1^)^;>>%1 echo VirtualDub.video.SetFrameRate^(0,1^)^;>>%1 echo VirtualDub.video.SetIVTC^(0,0,-1,0^)^;>>%1 echo VirtualDub.video.SetCompression^(0x6a6d7674,0,10000 ,0^)^;>>%1 echo VirtualDub.video.SetCompData^(28,"TUpQRxgAAAAAAAAAA gAAAAgAAAACAAAAAQAAAA=="^)^;>>%1 echo VirtualDub.video.filters.Clear^(^)^;>>%1 echo if "%V_Q%"=="HD" echo "Insert HD Video Info Like This">>%1 echo if "%V_Q%"=="SD" echo "Insert SD Video Info Like This">>%1 rem ***Make The .avs AVISynth Script*** echo DirectShowSource^(%4^)>%2 if "%V_Q%"=="HD" echo Crop^(0,32,0,0^)>>%2 rem ***Call VirtualDub[Mod] if NOT EXIST %VDM_LOC% ( echo Um, where the hell is VirtualDubMod? pause ) %VDM_LOC% /s%1 /p%2,%3 /r /x if NOT "%ERRORLEVEL%"=="0" ( echo WARNING!!! VirtualDubMod Error Detected!!! pause ) for %%v in (%3) do ( if %%~zv LSS 128 ( echo ERROR!!! Extra Small File Size Detected!!! pause ) ) rem Clean-up if NOT EXIST DONE MKDIR DONE DEL %1 DEL %2 if NOT EXIST "%DESTFOLDER%\%~n4.avi" goto :Skip-To-Cleanup :MakeOldFile Set "TEMPFILE=%~n4-o%RANDOM%.avi" if EXIST "%DESTFOLDER%\%TEMPFILE%" goto :MakeOldFile REN "%DESTFOLDER%\%~n4.avi" %TEMPFILE% :Skip-To-Cleanup REN %3 "%~n4.avi" MOVE "%WorkFolder%\%~n4.avi" ".." goto :eof :GetTargetName Set "FileName=" Set /p FileName=Enter Target Name: rem Add or remove double-quotes if necessary if NOT DEFINED FileName ( Set "FileName-DQ=" goto :DQSkip ) Set "FileName-DQ=%FileName:"=%" if NOT DEFINED FileName-DQ ( Set "FileName=" Set "FileName-DQ=" goto :DQSkip ) if EXIST "%FileName-DQ%" ( if "%FileName-DQ%"=="%FileName-DQ: =%" ( Set "FileName=%FileName-DQ%" ) else ( Set FileName="%FileName-DQ%" ) ) :DQSkip if /I "%FileName-DQ%"=="" Set FileName="%CD%" if /I "%FileName-DQ%"=="CD" Set FileName="%CD%" if /I "%FileName-DQ%"=="EXIT" goto :eof if /I "%FileName-DQ%"=="X" goto :eof if /I "%FileName-DQ%"=="NOEXIT" goto :GetTargetName if DEFINED FileName ( Set /a ARGLVL+=1 CALL :ARGS %FileName% Set /a ARGLVL-=1 ) goto :GetTargetName
Will give a list of all the relevant possible FFProbe outputs.Code:FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_format "%~f1"
I only got involved in this to correct an atrocious use of the for loop...Last edited by ndjamena; 18th May 2014 at 07:50.
Aaaaanyway, I'm about to reinstall windows to see if I can get MKVExtract to stop crashing every time I try to extract some tags... If it works, I'll have to see about trying to get it happening again so I can finally get that bug fixed.
------------------- (I'm looking for download choise for xp)
maybe your choice is not the same version/os or I don't know that mine
with another version:
I'm looking for the choice of the resource kit
hoewver your script, in my pc, seems to work when I try to drag and drop a file into script (mmm what powerful!) but if I press the Return key not working well because maybe I don't have the right CHOICE
I have download it from:
http://hp.vector.co.jp/authors/VA007219/dkclonesup/choice.htmlLast edited by marcorocchini; 13th May 2014 at 10:51.
