Page 2 of 2
FirstFirst 1 2
Results 31 to 42 of 42
  1. ndjamena for kindess: question2
    if I manually want do a ffprobe in a C0020.mxf file with same option as you used in your script
    FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_entries stream^=codec_type^,width^,height^,sample_aspect_r atiotream_disposition^=:format_tags^=timecode^,company _name^,product_name^,product_version "%~1" 2^>^&1'
    what is the command line to generate a .txt file?
  2. Member Cornucopia's Avatar
    I hate to say this, but marcorocchini, doesn't this all sound an awful lot like a "rube goldberg machine" approach to your problem?
    Sep 2012
    Australia
    He likes cats...
    FFProbe -hide_banner -loglevel fatal -print_format default=nk=1:nw=1 -show_entries format_tags=timecode "%~1" 1>"%~dpn1.txt"
    will print just the time code into a .txt file
    an equals sign inside the for options double quotes is seen as an operator if not escaped, hence = should be written as ^=
    I'm trying to write an AVISynth script to remove the yellow colour from some burnt in subtitles with as little chance for error as possible at the moment. It's much more interesting then anything you're doing. Not that I have any idea what you're doing...
    FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_entries stream^=codec_type^,width^,height^,sample_aspect_r atiotream_disposition^=:format_tags^=timecode^,company _name^,product_name^,product_version "%~1" 1>"%~dpn1.txt"
  4. Originally Posted by Cornucopia View Post
    mmmmm You're jealous of my NLE for cats! Speed Razor HD cats 3.0 revenge
  5. Code:
    FFProbe -hide_banner -loglevel fatal -print_format default=nk=1:nw=1 -show_entries format_tags=timecode c0020.mxf 1>ffp.txt
    it generate the only timecode as exactly requested, perfects! thanks
  6. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    marcorocchini, if you wish to try the GUI it is at http://files.videohelp.com/u/214352/Timecode2txt.zip. It will do batch also if you have more files in the folder. If you throw a clinker in like a text file, it will wait 10 seconds and give you a message. The text files are saved by the name of the original file with the .TXT extension. The from and to location folders are drag and drop but individual files are not since I didn't see the need.
Name:	ScreenHunter_67 May. 19 00.39.jpg
    I have a Windows 7 computer and it works on that so give it a try if you wish.
    Bud
  7. nice program, in xp seems work well
    thanks ^^
    Feb 2014
    Mumbai
    Originally Posted by marcorocchini View Post
    mm so for example:
    I have a file C0020.mxf and for this file I would like generate a .txt that contatins only the timecode:
    if I do:
    ffmpeg -i c0020.mxf -f ffmetadata metadata.txt
    metadata.txt is (also in attachement):
    ;FFMETADATA1
    uid=41821e00-3664-05c1-0270-08004602023b
    generation_uid=41821e00-3664-05c2-0270-08004602023b
    company_name=SONY
    product_name=Opt
    product_version=1.22
    product_uid=060e2b34-0401-0103-0e06-012002010300
    modification_date=2013-05-24 22:12:18
    timecode=01:34:21:15
    so the script should isolate 01:34:21:15 from all the rest
    I should do a script that via commandline I type:
    tc.bat C0020.mxf
    and it generate a .txt that have 01:34:21:15
    can you help to do this? thanks
    The reply is late but I'm pleased to present you a Java class which can do this.
    Just rename the TimeCode.zip to TimeCode.class (Case sensitive)
    and run on terminal using
    java TimeCode
    This requires the metadata.txt to be placed in the same folder
    This is the sample output
    C:\Users\sandesh\workspace\HelloWorld\bin>java TimeCode
    ;FFMETADATA1
    company_name=SONY
    product_name=Opt
    01:34:21:15
    Edit :
    I forgot to write the timestamp to the text file, so I updated the java code.
  9. oh thanks, winzip get me an error during decompress timecode.zip (not seem a "valid winzip archive") but I try others unzipper
    Feb 2014
    Mumbai
    Don't extract it ... Just rename TimeCode.zip to TimeCode.class
  11. I have do it but is not associated to nothing in my pc, I have the old xp^^
  12. it's a Java class file so it requires a Java runtime to be installed
