Here's my boggle,I can capture compressed AVI at 30fps no problem. Then I've been using MPEG1 compression (TMPGEnc) and burning those to disks. Last week I found VCDhelp and last Xmas got a Philips DVD-714 player. I downloaded VCDEasy and began to study however the about 6 burnt CD's later I still cannot play the finished DAT file in the MPEGAV directory.
It will play with the Windows media player but sound and video are garbled. Green squares and blotched video is all I can see. The player results with either the same as above or disk error or trys to look for MP3 files. Okay to wrap things up:
Philips 714 DVD Player - Manual states VCD 2.0
Computer 1.1Ghz Celeron, Acer 8x2x32 CDRW
Win TV Capture Card 848 Booktree
MMPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps
VCD 2.0 option set on VCDEasy
I am just curious about the VCD options since my player says it will play them. If I cannot keep losing disks like this my wife is ready to kill me.
Results 1 to 1 of 1
Remember, Life is one game that none of us will get out of alive.
avi won't play
By fabre in forum Software PlayingReplies: 2Last Post: 25th Aug 2011, 00:26 -
.ogm Won't play
By shiroshadows in forum Software PlayingReplies: 8Last Post: 2nd Jan 2010, 20:38 -
some .mkv won't play
By snooze091 in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2009, 18:48 -
MP4 won't play
By lilblu in forum Software PlayingReplies: 3Last Post: 15th May 2009, 00:25 -
JPegs won't play on TV
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 18:04
