  1. This problem only with one film
    Format                                   : Matroska
    Format version                           : Version 4 / Version 2
    File size                                : 16.9 GiB
    Duration                                 : 1h 50mn
    Overall bit rate                         : 21.8 Mbps
    Movie name                               : ReJIiZ by BenderBEST
    Encoded date                             : UTC 2014-05-04 06:30:53
    Writing application                      : mkvmerge v6.9.1 ('Blue Panther') 32bit built on Apr 18 2014 18:15:44
    Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
    Video
    Format                                   : VC-1
    Format profile                           : AP@L3
    Codec ID                                 : WVC1
    Codec ID/Hint                            : Microsoft
    Duration                                 : 1h 50mn
    Bit rate                                 : 19.9 Mbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate                               : 23.976 fps
    Original frame rate                      : 29.970 fps
    Bits/(Pixel*Frame)                       : 0.400
    Stream size                              : 15.4 GiB (91%)
    Title                                    : 1920x1080, VC-1 (HDTracker.ru)
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Codec ID                                 : A_DTS
    Duration                                 : 1h 50mn
    Bit rate mode                            : Constant
    Bit rate                                 : 1 510 Kbps
    Channel(s)                               : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 24 bits
    Stream size                              : 1.17 GiB (7%)
    Language                                 : English
    Default                                  : No
    Forced                                   : No
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Make a script using this:
    LoadPlugin("your path here\avss.dll")
    dss2("video.mkv", fps=23.976).AssumeFPS(24000,1001)
    Try and replay.
  3. Thank you my friend
    I download ffdshow . Now opened film