this works! but it select HD also for SD files ^_^Code:
@rem unless otherwise specified for debugging reasons turn echo off @if "%EMode%"=="" Set EMode=OFF @ECHO %EMode% echo on rem delayed expansion is a bad idea when processing file names SetLocal DisableDelayedExpansion Set "EXTLIST=*.mxf" Set "DoPop=" rem if no arguments are given, process everything in the current directory. if [%1]==[] ( Set "Pattern=%EXTLIST%" CALL :START %1 ) rem process the arguments one by one. :ARGS rem if there are no further arguments then exit the batch. if [%1]==[] ( EndLocal pause goto :eof ) rem if the argument doesn't exist in the file system in any form skip it. if NOT EXIST %1 ( SHIFT goto :ARGS ) Set "Pattern=%EXTLIST%" rem if the argument is the current directory then process everything in it. if "%~f1"=="%CD%" ( CALL :START %1 SHIFT goto :ARGS ) rem Test if the argument is a directory, if it is move to it then process everything in it, if not then move to the file's parent directory and process the file. Then return to starting directory. Type NUL pushd "%~f1" 2> nul if NOT "%errorlevel%"=="0" ( if NOT "%CD%\"=="%~dp1" ( pushd "%~dp1" Set "DoPop=1" ) Set Pattern="%~nx1" ) else ( Set "DoPop=1" ) CALL :START %1 if "%DoPop%"=="1" ( popd Set "DoPop=" ) SHIFT goto :ARGS :START Set "Count=0" rem Process all files in the current directory fitting the arguments search pattern. for %%y in (%Pattern%) do ( CALL :Process_File "%%~fy" ) rem if the last for loop didn't find anything search all directories up one level instead if "%Count%"=="0" ( for /d %%b in (*) do ( pushd "%%~fb" CALL :START "%%~fb" popd ) ) goto :eof :Process_File <MXF_FILENAME> Set /a Count+=1 Set "FOUNDLVL=%STARTLVL%" if /I NOT "%~x1"==".mxf" ( echo "%~nx1" echo Is not an mxf file. pause goto :eof ) SetLocal DisableDelayedExpansion rem Find TimeCode Info echo Processing File; "%~nx1" Set AUCount=0; for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\virtualdubmod\FFProbe.exe -hide_banner -loglevel fatal -pretty -show_streams -select_streams v -show_entries stream^=width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version "%~1" 2^>^&1') DO ( if "%%~g"=="TAG:company_name" ( set "T_Company_Name=%%~h" ) if "%%~g"=="TAG:product_name" ( set "T_Product_Name=%%~h" ) if "%%~g"=="TAG:product_version" ( set "T_Product_Version=%%~h" ) if "%%~g"=="TAG:timecode" ( set "TIMECODE=%%~h" ) if "%%~g"=="width" ( set "V_Width=%%~h" ) if "%%~g"=="height" ( set "V_Height=%%~h" ) if "%%~g"=="sample_aspect_ratio" ( set "V_PAR=%%~h" ) ) if "%V_Width%"=="" ( echo ERROR: Video Width NOT FOUND! pause goto :eof ) if "%V_Height%"=="" ( echo ERROR: Video Height NOT FOUND! pause goto :eof ) if "%V_PAR%"=="" ( echo ERROR: Video PAR NOT FOUND! pause goto :eof ) Set "V_Q=" if %V_Width% LEQ 1024 if %V_Height% LEQ 576 Set "V_Q=SD" if "%V_Q%"=="" Set "V_Q=HD" if "%TIMECODE%"=="" ( echo NO TIMECODE FOUND IN: echo "%~1" pause ) else ( if "%V_Q%"=="SD" ( CALL :MAKEVCF_SD "v:\automazioneclip\virtualdubmod\temp\%~n1.vcf" "v:\automazioneclip\virtualdubmod\temp\%~n1.avs" "o:\%~n1.avi" "%~f1" ) else ( CALL :MAKEVCF_HD "v:\automazioneclip\virtualdubmod\temp\%~n1.vcf" "v:\automazioneclip\virtualdubmod\temp\%~n1.avs" "o:\%~n1.avi" "%~f1" ) ) echo Done! echo. echo --------------------------------------------- echo. EndLocal goto :eof :MAKEVCF_HD <VCF_FILENAME> <AVS_FILENAME> <AVI_FILENAME> <MXF_FILENAME> rem ***Make The .vcf Script File*** echo VirtualDub.RemoveInputStreams^(^)^;>%1 echo VirtualDub.video.DeleteComments^(1^)^;>>%1 echo VirtualDub.video.AddComment^(0x0000000C,"","%TIMECODE%"^)^;>>%1 echo VirtualDub.video.AdjustChapters^(1^)^;>>%1 echo VirtualDub.video.SetDepth^(24,24^)^;>>%1 echo VirtualDub.video.SetMode^(1^)^;>>%1 echo VirtualDub.video.SetFrameRate^(0,1^)^;>>%1 echo VirtualDub.video.SetIVTC^(0,0,-1,0^)^;>>%1 echo VirtualDub.video.SetCompression^(0x31626d64,0,10000 ,0^)^;>>%1 echo VirtualDub.video.filters.Clear^(^)^;>>%1 rem ***Make The .avs AVISynth Script*** echo DirectShowSource^(%4^)>%2 rem ***Call VirtualDub[Mod] "v:\automazioneclip\virtualdubmod\virtualdubmod.exe" /s%1 /p%2,%3 /r /x "v:\automazioneclip\virtualdub\cfourcc.exe" -i o:\%~n1.avi -u MJPG -d MJPG goto :eof :MAKEVCF_SD <VCF_FILENAME> <AVS_FILENAME> <AVI_FILENAME> <MXF_FILENAME> rem ***Make The .vcf Script File*** echo VirtualDub.RemoveInputStreams^(^)^;>%1 echo VirtualDub.video.DeleteComments^(1^)^;>>%1 echo VirtualDub.video.AddComment^(0x0000000C,"","%TIMECODE%"^)^;>>%1 echo VirtualDub.video.AdjustChapters^(1^)^;>>%1 echo VirtualDub.video.SetDepth^(24,24^)^;>>%1 echo VirtualDub.video.SetMode^(1^)^;>>%1 echo VirtualDub.video.SetFrameRate^(0,1^)^;>>%1 echo VirtualDub.video.SetIVTC^(0,0,-1,0^)^;>>%1 echo VirtualDub.video.SetCompression^(0x31626d64,0,10000 ,0^)^;>>%1 echo VirtualDub.video.SetCompData^(28,"TUpQRxgAAAAAAAAAA gAAAAgAAAACAAAAAQAAAA=="^)^;>>%1 echo VirtualDub.video.filters.Clear^(^)^;>>%1 rem ***Make The .avs AVISynth Script*** echo DirectShowSource^(%4^)>%2 echo Crop^(0,32,0,0^)>>%2 rem ***Call VirtualDub[Mod] "v:\automazioneclip\virtualdubmod\virtualdubmod.exe" /s%1 /p%2,%3 /r /x goto :eof
