I am trying to convert a DVD-VR source to DVD video by DVD Flick. I checked "copy MPEG-2 streams" in the options, but it is still reencoding the file. It takes more than half an hour. How can I prevent re-encoding? I attached the logs
Code:DVD Flick error log Version 1.3.0.7 build 738 Windows 6.2 build 9200 *** Project info EncodeProf 3 Threads 4 OverScan 0, 3 TargetRate 0 TargetFormat 1 TargetSize 4 CreateISO 0 CustRate 1000 EnableBurn 0 EraseRW 1 HalfRes 0 LoopPlayb 1 AutoPlayMenu 1 MenuTemplt None VolumeMod 100 WhenPlayed 0 *** Warnings given *** Titles 0 - VR_MOVIE ChaptCount -1 ChaptInt -1 ChaptSource 1 TargetAR 1 ThumbIndex 720 *** Project sources F:\DVD_RTAV\VR_MOVIE.VRO Stream 0 (2) Dur 7201.16 StartT 0.470267 Compr mpeg2video BitR 4200 352x480 29.97 FPS PAR 1 SAR 0.7333333 Stream 1 (1) Dur 7201.16 StartT 0.470267 Compr ac3 BitR 256 Chnnls 2 SRate 48000 Delay -160 *** dvdflick.log 12:28:38: DVD Flick 1.3.0.7 build 738 12:28:38: Calculating stream sizes... 12:28:38: Disc space used : 4493524 KB 12:28:38: Average bitrate : 4859 Kbit/s 12:28:38: Total duration : 2:00:01 hours 12:28:38: 1 title(s). 12:28:38: Using Best encoding profile. 12:28:38: NTSC target format. 12:28:38: CPU: Intel(R) Core(TM) i7-3820QM CPU @ 2.70GHz 12:28:38: Threadcount: 4 12:28:38: Encoding video... 12:28:38: Title 0, source 0 12:28:38: Source : F:\DVD_RTAV\VR_MOVIE.VRO 12:28:38: Properties : 352x480, 0.73:1, 29.97 FPS, mpeg2video, 7201.16 seconds 12:28:38: Target BitRate : 4859 Kbit\s 12:28:38: Re-encoding 12:28:38: -i "F:\DVD_RTAV\VR_MOVIE.VRO" -vcodec mpeg2video -s 720x480 -r 29.97 -g 14 -bufsize 1835008 -packetsize 2048 -muxrate 10080000 -aspect 16:9 -minrate 4809k -maxrate 4809k -b 4809k -preme 1 -precmp 2 -subcmp 8 -mbcmp 8 -cmp 1 -sws_flags spline+accurate_rnd -trellis 1 -mbd 2 -sc_threshold -3000 -dc 8 -an -threads 4 -fflags +genpts -f mpeg2video -shortest -map 0:0 "C:\Users\a\Documents\dvd\0.0.m2v" *** ffmpeg_video_title0_source0.txt 153688kB time=261.86 bitrate=4807.9kbits/s frame= 7892 fps= 91 q=2.0 size= 154528kB time=263.30 bitrate=4807.9kbits/s frame= 7934 fps= 91 q=2.0 size= 155350kB time=264.70 bitrate=4807.9kbits/s frame= 7983 fps= 91 q=2.0 size= 156310kB time=266.33 bitrate=4807.9kbits/s frame= 8031 fps= 91 q=2.0 size= 157250kB time=267.93 bitrate=4807.9kbits/s frame= 8078 fps= 91 q=2.0 size= 158171kB time=269.50 bitrate=4807.9kbits/s *** Project destination folder 0.0.m2v 162247946 dvdflick.log 1320 errorlog.txt 3326 ffmpeg_video_title0_source0.txt 15990 *** Drives C - - 2 FS NTFS AvailSpace 269608 FreeSpace 269608 TotalSize 488034 F - $ DV-HR400 Basis Volume $ - 4 FS UDF AvailSpace 2352 FreeSpace 2352 TotalSize 4471
Thank you for the tip. Selecting "half horizontal resolution" option solved the problem.
