Results 1 to 10 of 10
    May 2014
    República Dominicana
    hi guys
    long'm having trouble encoding with Handbrake. I am using a RPD Encoding
    When I try to put the amount I need Bitrate, immediately tells me this error:
    Error code:
    An Unknown Error has occured.
    System.Globalization.CultureNotFoundException: Culture is not supported.
    Parameter name: culture
    22538 (0x580a) is an invalid culture identifier.
    at System.Globalization.CultureData.GetCultureData(In t32 culture, Boolean bUseUserOverride)
    at System.Globalization.CultureInfo.InitializeFromCul tureId(Int32 culture, Boolean useUserOverride)
    at System.Windows.Input.InputLanguageSource.get_Curre ntInputLanguage()
    at System.Windows.Input.InputLanguageManager.get_Curr entInputLanguage()
    at System.Windows.Documents.TextSelection.EnsureCaret (Boolean isBlinkEnabled, Boolean isSelectionActive, CaretScrollMethod scrollMethod)
    at System.Windows.Documents.TextSelection.System.Wind ows.Documents.ITextSelection.UpdateCaretAndHighlig ht()
    at System.Windows.RoutedEventArgs.InvokeHandler(Deleg ate handler, Object target)
    at System.Windows.EventRoute.InvokeHandlersImpl(Objec t source, RoutedEventArgs args, Boolean reRaised)
    at System.Windows.UIElement.RaiseEventImpl(Dependency Object sender, RoutedEventArgs args)
    at System.Windows.UIElement.RaiseTrustedEvent(RoutedE ventArgs args)
    at System.Windows.Input.InputManager.ProcessStagingAr ea()
    at System.Windows.Input.KeyboardDevice.ChangeFocus(De pendencyObject focus, Int32 timestamp)
    at System.Windows.Input.KeyboardDevice.Focus(Dependen cyObject focus, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
    at System.Windows.Input.KeyboardDevice.Focus(IInputEl ement element)
    at System.Windows.UIElement.Focus()
    at System.Windows.Documents.TextEditorMouse.MoveFocus ToUiScope(TextEditor This)
    at System.Windows.Documents.TextEditorMouse.OnMouseDo wn(Object sender, MouseButtonEventArgs e)
    at System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e)
    at System.Windows.Input.InputProviderSite.ReportInput (InputReport inputReport)
    at System.Windows.Interop.HwndMouseInputProvider.Repo rtInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
    at System.Windows.Interop.HwndMouseInputProvider.Filt erMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at System.Windows.Interop.HwndSource.InputFilterMessa ge(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at MS.Win32.HwndSubclass.DispatcherCallbackOperation( Object o)
    at System.Windows.Threading.ExceptionWrapper.Internal RealCall(Delegate callback, Object args, Int32 numArgs)
    at MS.Internal.Threading.ExceptionFilterHelper.TryCat chWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
    Any idea?
    regards
    Have you tried google search that error? I have never seen that before.
    Tried latest beta/nightly build of handbrake?
    Or try Vidcoder. It's based on handbrake.
  3. "System.Globalization.CultureNotFoundException : Culture is not supported."
    Is a .Net error, seems like handbrake is looking for some 'locale' (<> Culture) which is not available on your system.
    May 2014
    Hello
    The strange thing is that the Vidcode gives me the same error when trying to set the bitrate I want ..
    Mmm .. ``locale`` ? .. you have any idea how I can fix that?
    thanks
  5. Not a .Net programmer, but wild guess: try if it helps to change your system locale to English. (also make sure the latest .Net Runtime is installed)
    my guess is that they check whether '.' or ',' is used to split numbers and decimals.
    Shouldn't be too hard for the developers to write a workaround for this, so reporting it to the developers of the tools might be a good idea.
    May 2014
    ok I'll try, thanks
    canada
    Do you get that error on files that are on your system or just net based or both?
    May 2014
    In all I try to encode..
    i try MeGUI me and this works well, but is slower than my grandmother
    Mar 2011
    Nova Scotia, Canada
    Originally Posted by K40s View Post
    ....i try MeGUI me and this works well, but is slower than my grandmother
    There's no particular reason it should be that much slower except for the default settings.
    Despite what the people who make these encoders tell you, they're all about the same regarding speed.
    May 2014
    The problem is that MeGUI does two stages of encoding. In the settings there is the option to increase to more than 2 steps, but it is decreased to less than 2. Such is the problem of MeGUI.
    While Handbrake encoding makes the same quality (for me) on only one stage (about 45 minutes)