my file HD:
eneral
Complete name : D:\galvanina\C0054.MXF
Format : MXF
Commercial name : XDCAM HD422
Format profile : OP-1a
Format settings : Closed / Complete
File size : 63.6 MiB
Duration : 8s 800ms
Overall bit rate : 60.6 Mbps
Encoded date : 2013-09-07 18:31:25.000
Writing application : SONY Opt 1.22
Writing library : SONY Opt 1.22
Video
Format : MPEG Video
Format version : Version 2
Format profile : 4:2:2@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Format_Settings_Wrapping : Frame
Duration : 8s 800ms
Bit rate : 50.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.965
Stream size : 52.5 MiB (82%)
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : PCM
Format settings, Endianness : Little
Format_Settings_Wrapping : Frame (AES)
Duration : 8s 800ms
Bit rate mode : Constant
Bit rate : 1 152 Kbps
Channel(s) : 1 channel
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 1.21 MiB (2%)
Audio #2
Format : PCM
Duration : 8s 800ms
Bit depth : 24 bits
Audio #3
Format : PCM
Duration : 8s 800ms
Bit depth : 24 bits
Audio #4
Format : PCM
Duration : 8s 800ms
Bit depth : 24 bits
Audio #5
Format : PCM
Duration : 8s 800ms
Bit depth : 24 bits
Audio #6
Format : PCM
Duration : 8s 800ms
Bit depth : 24 bits
Audio #7
Format : PCM
Duration : 8s 800ms
Bit depth : 24 bits
Audio #8
Format : PCM
Duration : 8s 800ms
Bit depth : 24 bits
Other #1
Type : Time code
Format : MXF TC
Time code of first frame : 01:35:38:23
Time code settings : Striped
Other #2
Type : Time code
Format : SMPTE TC
Muxing mode : SDTI
my file SD:
General
Complete name : V:\cesenaCalcio\C0039.MXF
Format : MXF
Commercial name : IMX 50
File size : 419 MiB
Duration : 56s 160ms
Overall bit rate : 62.6 Mbps
Encoded date : 2013-09-19 15:51:22.000
Writing application : SONY Opt 1.41
Writing library : SONY Opt 1.41
Video
Format : MPEG Video
Format profile : 4:2:2@Main
Format settings, BVOP : No
Format settings, Matrix : Default
Format settings, GOP : N=1
Format_Settings_Wrapping : Frame (D-10)
Width : 720 pixels
Height : 576 pixels
Original height : 608 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 4.823
Stream size : 337 MiB (80%)
Audio
Format : PCM
Bit rate : 12.3 Mbps
Channel(s) : 8 channels
Bit depth : 24 bits
Stream size : 82.3 MiB (20%)
Other #1
Type : Time code
Format : MXF TC
Time code of first frame : 00:30:09:07
Other #2
Type : Time code
Format : SMPTE TC
Muxing mode : SDTI
Time code of first frame : 00:30:09:07 -
if cannot understand why for SD files the script use alwais HD routine
Just delete the /M message switch. Apparently it doesn't need it.Originally Posted by http://hp.vector.co.jp/authors/VA007219/dkclonesup/choice.txt
My bad, I forgot to check if it was already set.
Plus your 'SD' videos have a height of 608 for some reason...Code:Set "V_Q=UD" if %V_Width% LEQ 1920 if %V_Height% LEQ 1120 Set "V_Q=HD" if %V_Width% LEQ 1280 if %V_Height% LEQ 752 Set "V_Q=MD" if %V_Width% LEQ 1024 if %V_Height% LEQ 608 Set "V_Q=SD" echo Using %V_Q% Mode.
-Edit- I flipped it around to make it neater.Last edited by ndjamena; 14th May 2014 at 00:24.
yes, now SD works
but if you press return key it falls in "invalid switch syntax. Expected form: /C[:]choices"
however I would like remove you can remove the choice option, is not important -
Delete that, or rem it in case you want to add it back.Code:
CALL :GetTargetName
it LOOKS as though you need to add a colon between the /C and the YN, or else leave out the space. Something like that.Code:
CHOICE [/C[:]choices] [/N] [/S] [/T[:]c,nn] [text]
ndjamena please I ask you a kindness: in this days I do many proof
At the moment I try to understand this:
if I have a .mxf file c:\mycats\c0001.mxf, and I want insert in a batch file the fact that c0001.mxf is a enviroment variable, what is the restrict procedure that extract timecode with ffprobe from c0001.mxf and put it in another variable?
and If have a .txt (ascii) file -attached- called that contain
what is the procedure to put in a enviroment variable 01:24:51:23 ? (procedure without use ffprobe)
thank you -
your text file is a pain because it uses spaces in the descriptors but...
