I use MeGUI as sort of a "better compressor" than my video editor, giving videos a 2nd run-through on One-Click Encoding. The source files are already .MP4 and I just want them to come out as another .MP4 at a smaller size.
I can't figure out this AVS stuff at all so One-Click is all I use.
My problem is that I just updated MeGUI to 2418, and now when I encode my .MP4s, it says something called "Muxing MKV", finishes that, and the worker window closes and a huge red X appears over my toolbar image for MeGUI. When I look in the logs it says this:
Preliminary log file only. During closing of MeGUI the well formed log file will be written.
Seems if I render the video in .AVI instead, it works fine.-[Information] Versions
--[Information] [4/30/2014 10:07:54 PM] MeGUI: 2418
--[Information] [4/30/2014 10:07:54 PM] Operating System: Windows 7 Premium Edition x64 (6.1.0.7600)
--[Information] [4/30/2014 10:07:54 PM] .Net Framework: 4.0 (4.0.30319)
--[Information] [4/30/2014 10:07:54 PM] AviSynth: 2.5.8.5 (21-12-2008)
--[Information] [4/30/2014 10:07:54 PM] AvisynthWrapper: (02-01-2009)
--[Information] [4/30/2014 10:07:54 PM] Haali Matroska Splitter: 1.13.138.14 (14-04-2013)
--[Information] [4/30/2014 10:07:54 PM] Haali DSS2: (14-04-2013)
--[Information] [4/30/2014 10:07:54 PM] ICSharpCode.SharpZipLib: 0.85.5.452 (08-08-2008)
--[Information] [4/30/2014 10:07:54 PM] LinqBridge: 1.0.0.0 (28-05-2009)
--[Information] [4/30/2014 10:07:54 PM] MediaInfo: 0.7.64.0 (05-07-2013)
--[Information] [4/30/2014 10:07:54 PM] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
--[Information] [4/30/2014 10:07:54 PM] MessageBoxExLib: 1.0.2218.28317 (20-12-2008)
--[Information] [4/30/2014 10:07:54 PM] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
--[Information] [4/30/2014 10:07:54 PM] 7z: 9.20 (18-11-2010)
-[Information] Update detection
--[Information] [4/30/2014 10:07:55 PM] Connecting to server: http://megui.xvidvideo.ru/auto/stable/
--[Information] [4/30/2014 10:07:55 PM] All files are up to date
-[Information] OneClick
--[Information] [4/30/2014 10:08:19 PM] MediaInfo
---[Information] File: Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4
-[Information] Format: MPEG-4
-[Information] FormatString: MPEG-4
-[Information] FileSize: 598166033
-[Information] PlayTime: 00:19:42.195
---[Information] General
-[Information] ID: 1
-[Information] StreamOrder: 0
-[Information] Width: 960
-[Information] Height: 720
-[Information] FrameCount: 35466
-[Information] FrameRate: 30.000
-[Information] FrameRateOriginal:
-[Information] FrameRateMode: CFR
-[Information] ScanType: Progressive
-[Information] Codec: AVC
-[Information] CodecString: AVC
-[Information] Bits Depth: 8
-[Information] Format: AVC
-[Information] AspectRatio: 1.333
-[Information] AspectRatioString: 4:3
-[Information] Delay: 0
-[Information] Title:
-[Information] Language: en
-[Information] LanguageString: English
-[Information] Default:
-[Information] DefaultString:
-[Information] Forced:
-[Information] ForcedString:
---[Information] Video
-[Information] ID: 2
-[Information] StreamOrder: 1
-[Information] Format: AAC
-[Information] FormatProfile: LC
-[Information] FormatSettingsSBR:
-[Information] FormatSettingsPS:
-[Information] SamplingRate: 44100
-[Information] SamplingRateString: 44.1 KHz
-[Information] Channels: 2
-[Information] ChannelsString: 2 channels
-[Information] ChannelPositionsString2: 2/0/0
-[Information] BitRateMode: CBR
---[Information] Audio
-[NoImage] File 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4': container: QuickTime/MP4 [is_providing_timecodes:1]
-[NoImage] Track ID 0: video (avc1) [packetizer:mpeg4_p10_video language:eng]
-[NoImage] Track ID 1: audio (mp4a) [language:eng]
--[Information] [4/30/2014 10:08:31 PM] MkvInfo
--[Information] [4/30/2014 10:08:31 PM] Video: Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4
--[Information] [4/30/2014 10:08:31 PM] Audio: Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4 ([2] - AAC - 2 channels / 44.1 KHz / English)
-[Information] Log for job1204 (mux, Psycho6.mp4 -> Psycho6.mkv)
--[Information] [4/30/2014 10:08:36 PM] Started handling job
--[Information] [4/30/2014 10:08:36 PM] Preprocessing
--[Information] [4/30/2014 10:08:36 PM] MediaInfo
--[Information] [4/30/2014 10:08:36 PM] Job commandline: "Z:\Aperture Science Research Documents\ArmoredChocobo\MeGUI_2153_x86\tools\mkvmerge\mkvmerge.exe" -o "Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\wmr4s qa5.res\Psycho6.mkv" "Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4" "--compression" "0:none" --ui-language en
--[Information] [4/30/2014 10:08:36 PM] Process started
--[Information] [4/30/2014 10:08:36 PM] Standard output stream
--[Information] [4/30/2014 10:08:36 PM] Standard error stream
---[Information] [4/30/2014 10:08:36 PM] mkvmerge v6.5.0 ('Isn't she lovely') built on Oct 20 2013 12:50:05
---[Information] [4/30/2014 10:08:36 PM] 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4': Using the demultiplexer for the format 'QuickTime/MP4'.
