hi i made some 3d blu-ray clips using tsmuxer for use in powerdirector 12 but when created as a 3dbd the 3d works but the framerate is off, its jerky and varies from clip to clip (2d is fine and powerdirector 3d conversions work too) im guessing it maybe the bitrate is too high on them (had the same prob with premiere 2d clips) but i cant seem to find a programme that will handle 3d m2ts files and ley me lower the bitrate
any ideas please? thx
What framerate did you start with? 3dbd only supports a very small subset of acceptable framerates.
Scott -
It should do movie-only or you could try IMPORT feature on the individual m2ts files
