  1. Hi, last week i enter the new word of burning svcd and vcd with Nero ( i was the 5578 version) and buy the Mustek 520DVD player.
    Whats fun... All is ok.. Burning 3 SVCD with NEro and all function right!
    Yesterday i install on my computer the last version of Nero (the 5580) and (only for the cover!!) the easy cd-creator 5.0 (i select custom and only cover program)... Then reboot... make a new SVCD.. and...
    Nothing work...!!! I explain.. Over the DVD computer the new CD burning is function correct.. but over the DVD Player... i see nothing!!!!
    It load disc.. it play disc.. but over the screen.. nothing to see!!!
    Can anyone help me?
    Oh yes , i come back and reinstall Nero 5578, and remove Easy CD Creator... reboot.. but nothing change!!!
    Help Plsssss...
    The Sharky.... over the sea....
    May 2001
    There is a problem with the install program for NERO 5.5.8.0. You basically have to COMPLETELY DE-INSTALL the previous version, then install 5.5.8.0 (I had trouble with it recognizing my DVD recorder until I did the uninstall/ reinstall).
    Make sure that your are creating an ISO 9660 disk ONLY (for maximum compatibility with stand-alones). That means NO JOLIET FEATURES. This is set in the PREFERENCES menu in NERO.
    If it worked before, this should help you get it working again.
  3. Thanks.. all is functionality!!!
    I remove Nero 5580 and then delete the directory ahead.. reinstall...
    and OK!! Now is good!
    Thanks a lot.. Bye
