Results 1 to 28 of 28
    Apr 2014
    ardabil, iran
    hi, i have a HDR-XR150 handycam which records videos with the following information
    Complete name : --------------------------------------
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 296 MiB
    Duration : 1mn 50s
    Overall bit rate : 22.4 Mbps
    Maximum Overall bit rate : 24.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=2, N=13
    Codec ID : 27
    Duration : 1mn 50s
    Bit rate mode : Variable
    Bit rate : 21.2 Mbps
    Maximum bit rate : 22.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.410
    Stream size : 280 MiB (95%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : 129
    Duration : 1mn 50s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -80ms
    Stream size : 3.38 MiB (1%)
    Text
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 1mn 50s
    as you can see it has caption which is recording time and date. i want to edit this clip in vegas pro and make this caption appear on the video permanently, like a water mark. not a caption stream which you can select to see the caption or not.
  2. Some retail options:
    DVMP Pro 5
    https://www.videohelp.com/tools/DV-Media-Player
    http://www.dvmp.co.uk/
    Visual AVCHD Time Stamp (vATS)
    https://www.videohelp.com/tools/Visual-AVCHD-Time-Stamp
    http://www.dts8888.com/vATS/vats.htm
    A more difficult but free way to do is to use avchd2srt to extract srt subs (which will contain the date,time & GPS info if applicable), then you can hardcode a transparent clip with masksub() in avisynth to use as an overlay in vegas (there are some GUI's at the end of the thread)
    https://forum.videohelp.com/threads/316229-Export-AVCHD-frame-specific-metadata-to-subtitles
    Or you can import srt subs direct with vegasaur
    http://vegasaur.com/text-generation-wizard
    Apr 2014
    ardabil, iran
    DVMP Pro 5
    the two programs you just mentioned at first, do they work with vegas or i should edit in them?
  4. Originally Posted by darknesslord View Post
    I don't understand what you are asking
    They don't work directly with vegas (they are separate programs) . You can hardcode the data, then import into vegas. Vegasaur is sort of a plugin for vegas that directly works within vegas that you can import srt subs (if you extracted the date/time/gps info with other methods)
    Apr 2014
    ardabil, iran
    i downloaded the avchd2srt, how to i extract merdata in srt?
    Apr 2014
    ardabil, iran
    i extracted the captions, continuing the rest
    thanks alot
    Apr 2014
    ardabil, iran
    i downloaded avisynth and 32bit version of vsfilter.dll
    and made a .avs file like this:
    loadplugin("VSFilter.dll")
    FlipVertical(MaskSub("day1.srt",1920,1080,25,13832 ))
    but the .avs files can not be imported to the vegas.
  8. Originally Posted by darknesslord View Post
    .avs cannnot import directly to vegas. You have 2 options:
    1) You can re-encode the subs with masksub() to a transparent background video (e.g. lagarith or ut video codec in RGBA mode - You can do that with vdub), use that imported into vegas as an overlay over your original video .
    2) You can use avfs (avisynth virtual frame server)
    Usually #1 is better, because avfs can bog down your system if you have many instances/layers
    Apr 2014
    ardabil, iran
    thank you, you have been very helpful so far
    i re-encoded that .avs file with lagarith RGBA and imported that into vegas, but the video was only transparent in subtitle part instead of background. so i had to add invert to the avisynth function and re-encode again and import into vegas. it worked the only problem is that i only can get black subtitle
    what i want to do now is:
    1- have white subtitle
    2- have subtitle boxed( e.g. white sub in black box)
    3- have subtitle positioned in a plac other that lower middle
  10. Originally Posted by darknesslord View Post
    No, you just interpret the alpha channel in vegas -
    Right click the clip in the clip bin, properties, media tab, under "alpha channnel" set it to "straight" instead of "none" . "None" means vegas "thinks" the clip is RGB, not RGBA . The alpha channel is for transparency
    SRT subs are text only, no formatting
    If you want to adjust positioning , any fancy effects, colors , fonts ,size ,etc.... I would convert them to ASS subs . With ASS subs you have control over everything. You can use a subtitle editor like aegisub and make them look any way you want. You do this BEFORE hardsubbing the transparent video to import to vegas
    Or you can just make adjustments to the overlay layer in vegas (you can position the overlay, scale, change colors) . You have some control, but not as much control than if you did it the subs in aegisub . For example, you can alter the position in vegas (and they should already be white subs if you interpret the alpha channel) , but you can't automatically put a black box behind them unless you use ASS subs (unless you want an ugly static box in vegas)
    Apr 2014
    ardabil, iran
    there was guid here, use i use this method or you suggest another one for my specific purpose
    Apr 2014
    ardabil, iran
    http://forums.creativecow.net/sonyvegas
  13. Originally Posted by darknesslord View Post
    http://forums.creativecow.net/sonyvegas[/QUOTE]
    I don't understand what you're trying to say
    Use whatever method works for your goals. There were several suggestions listed in this thread
    Apr 2014
    ardabil, iran
    sorry for bad link.