Option 1:
Option 2:Code:for /F "usebackq tokens=1,* delims=:" %%g in ("c0006.txt") DO ( if "%%g"=="Time code of first frame " Set TimeCode=%%h ) Set "TimeCode=%TimeCode: =%" echo %TimeCode%
Make sure there's a single set of double quotes around the file name, in case the file name has spaces. You could remove a few tokens from option 2 and remove some of the conditional ifs, it will just be less accurate that way.Code:for /F "usebackq tokens=1,2,3,4,5,* delims=: " %%g in ("c0006.txt") DO ( if "%%g"=="Time" if "%%h"=="code" if "%%i"=="of" if "%%j"=="first" if "%%k"=="frame" Set TimeCode=%%l ) echo %TimeCode% -
ndjamena please help me cat:
I try to make my script this:
Code:del /q v:\automazioneclip\virtualdubmod\temp\*.* @echo on set "d=" set "done=" set /p "d=Type source path (or press enter for current folder): " if not defined d set "d=%cd%" if not exist "%d%" echo Enter valid path - try again & goto :loop :loop cd /d "%d%" for /f "delims=" %%a in ('dir *.mxf /b /od /a-d') do ( if defined done goto :EOF if not exist "v:\automazioneclip\output\%%~na.*" ( if exist v:\automazioneclip\virtualdubmod\temp\ascii.txt del v:\automazioneclip\virtualdubmod\temp\ascii.txt if exist v:\automazioneclip\virtualdubmod\temp\unicodefile.txt del v:\automazioneclip\virtualdubmod\temp\unicodefile.txt v:\automazioneclip\virtualdubmod\mediainfo.exe "%d%\%%~na.mxf" dumpinfo:"v:\automazioneclip\virtualdubmod\temp\unicodefile.txt" TYPE "v:\automazioneclip\virtualdubmod\temp\unicodefile.txt" > "v:\automazioneclip\virtualdubmod\temp\ascii.txt rename "v:\automazioneclip\virtualdubmod\temp\ascii.txt" mediainfo%%~na.txt for /F "usebackq tokens=1,* delims=:" %%g in ("v:\automazioneclip\virtualdubmod\temp\mediainfo%%~na.txt") DO ( if "%%g"=="Time code of first frame " Set TimeCode=%%h ) Set "TimeCode=%TimeCode: =%" echo "%TimeCode%" echo "%TimeCode%"|clip >nul findstr /c:"Commercial name : XDCAM HD422" "v:\automazioneclip\virtualdubmod\temp\mediainfo%%~na.txt" IF NOT ERRORLEVEL 1 ( echo DirectShowSource^("%d%\%%~na.mxf"^) >> v:\automazioneclip\virtualdubmod\temp\%%~na.avs "v:\automazioneclip\virtualdubmod\virtualdubmod.exe" /s"v:\automazioneclip\virtualdubmod\scriptHD.vcf" /p"v:\automazioneclip\virtualdubmod\temp\%%~na.avs","v:\automazioneclip\output\%%~na.avi" /r /x if exist v:\automazioneclip\virtualdubmod\temp\ascii.txt del v:\automazioneclip\virtualdubmod\temp\ascii.txt if exist v:\automazioneclip\virtualdubmod\temp\unicodefile.txt del v:\automazioneclip\virtualdubmod\temp\unicodefile.txt ) goto loop set done=1 ) )
this script consider to process only all .mxf files that are not in v:\automazioneclip\output
e.g if C0007.avi are in v:\automazioneclip\output ---> it don't process C0007.mxf of the input directory
[because of the if not exist "v:\automazioneclip\output\%%~na.*" ( line]
during execution it seems store timecode, but strangely don't put is on clipboard (using clip.exe for dos loaded on windows/system32)
I cannnot undestand why
or I can use also ffprobe but I don't know how incorporate to my script
the reason of my script is this: the script start from the .mxf file that are not processed. All .mxf processed have not to rewrite for transcoding.
If I have 100 .mxf file, and 50 are jet transcoded --> I don't wont to re-transcode first 50 .mxf
the script have to process only .mxf files not transcoded
if your script can do this I would be glad to use yours ^^ -
I was just about to add the code to my .bat file when I realised it was already there. However, as always, I need to know the exact purpose of the code. Do you intend to run multiple instances of the batch file? That's important so I know how to position and name the working files and what to check for before I begin another.
should work.Code:echo %TIMECODE%|CLIP
***I now have one more MKVToolNix bug under my belt, hopefully the time has come where I can continue using the tools without them constantly spitting error messages at me!!!*** -
at the moment for me is enought if I correct the timecode problem into my script
I have try with echo %TIMECODE%|CLIP but seems don't work. It's strange because seems easy but in clipboard it don't want take in clipbrd -
It works on mine... Why do you want the timecode in the clip-board anyhoo?
