When i play svcd on my DV-444 it behaves strange, i get some light effects(horisontally) on the tv when fast moves on the svcd is played.
Can it be something with PAL ,NTSC? the svcds is almost NTSC.
This on my Nokia 28".
Had an Dansai 852 before and that works fine on the Nokia.
But when i use the DV-444 and playing the same svcds on my old TV it works good.
Also only RGB works, video output gets black & white. (on the Nokia)
Does anyone know what this can be?
Can it be the Macrovision that making these effects on the TV?? I have no video or something coupled to the TV.
I don't think it has nothing to do with PAL or NTSC, I have the same problem with my DV-444, i watched LOTR on SVCD last week and had that problem on each disc. (4 cd:s)
The light "lines" goes downwards horisontally.
I'm also confused about this problem :-?
It's strange that it work on your other TV, I have tested 2 TV:s and i had the same problem with both, and the TV:s support NTSC.
Pioneer DVR-550h Problems
By sliverman in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th May 2011, 03:43 -
PIONEER-610AV-K region problems
By matt2112 in forum DVD & Blu-ray WritersReplies: 8Last Post: 28th Aug 2009, 16:18 -
Pioneer 111D problems
By EGrier in forum DVD & Blu-ray WritersReplies: 12Last Post: 25th Oct 2008, 01:35 -
Digital Cable Box, DVD Recorder, Television Hook Up Problems!
By robdawg70 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 30th Jul 2007, 15:35 -
Pioneer 112D problems
By Xande in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th May 2007, 22:13