---[Warning] [4/30/2014 10:08:36 PM] Warning: 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4' track 0: The AVC video track is missing the 'CTTS' atom for frame timecode offsets. However, AVC/h.264 allows frames to have more than the traditional one (for P frames) or two (for B frames) references to other frames. The timecodes for such frames will be out-of-order, and the 'CTTS' atom is needed for getting the timecodes right. As it is missing the timecodes for this track might be wrong. You should watch the resulting file and make sure that it looks like you expected it to.
---[Information] [4/30/2014 10:08:37 PM] 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4' track 0: Using the output module for the format 'AVC/h.264'.
---[Information] [4/30/2014 10:08:37 PM] 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4' track 1: Using the output module for the format 'AAC'.
---[Information] [4/30/2014 10:08:37 PM] The file 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\wmr4s qa5.res\Psycho6.mkv' has been opened for writing.
---[Information] [4/30/2014 10:08:37 PM] 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 960/720.
---[Information] [4/30/2014 10:09:32 PM] The cue entries (the index) are being written...
---[Information] [4/30/2014 10:09:32 PM] Muxing took 56 seconds.
--[Error] [4/30/2014 10:09:32 PM] Process exits with error: 1
--[Information] [4/30/2014 10:09:32 PM] Job completed
--[Information] [4/30/2014 10:13:23 PM] MediaInfo
--[Information] [4/30/2014 10:13:51 PM] MkvInfo
--[Information] [4/30/2014 10:13:51 PM] Video: Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4
--[Information] [4/30/2014 10:13:51 PM] Audio: Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4 ([2] - AAC - 2 channels / 44.1 KHz / English)
-[Information] Log for job1208 (mux, Psycho6.mp4 -> Psycho6.mkv)
--[Information] [4/30/2014 10:13:57 PM] Started handling job
--[Information] [4/30/2014 10:13:57 PM] Preprocessing
--[Information] [4/30/2014 10:13:57 PM] MediaInfo
--[Information] [4/30/2014 10:13:57 PM] Job commandline: "Z:\Aperture Science Research Documents\ArmoredChocobo\MeGUI_2153_x86\tools\mkvm erge\mkvmerge.exe" -o "Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\1z5ki bpd.350\Psycho6.mkv" "Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4" "--compression" "0:none" --ui-language en
--[Information] [4/30/2014 10:13:57 PM] Process started
--[Information] [4/30/2014 10:13:57 PM] Standard output stream
--[Information] [4/30/2014 10:13:57 PM] Standard error stream
---[Information] [4/30/2014 10:13:57 PM] mkvmerge v6.5.0 ('Isn't she lovely') built on Oct 20 2013 12:50:05
---[Information] [4/30/2014 10:13:58 PM] 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4': Using the demultiplexer for the format 'QuickTime/MP4'.
---[Warning] [4/30/2014 10:13:58 PM] Warning: 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4' track 0: The AVC video track is missing the 'CTTS' atom for frame timecode offsets. However, AVC/h.264 allows frames to have more than the traditional one (for P frames) or two (for B frames) references to other frames. The timecodes for such frames will be out-of-order, and the 'CTTS' atom is needed for getting the timecodes right. As it is missing the timecodes for this track might be wrong. You should watch the resulting file and make sure that it looks like you expected it to.
---[Information] [4/30/2014 10:13:58 PM] 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4' track 0: Using the output module for the format 'AVC/h.264'.
---[Information] [4/30/2014 10:13:58 PM] 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4' track 1: Using the output module for the format 'AAC'.
---[Information] [4/30/2014 10:13:58 PM] The file 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\1z5ki bpd.350\Psycho6.mkv' has been opened for writing.
---[Information] [4/30/2014 10:13:58 PM] 'Z:\Aperture Science Research Documents\ArmoredChocobo\Psychonauts\Psycho6\Psych o6.mp4' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 960/720.
---[Information] [4/30/2014 10:14:43 PM] The cue entries (the index) are being written...
---[Information] [4/30/2014 10:14:43 PM] Muxing took 46 seconds.
--[Error] [4/30/2014 10:14:43 PM] Process exits with error: 1
--[Information] [4/30/2014 10:14:44 PM] Job completed
What's going on, how do I fix it (with details please), and why is it muxing my .MP4 to MKV when I want a .MP4 as a result anyway? It seems like it's breaking just as soon as it finishes making an MKV of my file.
My settings for encoding (in one click encoder):
Video - x264:
- Bitrate 400, No Advanced settings, default playback (it goes on the internet/my IPod touch 4)
Audio - Nero AAC
Output - .MP4 only, 85Mb
All I want it to do is compress my .MP4 (about 400-500 Mb) down to a 80-90Mb video file. I was able to do it in the older builds, but not this new one.
I found a simple guide to making an AVS script and now the worker window doesn't close automatically at "Muxing MKV", but now gives me a file that says "(file name)_muxed" and it has absolutely no audio.
The only thing changed on the script itself is I changed "audio=false" to "audio=true".
Also I downloaded an older built of MeGUI and it works exactly like it did before I updated and ran into this mess. Of course, the moment I ran it it tried to update itself to 2418. I even let everything BUT the core file update, and it still worked just fine, it's the core files. How can I keep it from auto-updating that.Last edited by ArmoredChocobo; 1st May 2014 at 02:31.