What version of windows are you using? Apparently, CLIP was introduce in Windows Server 2003 and Vista. It can be copied between systems and used in Windows XP Pro but it doesn't look like it works with plain old XP at all. -
By the way:
But as it stands my script won't handle multiple instances at all. I've thought about copying your script into mine but you've mentioned things that aren't in there. I'm still trying to figure out why there's a 'set done=1' after a 'goto loop' where it can never be reached.Code::Process_File <MXF_FILENAME> Set /a Count+=1 Set "FOUNDLVL=%STARTLVL%" echo Processing File; "%~nx1" if /I NOT "%~x1"==".mxf" ( echo "%~nx1" echo Is not an mxf file. pause goto :eof ) if EXIST "%DEST%\%~n1.avi" ( echo Output Already Exists... goto :eof ) SetLocal DisableDelayedExpansion rem Find TimeCode Info
oh I don't know, it was write by one of my 5 cats!
hoewver also me was thinking: why if there is a goto and is there a set done=1 so set done is baypassed by a cat! :=)
the "clip" is just a whim to be sure that the environment variable is correctly assigned.
The thing that make me angry with my script, is that sometimes (sometimes ^^^) the timecode enter in clip and sometimes not.
Your script seems working (but I cannot try with the choice version) but seems to me each time it start from afresh:
eg. if I have 1000 .mxf files in c:\mycats and I have processed 700 files, but the script start afresh from c0001.mxf and I have to be waith until C1000.mxf
I woulk like a script that don't have to transcode the first 700 .mxf
another thing: copy temp files would be sometimes uncomfortable when it comes to copying files of 20-30GB
summarizing, I should do this:
1) when the script starts it habe to ask if you want (as watch directory) to use the Current Directory or please specify what the Watch Directory of input .mxf files (but at the same time would be glad to receive .mxf files via drag and drop)
[? set "d="
set "done="
if not defined d set "d=%cd%"]
2) output directory is fixed (e.g. o:\ or o:\output or o:\work o:\outputCATS ec.. for example here I assume o:\work )
3) if o:\work have a file that have the same name without extension of a file contents in the watch directory ---> that file have to no process
example: if o:\work have jet C009.avi and C0010.AVI and C0011.avi AND IF the watch directory have C0009.mxf and C0010.MXF and C0011.mxf ---> C0009/10/11.mxf have not to process [? if not exist "v:\automazioneclip\output\%%~na.*" ( ...]
4) the order of the files to be processed should be from the older to the younger [for /f "delims=" %%a in ('dir *.mxf /b /od /a-d')]
5) the script have to distinguish only hd (1920x1080) files from SD (IMX D-10 is 608?X576)
(it's nice to see other resolutions and others addicted functions in your script but I risk of lose-me, if I before understand the bare essentials-->after I understand all the complements)
Possibly would be better if the script recall a defined .vcf called (e.g) scriptHD.vcf and scriptSD.vcf
because for HD have to use a codec (dmb1)
and for SD have to use another codec (tvmj) (the reason of that is is more easy modify the vcf for subsequent additions to the operations of virtualdub, I know hoever it's possibile with the insertion o single lines
but seems to me more pratical use pre-defined .vcf)
6) timecode: if exist in source .mxf ---> it must be inserted in .avi (destination files)
if not exist in .mxf don't insert nothing
ndjamena thanks anyway also by my 5 cats -
OK, THIS is how to make different .vcf files for HD and SD content:
Code:echo if "%V_Q%"=="HD" echo "Insert HD Video .vcf Info Like This">>%1 echo if "%V_Q%"=="SD" echo "Insert SD Video .vcf Info Like This">>%1
And as far as I can tell, THIS is pretty much everything you've asked for:
You need to customise the .vcf output and add the audio processing, I can see you're more than capable of doing that, just add the code to the :MAKEVCF block. %4 is the original file, the variable works just like %%a. ie. [%~n4]==[%%~na] so I know you understand.Code:@rem unless otherwise specified for debugging reasons turn echo off @if "%EMode%"=="" Set EMode=OFF @ECHO %EMode% rem delayed expansion is a bad idea when processing file names SetLocal DisableDelayedExpansion Set "EXTLIST=*.mxf" Set "DoPop=0" Set "ARGLVL=0" Set "FileName-DQ=" Set VDM_LOC="C:\Program Files (x86)\VirtualDubMod\VirtualDubMod.exe" :MakeFolders Set "DestFolder=O:\output" if EXIST "%DestFolder%" goto :MakeWork type NUL mkdir "%DestFolder%" if "%ERRORLEVEL%"=="0" goto :MakeWork echo Error!!! Cannot Make Destination Folder: echo "%DestFolder%" pause goto :eof :MakeWork Set "WorkFolder=%DestFolder%\Work" if EXIST "%WorkFolder%" goto :ARGS type NUL mkdir "%WorkFolder%" if "%ERRORLEVEL%"=="0" goto :ARGS echo Error!!! Cannot Make Work Folder: echo "%WorkFolder%" pause goto :eof rem process the arguments one by one. :ARGS rem if there are no further arguments then exit the batch. if [%1]==[] ( if "%ARGLVL%"=="0" ( CALL :GetTargetName EndLocal pause ) goto :eof ) rem wildcard processing Set "FileName=%~1" if "%FileName%"=="" ( SHIFT goto :ARGS ) rem if the argument doesn't exist in the file system in any form skip it. if NOT EXIST %1 ( SHIFT goto :ARGS ) if NOT [%1]==[] if NOT "%FileName:^*=%%FileName:^?=%"=="%FileName%%FileName%" ( for %%w in (%1) DO ( Set /a ARGLVL+=1 CALL :ARGS "%%~fw" Set /a ARGLVL-=1 ) SHIFT goto :ARGS ) Set "FileName=" rem Set search/recursion variables Set "Pattern=%EXTLIST%" Set "STARTLVL=0" Set "FOUNDLVL=1024" rem if the argument is the current directory then process everything in it. if "%~f1"=="%CD%" ( echo Processing Directory; "%CD%" CALL :START %1 SHIFT goto :ARGS ) rem Test if the argument is a directory, if it is move to it then process everything in it, if not then move to the file's parent directory and process the file. Then return to starting directory. Type NUL pushd "%~f1" 2> nul if NOT "%errorlevel%"=="0" ( if NOT "%CD%\"=="%~dp1" ( pushd "%~dp1" Set "DoPop=1" ) Set Pattern="%~nx1" ) else ( echo Processing Directory; "%~f1" Set "DoPop=1" ) CALL :START %1 if "%DoPop%"=="1" ( popd Set "DoPop=0" ) SHIFT goto :ARGS :START <CURRENT_ARG> rem Count is superseded by FOUNDLVL but may still be useful for renaming purposes Set "Count=0" rem Process all files in the current directory fitting the arguments search pattern. for /f "delims=" %%y in ('dir %Pattern% /b /od /a-d') do ( if /I NOT "%%~y"=="File Not Found" CALL :Process_File "%%~fy" ) rem if it didn't find anything search all directories instead if "%Count%"=="0" if %STARTLVL% LSS %FOUNDLVL% ( for /d %%b in (*) do ( pushd "%%~fb" echo Processing Directory; "%%~fb" Set /a STARTLVL+=1 CALL :START "%%~fb" Set /a STARTLVL-=1 popd ) ) goto :eof :Process_File <MXF_FILENAME> Set /a Count+=1 Set "FOUNDLVL=%STARTLVL%" echo Processing File; "%~nx1" if /I NOT "%~x1"==".mxf" ( echo "%~nx1" echo Is not an mxf file. pause goto :eof ) if EXIST "%DestFolder%\%~n1.avi" ( echo Output Already Exists... goto :eof ) if EXIST "%WorkFolder%\%~n1.avi" ( echo Working File Already Exists... goto :eof pause ) SetLocal DisableDelayedExpansion rem Find TimeCode Info Set AUCount=0; for /f "tokens=1,2 delims=^=" %%g in ('FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_entries stream^=codec_type^,width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version "%~1" 2^>^&1') DO ( if "%%~g"=="TAG:company_name" set "T_Company_Name=%%~h" if "%%~g"=="TAG:product_name" set "T_Product_Name=%%~h" if "%%~g"=="TAG:product_version" set "T_Product_Version=%%~h" if "%%~g"=="TAG:timecode" set "TIMECODE=%%~h" if "%%~g"=="width" set "V_Width=%%~h" if "%%~g"=="height" set "V_Height=%%~h" if "%%~g"=="sample_aspect_ratio" set "V_PAR=%%~h" if "%%~g"=="codec_type" if "%%~h"=="audio" set /a AUCount+=1 ) if "%V_Width%"=="" ( echo ERROR: Video Width NOT FOUND! pause goto :eof ) if "%V_Height%"=="" ( echo ERROR: Video Height NOT FOUND! pause goto :eof ) if "%V_PAR%"=="" ( echo ERROR: Video PAR NOT FOUND! pause goto :eof ) rem Set "V_Q=UD" rem if %V_Width% LEQ 1920 if %V_Height% LEQ 1120 \\ Set "V_Q=HD" rem