Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 66
  1. Originally Posted by videobruger View Post
    @Zeggo
    Perhaps attach the srt together with MediaInfo (View -> Text) for the MP4 file to a post.
    Here's MediaInfo - SRT file attached:
    General
    Complete name : E:\--- Movies to burn to DVD ---\Matador\Matador_1978_S01E01-DenRejsende.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 1.03 GiB
    Duration : 45mn 19s
    Overall bit rate : 3 250 Kbps
    Encoded date : UTC 2011-05-10 05:48:37
    Tagged date : UTC 2011-05-10 06:45:37
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : 20
    Duration : 45mn 19s
    Bit rate mode : Variable
    Bit rate : 3 164 Kbps
    Maximum bit rate : 4 831 Kbps
    Width : 720 pixels
    Height : 544 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.323
    Stream size : 1.00 GiB (97%)
    Writing library : em4v 4.1.6.5
    Language : English
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 45mn 19s
    Source duration : 45mn 19s
    Bit rate : 80.4 Kbps
    Maximum bit rate : 95.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Stream size : 26.1 MiB (2%)
    Source stream size : 26.1 MiB (2%)
    Language : English
    Menu
    00:00:00.000 : Chapter 1
    00:05:43.720 : Chapter 2
    00:14:13.320 : Chapter 3
    00:18:29.680 : Chapter 4
    00:23:42.720 : Chapter 5
    00:31:58.800 : Chapter 6
    00:35:30.960 : Chapter 7
    00:38:49.080 : Chapter 8
  2. Your .srt is Unicode encoded while Vidcoder (probably) expect UTF-8. Open the .srt in Notepad and change the encoding at the bottom of the Save-As Window.
  3. Thanks videobruger - that did the trick
  4. I have the same trouble as @Zeggo. I have an MP4 file and a separate SRT file. I need to hardcode the subs in for streaming.
    The subs work when playing on a local media player with sub file selected.
    I run VidCoder 1.5.33.0. I've checked "Burn in" but no matter what I do, no subs are being written into the new output MP4.
    Any suggestions on what could be the issue? And how to fix?
    I attach here the .srt and Media Info. of the mp4.
    General
    Complete name : C:\Users\tiendq\Downloads\LEGO® Youngest Builders - Let’s Build Happy.mp4
    Format : MPEG-4
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 9.65 MiB
    Duration : 1mn 0s
    Overall bit rate : 1 347 Kbps
    Writing application : Lavf54.63.104
    Video
    Format : AVC
    Format profile : Main@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Duration : 1mn 0s
    Bit rate : 1 217 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.053
    Stream size : 8.71 MiB (90%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1mn 0s
    Bit rate mode : Constant
    Bit rate : 126 Kbps
    Frame rate : 43.066 fps (1024 spf)
    Stream size : 922 KiB (9%)
    Default : Yes
    Alternate group : 1
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    General
    Format : MPEG-4
    Duration : 1mn 0s
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 1mn 0s
    Height : 720 pixels
    Color space : YUV
    Bit depth : 8 bits
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1mn 0s
    Bit rate : 126 Kbps
    Default : Yes
    Alternate group : 1
    Try rename your subtitle file....remove the special characters and just name it lego.srt. THen import it in vidcoder.
    If that fails try hardcode with Xmedia Recode.
  6. @Baldrick: Tks for your help. I've renamed the srt file but it doesn't work.
    I've tried with Format Factory, the subs are perfect but the video quality is not as good as with Vidcoder.
  7. @Baldrick: I've tried with Xmedia Recode, it works perfect. Tks you a lots.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Be sure to use h264/avc video in format factory or xmedia recode. And decrease the constant quality/quantizer value for better quality or increase the bitrate under the video encoding settings.
  9. Originally Posted by Baldrick View Post
    Tks you a lots. I will try
  10. Thanks for the great software guys!
    Is there a way to change the color of the subtitles when hardcoding?
    I'm trying to sub a black and white video and the default (white) color isn't adecuate for it
    The program itself lacks this configuration, but maybe I can add a line in a cfg file or something?
  11. .srt has font color as a formatting option.
