Hello, after some months without encoding, i started encoding again but when i tried to encode a mkv video with soft subs to a mp4 with hard subs an error showed up(video encoding frozen in 0.00% and then after 10 minutes aborts the encoding)... i used to use Xvid4PSP 5.10 before, doing the same process without problems, but now i cant encode mkv to mp4. I think the problem is that i changed w8 to w8.1 because when i had w8.0 this problem never showed up. Questions are:
Does any body else has this problem or its a problem related to my pc???
Does this problem has a solution???
Thanks.![]()
Have you tried with a different video source? It might just be a problem with that mkv.
Yes, already tried using a different mkv but nothing changed either...