if %V_Width% LEQ 1280 if %V_Height% LEQ 752 Set "V_Q=MD" if %V_Width% LEQ 1024 if %V_Height% LEQ 608 Set "V_Q=SD" echo Using %V_Q% Mode. echo PAR = %V_PAR% if "%TimeCode%"=="" echo Warning! no TimeCode Found! if NOT "%TimeCode%"=="" echo Timecode= %TIMECODE% if NOT "%TimeCode:~2,1%"=="" echo %TimeCode:~0,-1%^%TimeCode:~-1,1%>"%~dpn1.txt" rem if NOT "%TimeCode%"=="" echo %TimeCode% 1>"%~dpn1.txt" CALL :MAKEVCF "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1" echo Done! echo. echo --------------------------------------------- echo. EndLocal goto :eof :MAKEVCF <VCF_FILENAME> <AVS_FILENAME> <AVI_FILENAME> <MXF_FILENAME> rem ***Make The .vcf Script File*** echo %T_Company_Name% %T_Product_Name% %T_Product_Version% echo %AUCount% Audio Streams Detected. echo VirtualDub.RemoveInputStreams^(^)^;>%1 echo VirtualDub.video.DeleteComments^(1^)^;>>%1 if NOT "%TimeCode%"=="" echo VirtualDub.video.AddComment^(0x0000000C,"","%TIMECODE%"^)^;>>%1 echo VirtualDub.video.AdjustChapters^(1^)^;>>%1 echo VirtualDub.video.SetDepth^(24,24^)^;>>%1 echo VirtualDub.video.SetMode^(1^)^;>>%1 echo VirtualDub.video.SetFrameRate^(0,1^)^;>>%1 echo VirtualDub.video.SetIVTC^(0,0,-1,0^)^;>>%1 echo VirtualDub.video.SetCompression^(0x6a6d7674,0,10000 ,0^)^;>>%1 echo VirtualDub.video.SetCompData^(28,"TUpQRxgAAAAAAAAAA gAAAAgAAAACAAAAAQAAAA=="^)^;>>%1 echo VirtualDub.video.filters.Clear^(^)^;>>%1 echo if "%V_Q%"=="HD" echo "Insert HD Video Info Like This">>%1 echo if "%V_Q%"=="SD" echo "Insert SD Video Info Like This">>%1 rem ***Make The .avs AVISynth Script*** echo DirectShowSource^(%4^)>%2 if "%V_Q%"=="HD" echo Crop^(0,32,0,0^)>>%2 rem ***Call VirtualDub[Mod] if NOT EXIST %VDM_LOC% ( echo Um, where the hell is VirtualDubMod? pause ) %VDM_LOC% /s%1 /p%2,%3 /r /x if NOT "%ERRORLEVEL%"=="0" ( echo WARNING!!! VirtualDubMod Error Detected!!! pause ) for %%v in (%3) do ( if %%~zv LSS 128 ( echo ERROR!!! Extra Small File Size Detected!!! pause ) ) rem Clean-up if NOT EXIST DONE MKDIR DONE DEL %1 DEL %2 if NOT EXIST "%DESTFOLDER%\%~n4.avi" goto :Skip-To-Cleanup :MakeOldFile Set "TEMPFILE=%~n4-o%RANDOM%.avi" if EXIST "%DESTFOLDER%\%TEMPFILE%" goto :MakeOldFile REN "%DESTFOLDER%\%~n4.avi" %TEMPFILE% :Skip-To-Cleanup REN %3 "%~n4.avi" MOVE "%WorkFolder%\%~n4.avi" ".." goto :eof :GetTargetName Set "FileName=" Set /p FileName=Enter Target Name: rem Add or remove double-quotes if necessary if NOT DEFINED FileName ( Set "FileName-DQ=" goto :DQSkip ) Set "FileName-DQ=%FileName:"=%" if NOT DEFINED FileName-DQ ( Set "FileName=" Set "FileName-DQ=" goto :DQSkip ) if EXIST "%FileName-DQ%" ( if "%FileName-DQ%"=="%FileName-DQ: =%" ( Set "FileName=%FileName-DQ%" ) else ( Set FileName="%FileName-DQ%" ) ) :DQSkip if /I "%FileName-DQ%"=="" Set FileName="%CD%" if /I "%FileName-DQ%"=="CD" Set FileName="%CD%" if /I "%FileName-DQ%"=="EXIT" goto :eof if /I "%FileName-DQ%"=="X" goto :eof if /I "%FileName-DQ%"=="NOEXIT" goto :GetTargetName if DEFINED FileName ( Set /a ARGLVL+=1 CALL :ARGS %FileName% Set /a ARGLVL-=1 ) goto :GetTargetName
I've never used FFMPEG to process audio like that, and since it's not relevant to my ripping of DVDs and Blu Rays I don't see any point in learning.
I haven't tested it yet, I can't actually test it anyway, I wiped my boot drive and all the programs on it.
It doesn't sort files you've dragged and drop onto the .bat. It's possible to make it do that but very, very complicated.
I've removed CHOICE, just pressing enter uses the current directory, which is useless unless you plan on copying the batch to the other hard drive. To exit you type EXIT.
If it doesn't work I'll try to debug it blind.Last edited by ndjamena; 18th May 2014 at 07:44.
Set "Work=%DestFolder%\Work"
Should be:
You specified calling %DestFolder% %D% so I fiddled with the names for a while before deciding on long names. I missed one. -
I see now your answer, thanks: tomorrow I test it.
In the meantime I try to understand a basic procedure in my rudimentary script, please can help me to insert the timecode-reading procedure?
