Bought Bandicam. Can anyone recommend settings for a conference? Probably just people sitting at a table plus some slides. Not sure of the content, really.Audio recommendations too, please. I have 338.3 GB available. And I think I should go for a format that's compatible with smart phones.
It's not a movie, so shouldn't I raise the frame rate to 60? Or 59.940?
Also, for audio, why go above CD quality (44100)? -
I would say start by matching your framerate to your source. What camera(s) are you using?
Download AmarecTV, run it and post screenshot from SOURCE TAB. Its show all resolutions from your Webcam/Card