  12. I'm a MEGA Super Moderator Baldrick's Avatar
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    Updated the guide with:
    You can use Subtitle Edit to change the color in your srt subtitle, In Subtitle Edit open the srt, Mark all (Ctrl+A). Rigth click. Select Color. Save as a new srt. Import it in Vidcoder.
    Thanks to videobruger.
  14. Is there a way to automatically burn .srt when there exists an .srt file with the same filename as the movie being re-coded (e.g., mymovie.mp4 is being re-coded and there exists a mymovie.srt file)?
    I would like to burn subtitles during re-coding of a list of files without having to go through the addition of subtitles manually.
  15. I'm a MEGA Super Moderator Baldrick's Avatar
    I don't think so. But you could try click on Picker:None (at top right in latest vidcoder beta) and choose Subtitle selection: First or All and see if it autoloads any subs.
  16. Thanks--I could not get it to work (tried some other picker settings as well).
  17. is it possible to change the subtitles' settings? (size, font etc) because they are not very easily readable if ur bed is not close to the pc..
  18. is it possible to change the subtitles' settings?
    Even though some players/software may support formatting in .srt beside the basics bold, italic, underline, color you should
    never expect it.
    Instead convert your .srt to ass (Aegisub/Subtitle Edit), do the formatting and mux the .ass with the video with MKVToolnix GUI and you can hardcode it in VidCoder/HandBrake.
  19. Originally Posted by videobruger View Post
    never expect it.
    unless i just make everything bold by adding the bbcode. that will work for me, thanks anyways.
    Feb 2014
    Croatia
    My srt file is ANSI. Can I change the settings in VidCoder? From UTF-8 to what exactly: there are several ANSI options...
  21. I'm a MEGA Super Moderator Baldrick's Avatar
    Wont it work fine with default ASCII? Or do you get strange characters?
  22. Member
    Feb 2014
    Croatia
    Actually, I get some character missing.
  23. I'm a MEGA Super Moderator Baldrick's Avatar
    Try ISO-8859-2 then.
    ISO-8859-2 Latin 2
    Latin-written Slavic and Central European languages: Czech, German, Hungarian, Polish, Romanian, Croatian, Slovak, Slovene.
    Or maybe try convert your srt to utf8.
  24. Member
    Feb 2014
    Croatia
    I tried with ISO-8859-2 and now only 1 character isn't showing, "ž"!
    It's definitely an improvement, but I'm still opened for suggestions.
  25. Member
    Feb 2014
    Croatia
    Ok, I tried converting the subtitle file to UTF8 and worked just fine, so that's sorted. Now I have another question: why is my output file significally larger than the input file? Input file is 1.49 GB and output is 2.75 GB! I didn't touch anything in Vidcoder settings. Is there a way to avoid such change in file size? Here's the Mediainfo slip from the input file, if it helps.
  26. Member
    Feb 2014
    Croatia
    And here's the output file:
  27. Member Bernix's Avatar
    Apr 2016
    Europe
    You didn't do nothing, but since vidcoder has not direct stream copy for video, your compression settings gets almost twice bitrate. Check overall bitrate in last post. 4611 and in first it is about 2500. You will hurt quality size when reencoding video, which is must be when hardcoded subtitles. To keep same size, use 2pass encoding with same video bitrate as original video has. And it has around 2000 Kbps in your original post.
    And do nothing actually spoiled your audio quality. AAC codec in vidcoder isn't much great, if you want your original quality keep, so in audio tab set it to auto passthrough.
    Bernix
  28. Member
    Feb 2014
    Croatia
    Bernix, that nearly did the trick, although I couldn't find 2pass encoding in the settings. All in all, the result is more than satisfactory! Tnx!
  29. Member Bernix's Avatar
    Apr 2016
    Europe
    Hi,
    glad it helped. Two pass encoding is in Video encoding tab. It is above average bitrate. You can set final size of video in MB. Two pass is much more better than average bitrate in terms of quality at same size. I suggest next time use this with turbo first pass, and of course switch to constant frame rate instead of variable bitrate that is default(lots of trouble) and frame rate same as source.
    If you have no trouble with Variable frame rate VFR it doesn't mean others can't or your other devices can have problem as well.
    Bernix