I have make a dir in c:\ called gatto
so c:\gatto have 2 .mxf HD files:
https://dl.dropboxusercontent.com/u/39871584/HD169.MXF
https://dl.dropboxusercontent.com/u/39871584/C0020.mxf
My output dir is v:\automazioneclip\output
dir containig virtualdubmod is v:\automazioneclip\virtualdubmod
and dir for temp files is v:\automazioneclip\virtualdubmod\temp
the script is c:\gatto\s30.bat :
Code:rem *** delete all .avs and .vcf temp file*** del /q v:\automazioneclip\virtualdubmod\temp\*.* rem *** del o:\*.avi is only for debug-mode: it previously delete all .avi generated by virtualdub only for reiterate each time the entire process. Normally this line does not exist*** del o:\*.avi @echo off set "d=" set "done=" set /p "d=Type source path (or press enter for current folder): " if not defined d set "d=%cd%" if not exist "%d%" echo Enter valid path - try again & goto :loop :loop cd /d "%d%" for /f "delims=" %%a in ('dir *.mxf /b /od /a-d') do ( if defined done goto :EOF if not exist "v:\automazioneclip\output\%%~na.*" ( rem ***in this hell I would like to be put the timecode-reader routine and point to %TIMECODE% *** echo Processing %d%\%%~na.mxf rem ***make .vcf in v:\automazioneclip\virtualdubmod\temp*** echo VirtualDub.RemoveInputStreams^(^)^;>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.DeleteComments^(1^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf if NOT "%TimeCode%"=="" echo VirtualDub.video.AddComment^(0x0000000C,"","%TIMECODE%"^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.AdjustChapters^(1^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.SetDepth^(24,24^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.SetMode^(1^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.SetFrameRate^(0,1^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.SetIVTC^(0,0,-1,0^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.SetCompression^(0x31626d64,0,10000 ,0^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.filters.Clear^(^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf rem ***make .avs an put it on v:\automazioneclip\virtualdubmod\temp*** echo DirectShowSource^("%d%\%%~na.mxf"^) >> v:\automazioneclip\virtualdubmod\temp\%%~na.avs rem *** make .avi file by virtualdub and put on v:\automazioneclip\output at the same time the script watch this dir to don't process all .mxf in input dir that are not in v:\automazioneclip\output *** "v:\automazioneclip\virtualdubmod\virtualdubmod.exe" /s"v:\automazioneclip\virtualdubmod\temp\%%~na.vcf" /p"v:\automazioneclip\virtualdubmod\temp\%%~na.avs","v:\automazioneclip\output\%%~na.avi" /r /x goto loop ) )
so I try to modify it so add the timecode function:
but this produce a strange result:Code:rem *** delete all .avs and .vcf temp file*** del /q v:\automazioneclip\virtualdubmod\temp\*.* rem *** del o:\*.avi is only for debug-mode: it previously delete all .avi generated by virtualdub only for reiterate each time the entire process. Normally this line does not exist*** del o:\*.avi @echo off set "d=" set "done=" set /p "d=Type source path (or press enter for current folder): " if not defined d set "d=%cd%" if not exist "%d%" echo Enter valid path - try again & goto :loop :loop cd /d "%d%" for /f "delims=" %%a in ('dir *.mxf /b /od /a-d') do ( if defined done goto :EOF if not exist "v:\automazioneclip\output\%%~na.*" ( for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\virtualdubmod\FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_entries stream^=codec_type^,width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version "%d%\%%~na.mxf" 2^>^&1') DO ( if "%%~g"=="TAG:timecode" set "TIMECODE=%%~h" ) echo Processing %d%\%%~na.mxf echo %timecode% rem ***make .vcf in v:\automazioneclip\virtualdubmod\temp*** echo VirtualDub.RemoveInputStreams^(^)^;>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.DeleteComments^(1^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf if NOT "%TimeCode%"=="" echo VirtualDub.video.AddComment^(0x0000000C,"","%TIMECODE%"^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.AdjustChapters^(1^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.SetDepth^(24,24^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.SetMode^(1^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.SetFrameRate^(0,1^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.SetIVTC^(0,0,-1,0^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.SetCompression^(0x31626d64,0,10000 ,0^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf echo VirtualDub.video.filters.Clear^(^)^;>>v:\automazioneclip\virtualdubmod\temp\%%~na.vcf rem ***make .avs an put it on v:\automazioneclip\virtualdubmod\temp*** echo DirectShowSource^("%d%\%%~na.mxf"^) >> v:\automazioneclip\virtualdubmod\temp\%%~na.avs rem *** make .avi file by virtualdub and put on v:\automazioneclip\output at the same time the script watch this dir to don't process all .mxf in input dir that are not in v:\automazioneclip\output *** "v:\automazioneclip\virtualdubmod\virtualdubmod.exe" /s"v:\automazioneclip\virtualdubmod\temp\%%~na.vcf" /p"v:\automazioneclip\virtualdubmod\temp\%%~na.avs","v:\automazioneclip\output\%%~na.avi" /r /x goto loop ) )
transcoding of the .mxf to .avi is ok (with naming and all) but at the first start of the script, the timecode %timecode% don't exist (echo error) and at the second pass - during processing C0077.mxf - where stored timecode of the previously file ... C0068.mxf
please ndjamena can help me...
tomorrow I try yours script, thanks!
ps: my o:\ is v:\automazioneclip\output (is substed) -
You can't change the value of a variable in a for statement from within said for statement (within the brackets). A value set inside a for statement only becomes set AFTER YOU LEAVE THE FOR STATEMENT BLOCK. It's the same with if statements with brackets or even enclosing code in nothing but brackets. That's why I keep using CALL.
CMD parses the bracketed statement as a single script command and doesn't rebuild the command every time you set a variable. Until you move onto the next command all variables are fixed. CALL and Delayed Expansion are the only ways around that. Or possibly masses of gotos, or masses of ifs...Last edited by ndjamena; 16th May 2014 at 05:15.
