Hi - I've not encountered this before, a vid that plays fine in my 2 players (WMP and PotPlayer) but not with Avidemux (both the portable and the installed copies I have). The audio is garbled junk and there's very slight distortion of the picture. As a possible fix, I installed Shark007 but that changed nothing. Loading the vid to Boilsoft Splitter gives a message 'seems the avi codec your file is using is not installed properly'. I'd really like to get this vid edited (with Avidemux) so if anyone can suggest what the problem/cure is I'd be very grateful. Here's Mediainfo:
Format : AVI
Format settings : rec
File size : 274 MiB
Duration : 24mn 4s
Overall bit rate : 1 592 Kbps
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 24mn 4s
Bit rate : 1 442 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.188
Stream size : 248 MiB (91%)
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 24mn 4s
Bit rate mode : Variable
Bit rate : 137 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 23.5 MiB (9%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.60 video frame)
my guess would be this:
what created it?Width : 640 pixels
Height : 480 pixels
When you load file, is Avidemux alerting you that it is 'building time map' and 'unpacking bit stream' prior to seeing video in Avidemux?
try this,,
Menu Items-> Edit->Preferences
Display(tab)
Video Display: Default Raster (select)
Enable openGL support (check box)
Threading(tab)
Prioritisation--> Playback priority: select 'HIGH'
Check info ((i) button) to ensure it matches MediaInfo output