    the reason i asked you is because you said to change "alpha channel to straight instead of none"
    but i tried every method and that suggestion didnt effect anything
    here is the method suggested in that link
  15. Originally Posted by darknesslord View Post
    The answer was posted above:
    If you tried that and it's still "black" in the background - not transparent - then you probably did not follow the other instructions correctly. Make sure lagarith or ut video is set to RGBA mode . The "A" is important
  16. Try this sample below in vegas. The sample is lagarith RGBA 1920x1080 25fps, 2secs
    Even if you "forgot" to use the alpha channel in vdub or lagarith or ut video configuration , you can use the same black/white video as a luma matte , or key out the black using luma key . If you've inverted the colors for some reason, invert the colors then use the luma key
    But it's better to do it the first way with the RGBA with embedded alpha, because there are fewer effects applied, thus fewer resources being used by vegas
    If nothing works, post a small sample of your encoded masksub clip (cut a small section using video=>direct stream copy , file=>save as avi in vdub )
  17. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Shouldn't the Alpha be set to "Pre-Multiplied"?
  18. Originally Posted by budwzr View Post
    Not in this situation - it's a straight alpha , pure black/white
    You use premultiplied alpha when the clip has variable (semi)transparency, maybe feathered edges
  19. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Oh, I see. It's a 100% Density Map? Hahaha.
    Apr 2014
    ardabil, iran
    thanks man, you helped me do exactly what i wanted to do
    and since you know every thing, do i have any chance of compressing these clips without any quality loss?
  21. Originally Posted by darknesslord View Post
    The subs are already compressed
    In that example, lagarith is used. Lagarith is an example of lossless video compression
    If you had used uncompressed RGBA instead, that clip would be 1.72MB clip would become 395MB. That's about 230x the size. It achieves so much compression because blank areas are easy to compress, low complexity. It's just a small time/date overlay. If you tried to compress "regular" content, you would not achieve such a large compression ratio .
    Native AVCHD clips are already compressed, so when you use lagarith, they actually become 5-10x larger. (Because the lossless compression is applied to the uncompresssed stream from the AVCHD - it's decoded and uncompressed before being re-compressed by lagarith)
  22. Member
    Apr 2014
    ardabil, iran
    i meant the compressing overall output, in other words clips captured by my handycam which information is mentioned in the beginning of thread.
    they have bitrate of 22Mbps, they are rather big files, so i look for a lossless (or unnoticeable loss) re-compression.
  23. Lossless (mathematically lossless) compression will just increase the filesize
    You can reduce the filesize with minimal quality loss by re-encoding using x264 or some GUI for it (e.g. megui, ripbot, xvid4psp). You can frameserve out of vegas using debugmode frameserver. You can use <search> because there are many guides describing how to do this
  24. Member Cornucopia's Avatar
    You already have lossy-compressed files (~30:1). You will be uncompressing them to do the overlay of the subs, then re-compressing them. This will LOSE quality. No ifs, ands or buts.
    How much quality you lose will depend on the compression settings & bitrate you give it when re-compressing. Again, if you re-compress to Lagarith, etc., your size will likely be 5x or more what it is now (though the only quality you will lose would be from the overlay operation's bitdepth rounding calculations). If you recompress back to an AVC of form & bitrate similar to your source file, you will have similar sizes to your source and will have only SLIGHT or MILD quality losses. How much is MILD? Is MILD too much for you? You have to decide that. If you try to do the recompress AND you try to go for even LOWER sizes, your losses will be even more noticeable. How much noticeable depends again on the material and on YOU.
  25. Member
    Apr 2014
    ardabil, iran
    actually this clip is codec with this parameters and possibly with fast algorithm
    i think re-encoding it with higher reframe, b-frame, format profile and ... can result in smaller file with unnoticeable quality loss
  26. Member
    Apr 2014
    ardabil, iran
    1-what is that?
    and by the way i use mediacoder for encoding.
    2-how good is that? i mean should i stick to this or i should choose another encoder?
    3- i also have handbrake which seem to have more options than mediacoder for h264!!! why?
  27. Originally Posted by darknesslord View Post
    1-what is that?
    It's a frameserver. It allows you to "connect" vegas to other programs. So it allows vegas to use other encoders. You can use x264 (or some GUI for x264), because it potentially offers better compression (better quality per filesize) than vegas's mainconcept or sony AVC encoders
    It depends what settings and encoder you use. Mediacoder is just a GUI or front end for other encoders
    Ask the programmer, Stanley Huang. Or learn to use x264 commandline (more options than handbrake) . Having more options is only better if you know how to use them and in what situations - otherwise it can get confusing
